advinnie Samba Member
Joined: November 18, 2011 Posts: 1389 Location: oxfordshire
Posted: Tue Nov 21, 2017 10:17 am Post subject: White steam / smoke coming out of crank case breather |
Hi all have a look at this video and tell me if you think I have a piston ring on it’s way out
The first video is of the breather after a five minute run and the second video is of the breather on first start up when cold
https://m.youtube.com/watch?v=2WkvyS351FU
https://m.youtube.com/watch?v=bD0-GwWcw6U
In the second video I had the engine engine running at just 500rpm |
jason Samba Member
Posted: Tue Nov 21, 2017 10:55 am Post subject: Re: White steam / smoke coming out of crank case breather |
New, rebuild? Do a leak down. |
Posted: Tue Nov 21, 2017 11:04 am Post subject: Re: White steam / smoke coming out of crank case breather |
The engine is a rebuild with new cam, pistons and barrows, pump and so on.
Unfortunately I don’t have a leak down test set so I will have to go buy one |
Posted: Tue Nov 21, 2017 11:07 am Post subject: Re: White steam / smoke coming out of crank case breather |
I can say that when I try and turn the engine over by hand you can fill all four cylinders have compression |
slalombuggy Samba Member
Posted: Tue Nov 21, 2017 11:36 am Post subject: Re: White steam / smoke coming out of crank case breather |
At this point it's not a question of is it on it's way out, but which one? I'd say you have a definite ring problem. You didn't use synthetic oil did you?
brad. |
thesatanicmechanic Samba Member
Joined: November 30, 2008 Posts: 102 Location: Charlotte, NC
Posted: Tue Nov 21, 2017 12:13 pm Post subject: Re: White steam / smoke coming out of crank case breather |
Details on the rebuild?
Piston and cylinder brand, bore, height group, ring end gap, etc...
Oil isn't way overfilled is it?
You could drive it and try to seat the rings, search "break in" on the site. That is a whole lot of blow by though. |
Posted: Tue Nov 21, 2017 12:23 pm Post subject: Re: White steam / smoke coming out of crank case breather |
This is the Oil I’ve just https://www.flightstore.co.uk/aircraft-supplies-c8...J_EALw_wcB
I can’t give you much detail on the engine rebuild it wasn’t done by me
I have a friend coming round in a minute with a compression tester so I will post up my results. But I just want to make shaw I will be doing it right, I do it on a cold engine and crank it over with the throttle fully open? |
Posted: Tue Nov 21, 2017 1:35 pm Post subject: Re: White steam / smoke coming out of crank case breather |
Right here are the results
Cylinder
1-124psi
2-122psi
3-122psi
4-126psi
If that’s good or bad I have no idea?
Next he done a leak check at 100psi
Cylinder 1 held 82psi
Cylinder 2 held 80psi
Cylinder 3 held 82psi
Cylinder 4 held 83psi
Once again I have no idea if that’s good or bad |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Tue Nov 21, 2017 2:56 pm Post subject: Re: White steam / smoke coming out of crank case breather |
You need dino oil to break in the rings. Put some straight grade and try the ring break in procedure again. Hopefully the rings will set. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4028 Location: NW Washington
Posted: Tue Nov 21, 2017 2:57 pm Post subject: Re: White steam / smoke coming out of crank case breather |
My guess is you have cracked a couple pistons from detonation with your turbo setup.
If I were you I would pull it off the road now and replace the P/C's with new ones.
With that much blowby you are driving a time bomb.
CorysVDub blew his engine to kingdom come when he had that problem.
I pulled my engine and replaced my P/C's when I had a blowby problem also.
I could not see the cracks with the naked eye but I never pulled the rings to check there.
It fixed the issue and I have had no other problems since going FI and being able to control Fuel and timing. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Tue Nov 21, 2017 3:04 pm Post subject: Re: White steam / smoke coming out of crank case breather |
I agree time to pull the engine and fit some more pistons 😡 |
Posted: Tue Nov 21, 2017 3:08 pm Post subject: Re: White steam / smoke coming out of crank case breather |
Is there any brand you would recommend? |
Posted: Tue Nov 21, 2017 3:10 pm Post subject: Re: White steam / smoke coming out of crank case breather |
advinnie wrote: |
It happens......That's why you want to run a muffler of some sort to make the engine quiet. You can hear the detonation if your exhaust is quiet enough.
Detonation can come at any time and if you let it happen too much you will crack the pistons.
Fix it now and it's just a set of barrels and pistons....let it go till it blows and you might be able to save only the clutch and flywheel.
Cory's engine was carnage and completely destroyed....you don't want to go there......... _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Tue Nov 21, 2017 3:24 pm Post subject: Re: White steam / smoke coming out of crank case breather |
I must say that at no point have I herd detonation and I’ve been very safe with the timing but shit happens |
Posted: Tue Nov 21, 2017 4:06 pm Post subject: Re: White steam / smoke coming out of crank case breather |
Cast or forged pistons! |
Posted: Tue Nov 21, 2017 4:20 pm Post subject: Re: White steam / smoke coming out of crank case breather |
advinnie wrote: |
If you can't hear the detonation due to exhaust or car noise then you can't say you have been safe with the timing.....
The blowby..... in my experience points to severe detonation......but I could be wrong.
I have AA P/C's and they are the Hyperteutic (spelling??) pistons.
If you don't have a good muffler on your engine then I doubt you will be able to hear the detonation.....especially if you don't know what it sounds like. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Tue Nov 21, 2017 10:21 pm Post subject: Re: White steam / smoke coming out of crank case breather |
In spite of the consistent test result #s, that pronounced breather pulsing seen in vids pretty much pegs it - you've no compression seal on 1 cylinder.
Suggest trying the dino oil first - have nothing to lose.
As others have noted, some type of quiet exhaust would also help here.
G' luck! _________________
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Posted: Wed Nov 22, 2017 12:29 am Post subject: Re: White steam / smoke coming out of crank case breather |
Cheers all for your help/advice I will try a straight 30weight Oil first while I want for farther Christmas to bring me my forged pistons 😁 |
Posted: Wed Nov 22, 2017 6:04 am Post subject: Re: White steam / smoke coming out of crank case breather |
Hi all after I post my compression last night I noticed that the compression gauge I was using was broken so went out and got a new one today and got a total different result.
The first figures are the cold cranking pressures and the second are hot cranking pressures
Cylinder 1- 117 & 128
Cylinder 2- 110 & 125
Cylinder 3- 50 & 68
Cylinder 4-120 & 129
No this is where I’ve got confused
After cranking for ten seconds I took the reading on the gauge and then left the engine for five minutes to see what the pressure drop would be and here’s them results
Cylinder1-went from 117 down to 109psi
Cylinder 2 went from 110 down to 104psi
Cylinder 3 went from 50 down to 47psi
Cylinder 4 went from 120 down to 114psi
This was done on a cold engine but if cylinder 3 is not making pressure due to bad rings how is it holding on to its pressure?
I was expecting cylinder 3 to drop its pressure very fast but it didn’t |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1597 Location: The South Zone
Posted: Wed Nov 22, 2017 6:16 am Post subject: Re: White steam / smoke coming out of crank case breather |
I think it's not your cylinder that's holding pressure, it the one-way check valve in the compression gauge that's holding pressure.
So, no. 3 is the culprit. Nice catch. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
