windfish Samba Member
Posted: Wed Nov 22, 2017 7:42 am Post subject: Hit a critter, dent advise |
Hit a opossum or racoon last night; ran right out in front, I just saw a blur and heard/felt a large thump as it impacted my front apron. Went back and looked, never found it. Only know what it was 'cause dashcam, initially thought it was some debris in the road.
Guess it's possible it lived, more likely it got thrown into the woods a bit. Makes it the first critter I've (probably) killed in 15 years of driving :/
Could have been worse on my bug's end, only seems to have dented the (already a bit rusty and bondo'd) front apron.
Any tips on massaging it back into shape? Not much experience with body work.
Doesn't have to be perfect, just the general shape would be nice.
Clip from the dashcam (here) for those morbidly curious. Less than a second.. |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1597 Location: The South Zone
Posted: Wed Nov 22, 2017 8:15 am Post subject: Re: Hit a critter, dent advise |
I wonder if the raccoon is on the small forest animal version of the samba right now, asking for advice on how to pound out the dent in his back.
A ball-peen hammer and a couple pieces of well placed 2X4 will get you close. Although an auto-body hammer and dolly would do a nicer job.
Good luck, man. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3333 Location: 802 The Pointless Forrest
Posted: Wed Nov 22, 2017 8:39 am Post subject: Re: Hit a critter, dent advise |
try the football trick, or comealong and tree _________________ "Albatross"! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Nov 22, 2017 8:44 am Post subject: Re: Hit a critter, dent advise |
Could try removing access plate and use that to run a rope or chain thru there. Then rig up a wood pole, or bar of steel to pull the dent out with hand winch. Would need to shim inside around the pole/bar so you do not crush the rim of the access hole and tie the rear end of the VW so it does not just drag.
With hammer in there you are not going to have a lot of swing room and more likely to make a rumpled mess. _________________ In Stereo, Where Available! |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Wed Nov 22, 2017 9:02 am Post subject: Re: Hit a critter, dent advise |
calvinater wrote: |
try the football trick, or comealong and tree |
Football trick? |
Posted: Wed Nov 22, 2017 9:11 am Post subject: Re: Hit a critter, dent advise |
yes, insert deflated football behind crumple, then inflate.. sometimes gives enough force to reform the metal. _________________ "Albatross"! |
beetlenut Samba Member
Posted: Wed Nov 22, 2017 10:36 am Post subject: Re: Hit a critter, dent advise |
Good time to replace that apron. If not, hammer and dolly are your best bet, but then you'll have to paint it cause the paint won't survive the pounding. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Wed Nov 22, 2017 11:25 am Post subject: Re: Hit a critter, dent advise |
calvinater wrote: |
yes, insert deflated football behind crumple, then inflate.. sometimes gives enough force to reform the metal. |
might need a basketball for this job.... _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
mark tucker Samba Member
Posted: Wed Nov 22, 2017 1:42 pm Post subject: Re: Hit a critter, dent advise |
new apron!!! there cheep. |
Starbucket Samba Member
Posted: Thu Nov 23, 2017 9:32 am Post subject: Re: Hit a critter, dent advise |
Three "c" clamps and a 2X4, clamp the 2X4 outside of apron at each end and slowly tighten the clamp you place over the center of dent until you reach the 2X4. |
mukluk Samba Member
Posted: Thu Nov 23, 2017 9:50 am Post subject: Re: Hit a critter, dent advise |
windfish wrote: |
Definitely a raccoon.
I'd lean toward the hammer and 2x4 method for knocking a dent back out of the spare wheel well. Make sure you round the corners of the 2x4 to keep from pounding high points into the sheetmetal; putting a piece of thick scrap leather or rubber in place prior to the 2x4 works rather well also. _________________ 1960 Ragtop w/Semaphores "Inga" |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Thu Nov 23, 2017 11:54 am Post subject: Re: Hit a critter, dent advise |
You can barely see it. Try knocking it out but don't worry about it. It could have been a deer. _________________ www.vwnos.com [email protected]
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Nov 23, 2017 4:09 pm Post subject: Re: Hit a critter, dent advise |
Starbucket wrote: |
I agree with this ^^^. There's no need or advantage to pounding, hammering, etc..
If the clamps don't work- use the scissor jack out of your wife's Volvo against the boards. The football trick might work with a backboard.
And yes, I've done both tricks several times without resorting to imprecise pounding. _________________
EverettB wrote: |
FU#5 |
Dan Hiebert Samba Member
Joined: July 14, 2016 Posts: 169 Location: Northern Maine
Posted: Fri Nov 24, 2017 6:55 pm Post subject: Re: Hit a critter, dent advise |
The metal on these cars is easy to move. I'd use a 2x4 with one end contoured to match how the apron is curved, pounded on the back end, to move it close, then use a hammer and dolly to get it closer to where it's supposed to be. Whether you use a football, 2x4 and clamps, hammer and dolly, etc. (anything is fair game in body work), any Bondo on there will be loosened off the metal anyway. I'd just get it over with and sand that area down to bare metal before working it, at least before working the final shaping. If the metal is rusted through anywhere, it will most likely tear. I note you're not seeking perfection, but you'll be glad you're working with bare metal. Then you can smooth it out with filler and touch it up with primer and paint. |
