aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Sat Nov 25, 2017 4:39 pm Post subject: Fuel Tank Padding and inside treatment post hot tanking |
I'm getting ready to hot tank two 1971 bus fuel tanks. Does anyone know a source for the strips of padding glued onto the outside in various locations as anti-chafing material?
Also, Will the tank flash rust after the tanking? Should I somehow protect it by sloshing around something inside right away. One tank will be used in a bus right away, the other will be wrapped in plastic and put up for a rainy day. TIA. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Nov 25, 2017 4:45 pm Post subject: Re: Fuel Tank Padding and inside treatment post hot tanking |
Seems to me that Busdaddy and Skills said something about putting ATF on tanks after cleaning, but don't quote me. As for the felt like material, you could possibly get glue on felt strips from a hardware store like what the use on furniture bottoms to keep from ruining your hardwood floor. Beyond that I don't know. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Sat Nov 25, 2017 5:06 pm Post subject: Re: Fuel Tank Padding and inside treatment post hot tanking |
I could have sworn I saw the rectangular felt for underneath being sold new recently, though I can't remember where.
For under the straps, anything seems to work. VW even deleted them on later models.
https://www.thesamba.com/vw/forum/viewtopic.php?p=5955854
I would use ATF for the slosh; it's a good corrosion inhibitor but also easily ingested by the engine.
www.airschooled.com |
scubaseas Samba Member
Joined: May 24, 2013 Posts: 442 Location: ME & Texas, in a Bus or on a boat somewhere
Posted: Sat Nov 25, 2017 5:07 pm Post subject: Re: Fuel Tank Padding and inside treatment post hot tanking |
Slosh coating with ATF works fine for storing tanks.
NAPA or LAPS should have A/C tape which is sticky butyl? and cork. About 1" wide, one side sticky, weather proof. Works great under the tank straps. Or rug under-layment or carpet would work OK too. Sound deadening pad material will work fine as does peel/stick roofing underlayment for ice dam barrier. _________________ Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired |
Posted: Sat Nov 25, 2017 5:14 pm Post subject: Re: Fuel Tank Padding and inside treatment post hot tanking |
Thanks Roberto _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
If you get the tank well drained the little bit of rust you get isn't going to hurt much.
Alternatively slosh some Muriatic acid around in there and then drain it out well and let dry. Follow with a slosh of Osphos and drain well. The excess Osphos can go back into the container for the next job. |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Sat Nov 25, 2017 7:44 pm Post subject: Re: Fuel Tank Padding and inside treatment post hot tanking |
gary
I do a ATF and gas mix. works fine, but I am unsure of long term storage. I can vouch that it works for a month (if kept indoors) as that is about as long as I have had a clean tank before it was put back into service.
I mix 1 quart of cheepie ATF to almost 1 quart of gas. coats everything nicely _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Sat Nov 25, 2017 7:51 pm Post subject: Re: Fuel Tank Padding and inside treatment post hot tanking |
the guy who did mine and Colin's sloshed them with diesel. He then sealed the top and the bottom. The fuel outlets he slid surgical hose between the outlets to keep the fuel from dripping everywhere while stored. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Nov 25, 2017 8:06 pm Post subject: Re: Fuel Tank Padding and inside treatment post hot tanking |
I've got three quarts of mystery ATF on my shelf so I guess I know where that's going. Thanks guys. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
curtp07 Samba Member
Posted: Sat Nov 25, 2017 8:46 pm Post subject: Re: Fuel Tank Padding and inside treatment post hot tanking |
I used felt door weatherstripping on mine. Worked perfectly. _________________ Subaru |
surfbus23 Samba Member
Posted: Sun Nov 26, 2017 6:38 am Post subject: Re: Fuel Tank Padding and inside treatment post hot tanking |
Thanks surfbus,
I ordered some. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
