i_luv_my_bus76 Samba Member
Joined: May 18, 2012 Posts: 371 Location: High Desert
Posted: Thu Nov 23, 2017 6:13 pm Post subject: Part for alternator type 4 |
What is part 19?
I installed a rebuilt alternator in my 76 bay... I am having issue with the battery going dead... I have a voltage regulator and a new battery |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Thu Nov 23, 2017 6:20 pm Post subject: Re: Part for alternator type 4 |
its a radio interference stopper- it is supposed to stop a buzz sound in the radio. from the alt. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Thu Nov 23, 2017 8:27 pm Post subject: Re: Part for alternator type 4 |
Just a capacitor to filter the output of the alternator to lessen radio interference. |
Posted: Thu Nov 23, 2017 9:40 pm Post subject: Re: Part for alternator type 4 |
Wildthings wrote: |
So that's not the reason my battery keeps dying... sounds like I have something still on when the ignition is on draining the battery |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Thu Nov 23, 2017 9:53 pm Post subject: Re: Part for alternator type 4 |
Can you exchange the alternator? _________________ www.vwnos.com [email protected]
Posted: Thu Nov 23, 2017 10:29 pm Post subject: Re: Part for alternator type 4 |
i_luv_my_bus76 wrote: |
Wildthings wrote: |
What is your charging voltage? Should be 14v +/-.
Its not that hard to check for a ghost amperage draw on one of these old rigs. You should be able to find your fault in 30 minutes or less. |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Thu Nov 23, 2017 11:40 pm Post subject: Re: Part for alternator type 4 |
Smarter minds correct me here:
If your battery keeps dying, remove the Positive terminal clamp on the battery. Hook up one lead of a voltmeter to the now bare battery terminal, and select 12VDC on the meter range. Now connect the other meter lead to the dangling Positive terminal clamp. You should see some voltage being read... this is the small load that is being placed on the battery that you are tired of. It might not be the full 12 volts.
Now go to your fuse block under the dash. One at a time, remove each fuse. Each time, look at the meter. When you find the fuse that when removed, causes the meter to read zero, then you have very likely found the offending circuit. Now start tracing that circuit and ensure that it is not hacked, and hopefully you will find the small load that is killing your battery. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Fri Nov 24, 2017 9:53 am Post subject: Re: Part for alternator type 4 |
Or, unhook the neg cable from the battery and hook a test light the the neg battery post and ground the light probe on the body,the light will glow if you have a current draw,then pull fuses as stated above,the light will go out when you pull the fuse for the faulty circuit.
Adding an extension to the test light wire would allow you to have the light up front with you while pulling the fuses.
Turn everything off when doing this test,including the doom light. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Fri Nov 24, 2017 11:13 am Post subject: Re: Part for alternator type 4 |
Wasted youth wrote: |
If your battery keeps dying, remove the Positive terminal clamp on the battery. |
Always safer to deal with the ground terminal on the battery than the "hot" terminal. Accidentally ground out the "hot" terminal and you can find yourself holding an red hot wire in your hands or blast a hole in the side of your van. |
Randy in Maine Samba Member
Posted: Fri Nov 24, 2017 4:12 pm Post subject: Re: Part for alternator type 4 |
And be sure to have a good hard look at fuse #12 especially if your windshield ever leaks so much as a drop. The light "excites" the alternator. |
Posted: Fri Nov 24, 2017 8:02 pm Post subject: Re: Part for alternator type 4 |
kawfee wrote: |
Can you exchange the alternator? |
The alternator has a lifetime warranty on it but Napa is trying to fight me on the exchange...their excuse is that the supplier they ordered it from doesn't have anymore |
Posted: Fri Nov 24, 2017 8:04 pm Post subject: Re: Part for alternator type 4 |
lil-jinx wrote: |
[quote= sounds like I have something still on when the ignition is on draining the battery |
I assume you mean when the ignition is ''off"[/quote]
Yes I meant off |
