5657 Samba Member
Joined: April 11, 2010 Posts: 170 Location: North Okanagan, BC CANADA
Posted: Sat Nov 25, 2017 1:42 pm Post subject: 1956 shift rod |
The rear shift rod has one hole for the set screw on one end and two on the other end(opposite each other). Which end goes to the front ? Thanks _________________ 1956 Type 2 Ambulance
1957 Type 1 Deluxe
1975 914 2.0 litre
2017 Jetta TSI |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Sat Nov 25, 2017 3:05 pm Post subject: Re: 1956 shift rod |
5657 wrote: |
The rear shift rod has one hole for the set screw on one end and two on the other end(opposite each other). Which end goes to the front ? Thanks |
From memory, both ends should have one divot for the set screw, so it could go either way round.
But...
I'd take a guess that you have/had a bug hockey stick in the gearbox. They have the divot on the top (the set screw is accessed from inside the car).
To use a bug hockey stick on a bus, either the hockey stick or the shift rod has to be drilled on the other side (180º from the factory hole) so the two set screws are on the same side and can be wired together across the coupler.
If that's the case, the end with two holes would go at the gearbox end.
I had a bug hockey stick and was going to use it in place of the worn bus hockey stick on my truck, until I read on here about the holes and realised I'd need to drill it. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
