TryToBeOriginal Samba Member
Joined: July 23, 2012 Posts: 266 Location: Georgetown, Texas
Posted: Tue Dec 05, 2017 7:09 am Post subject: Re: 1963 Rebuild/Resto |
Thread wrote: |
Regarding the all thread going through the center tube, I had seen a DIY somewhere (maybe here) where something similar to what you've found was a remedy for the clutch cable tube mount in that area having failed.
It was a way of avoiding having to make a large hole in the center channel to re-weld it. |
Good to know! I plan on checking all of that when I get to the pan.
On another note, I popped the two brass welds holding down the seam and now the entire thing is open. Sad to say YES the entire quarter panel was held in at the seam by nothing more than 2 spot welds and gravity. I am going to start across the bottom next and free that side then work my way to the front trunk. |
Posted: Thu Dec 07, 2017 9:28 am Post subject: Re: 1963 Rebuild/Resto |
So last night I managed to finally get through all that Bronze. Pain in the ass...
I still have a lot of work to do for the entire panel to come off but my biggest fear right now is getting the doors to align again. I was looking last night and my drivers side has 1 cm gap between door and B pillar while passenger has .5 cm. Guessing I can probably adjust these a little when I do heater channel repairs on the driver side.
Just gonna keep chugging along removing this panel until I can get a welder and some sheet metal hammers to straighten the panel a little.
mukluk Samba Member
Posted: Thu Dec 07, 2017 10:10 am Post subject: Re: 1963 Rebuild/Resto |
The passenger door gaps look good; the driver's door is shifted too far forward, most likely due to bent hinge mount points on the door and/or A pillar. You don't have any decent shots of the front of the driver's door in your gallery, but I'd pretty much guarantee there is almost no gap present between the door and A pillar from the bottom hinge all the way up to near the top of the vent window. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Thu Dec 07, 2017 10:31 am Post subject: Re: 1963 Rebuild/Resto |
mukluk wrote: |
The passenger door gaps look good; the driver's door is shifted too far forward, most likely due to bent hinge mount points on the door and/or A pillar. You don't have any decent shots of the front of the driver's door in your gallery, but I'd pretty much guarantee there is almost no gap present between the door and A pillar from the bottom hinge all the way up to near the top of the vent window. |
You are right. Bottom hinge has little to no gap and the top hinge has some. vent is super tight as well.
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Thu Dec 07, 2017 4:18 pm Post subject: Re: 1963 Rebuild/Resto |
What's the condition of the door "check-rod" on the left side? _________________ Jesucristo es mi Seņor y Salvador! |
Posted: Thu Dec 07, 2017 4:56 pm Post subject: Re: 1963 Rebuild/Resto |
57BLITZ wrote: |
What's the condition of the door "check-rod" on the left side? |
both are in good condition but that said I can open the drivers door a full 90 degrees. Can't remember if that is normal or not. I feel like my 69 opened to the same degree |
Posted: Wed Dec 13, 2017 9:43 am Post subject: Re: 1963 Rebuild/Resto |
welp... managed to get my middle finger with the cutoff wheel Monday night. 5 stitches later can;t really feel the tip yet. Think I'm gonna take a break until the new year and come back fresh. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Wed Dec 13, 2017 10:25 am Post subject: Re: 1963 Rebuild/Resto |
Good thing you did not cut the tendon for that finger, or they would have had to open up your arm up to near the shoulder to pull the tendon back down.
Got to hold grinders with both hands, and IOHO best grinders have the type of switch that turns off the tool off when you lose hold of it.
Other way you can go is a less powerful cutting tool like Harbor Freight sells or the smaller Dremil. The latter is required to do fine clean up work, that a big grinder/cut off would just make a bigger mess of. Course those will take more time to do the same job with weaker and/or smaller tools, but might save you a lot more time at the Emergency room and healing up.....
Hope you are feeling better soon! _________________ In Stereo, Where Available! |
Posted: Wed Dec 13, 2017 10:30 am Post subject: Re: 1963 Rebuild/Resto |
Eric&Barb wrote: |
Hope you are feeling better soon! |
Thanks!
It happened to me a few years ago because I was grinding one handed with my off hand and the torque twisted it in my hand. Learned my lesson and always use 2 hands now but this time I was cutting welds down and it grabbed a loose piece of metal pulling it out of my left hand and bouncing onto my finger... it has the paddle switch so it stopped as soon as I hit but it was enough time to go about 3/8" in. can't feel the tip of the finger but I can feel it tug the nerve if I stretch so hoping the nerves are just over sensitized for now.
Live and learn... |
Posted: Fri Jan 26, 2018 9:48 am Post subject: Re: 1963 Rebuild/Resto |
I've been lazy about updating this thread but pulled the front apron off the car and still working on removing the front quarter now that the finger is healed.
also dropped the engine and stripped it down to long block up on the stand. This weekend's plans are to build a new workbench and split the case open and start the engine rebuild. This engine was SUPER nice. everything was there from the original thermostat to the original VW coil and VW distributor. Pretty sure this is a 100% original engine. I did find some brass bar on the oil cooler so guessing it may have had issues at one time unless VW used brass bar on those.
Also noticed some metal shavings in the bell housing and the flywheel teeth edges were worn. may need to look into what would cause that. Planning on picking up a Bentley manual here this weekend as well so I can get some better information for engine specs.
Any tips and tricks for engine checks I should do is always appreciated. Pics to come of the progress. |
Posted: Fri Jan 26, 2018 10:06 am Post subject: Re: 1963 Rebuild/Resto |
Pre-DH Oil coolers were brazed closed when built at the factory. _________________ In Stereo, Where Available! |
Posted: Mon Feb 19, 2018 3:51 pm Post subject: Re: 1963 Rebuild/Resto |
I just realized how lazy I have been about updating this thread...
Life has been crazy busy since the new year so not as much as I would like to get done so far but still decent progress. managed to pull the front 2 drums off and get a look in there. also pulled off the front apron to straighten that out.
Managed to get it up on stands and drop the engine.
Split the engine open and am checking all the tolerances.
Up next is fixing the quarter panel and rebuilding the engine. Once those are done onto fuel and brakes. Then I should have a driving car. Plan on getting it running before I start all the body work. Need some milestones to keep the morale up.
Quick question on the head. Looks like there is a half moon piece of casting missing next to the exhaust port. Can't tell if it was chipped off or if it was made like that. I guess ultimately is this going to make me buy a new head ot is this one going to be fine?
Posted: Mon Feb 19, 2018 3:56 pm Post subject: Re: 1963 Rebuild/Resto |
That chip in the head is fine. The intake & metal seal seals against the lower surface of that hole. The chipped edge is just a centering ridge for the metal "O-ring" seal there so it is not offset to the hole into the head. _________________ In Stereo, Where Available! |
Posted: Tue Mar 13, 2018 3:48 pm Post subject: Re: 1963 Rebuild/Resto |
One of these days I will get better at updating this thread.
Recently just been working on cleaning every thing up now that the quarter is off. my main fear is how out of shape the spare tire tray is and the support behind it. The driver side is clean but passenger is all out of whack. Trying to decide do I sit here and spend lots of hours trying to beat it back into shape which will probably require me taking them off and putting them back on or do I just order replacement panels and put on fresh metal.
you can see that the support should have a wedge shape but is not a straight panel up and down.
Also the flange is missing or not aligned anymore to how it should be.
Anyone havae any experience playing with front ends and want to weigh in? |
Posted: Tue Mar 13, 2018 4:18 pm Post subject: Re: 1963 Rebuild/Resto |
Pound it out and use a shrinking disc. Been pulling out dents, bends, and warps out of our SO-34 westie. _________________ In Stereo, Where Available! |
