82WestySD Samba Member
Joined: November 28, 2016 Posts: 28 Location: Southern California
Posted: Sat Nov 25, 2017 9:29 pm Post subject: Diesel Engine in my 81 Rabbit |
About two years ago, I pulled the 1.6 diesel engine from my Westfalia and upgraded to the 1.9 TD and I've had that stock 1.6D engine in my garage ever since. Motor is in fine shape, just wanted a bit more power for my camper. Earlier this week, I bought a 1981 diesel Rabbit (AC model) for $400 on craigslist. Good project and really solid, but it's been sitting for 20 years. The motor is fine except for needing a new injection pump, but needs to be flushed and a heck of a lot of TLC.
TO MAKE A LONG STORY SHORT!-
So anyways, to my knowledge the 1.6D that I pulled from my 82 diesel Vanagon SHOULD be the same motor that's in the 81 diesel I just bought. Is this true? I'm hoping that I can just drop that guy in my rabbit and tinker with the pulled motor from the rabbit in the meantime. [/s][/i] |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Sun Nov 26, 2017 4:03 am Post subject: Re: Diesel Engine in my 81 Rabbit |
It's the same engine except that the intake & exhaust manifolds will need to be swapped & the pump bracket will need to be changed because of the lack of the engine mount (a real PITA.). _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Nov 26, 2017 8:27 am Post subject: Re: Diesel Engine in my 81 Rabbit |
Ah okay - which pump are we talking about here? |
Posted: Sun Nov 26, 2017 8:56 am Post subject: Re: Diesel Engine in my 81 Rabbit |
The engine mount bracket is also the bracket that holds the injection pump to the engine. The diesel Vanagon & the 85- Golfs & Jettas do not use this mount so it does not exist on the the injection pump bracket on these engines. To remove & replace this bracket requires removing the timing belt & the injection pump. This would also be the time to replace the engine mount that's pressed into the bracket. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Nov 26, 2017 5:53 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
Gotcha -I’m thinkin I’ll go ahead with that , the 1.6 I have is due for a new timing belt so while I’m there I’ll go ahead and delete the bracket. Thanks! |
Posted: Sun Nov 26, 2017 8:14 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
Nooo, you'll need to transfer the pump bracket WITH the engine mount from the Rabbit engine TO the Vanagon engine for the Vanagon engine to work in the Rabbit. I hope that was clear enough. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Nov 26, 2017 8:58 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
Oooh okay. So transfer the bracket with mount to the vanagon engine. I assume the injection pump itself is the same though? |
Posted: Sun Nov 26, 2017 9:04 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
Sorta, the throttle lever & cable stop is positioned differently on the Vanagon pump to clear the engine cover but I think it should still work. If not, those could be transferred also, just be sure to make the positions of the levers on the throttle shaft, the spring setups are a convoluted mess on the levers. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
vwoldbug Samba Member
Posted: Wed Nov 29, 2017 6:14 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
I believe the oil pan & oil pump are different . Also the clutch & flywheel are different . |
Posted: Wed Nov 29, 2017 7:38 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
vwoldbug wrote: |
I'm sure those were already used on the 1.9td in the Vanabeast. The oil pump is the same but the pickup tube is different. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Jan 02, 2018 10:28 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
Alright , so pulled the motor from the rabbit no problem and when I put a wrench on the crank - full rotation no problem! So I think I’m gonna replace the injection pump and half a dozen other things instead of swapping the motor. |
Posted: Mon May 21, 2018 4:45 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
UPDATE:
About half a year later.... Rabbit is up running a driving! Ended up staying with the same engine after all. But I'm having a bit of the issue with the injection pump.
So I've pretty much have the injection pump dialed in on fuel/air mixture, however when revving between around 1500 RPM and 2500 RPM, the pump appears to stutter at a very specific range. In other words if I'm accelerating in first gear, at that specific RPM, I will suddenly lose power, then regain power giving a bit of a bucking sensation. If I hold the throttle at that RPM range, under load the car will buck like I'm jerking the throttle. At first I thought my injectors might be clogged, so I took them apart, cleaned them, but there appears to be no difference. So here's my dilemma...I'm guessing my injection pump is the issue, however I have two spare 1.6 injection pumps that need rebuilding anyways. Is it best to go ahead and rebuild one and swap out the one that's in my rabbit? Or any other ideas? |
Posted: Mon May 21, 2018 6:31 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
There is no “dialing in” of air/fuel mixture on a diesel (no throttle plate, only a wide open intake), a diesel only runs as fast as it’s fuel source will allow. Give it more fuel, the faster it will rev. If it finds another source of fuel, it will run as fast as it can until it comes apart (thus the term “runaway”).
Diesels will run on just about anything with a flash point including antifreeze & engine oil. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon May 21, 2018 6:56 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
Gotcha - Any ideas on the pump issue? |
Posted: Mon May 21, 2018 6:59 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
Make sure that it’s a pump issue & not due to ingesting oil that may have puddled in the intake. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue May 29, 2018 6:07 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
Alright - so took off the air filter and looked into the intake and there is a bit of oil puddled in there. I've also noticed that the car tends to put out quite a bit of blue/grey smoke, which I assume is oil being burned. I'm not sure if the two issues are related, but is there any sort of upgrades for a pcv valve that might help stop oil from leaking into the intake? |
Posted: Tue May 29, 2018 6:14 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
Remove the crank case vent hose from the intake & either let it vent to atmosphere (makes for a messy engine bay) or make/buy a catch can/separator. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue May 29, 2018 6:19 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
I'm thinking of running it with a crankcase vent filter attached (hopefully that'll keep my engine bay less smokey than just detaching) and seeing if that'll solve my issue. If not I might be eyeing the valve seals as the smokey culprit and the pump as and issue still.. |
Posted: Wed May 30, 2018 6:03 am Post subject: Re: Diesel Engine in my 81 Rabbit |
What comes out of the crank case vent is not smoky, it will be oily, especially in an engine with excessive blow-by, thus the puddling of oil in the intake. You can also decrease the amount of oil vapor from the crank case vent tube by getting an oil baffle or windage tray from a later gas car to install over the camshaft to reduce the amount of oil slinging from the camshaft into the separator in the valve cover. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed May 30, 2018 1:02 pm Post subject: Re: Diesel Engine in my 81 Rabbit |
Hmmm...I ran it with the crankcase vent tube disconnected and there's quite a bit of smoke coming from the crankcase. In fact when I shut it off and opened the oil cap, there's still quite a bit of a smoke venting with the cap off. Being a diesel I'm not sure if this is on the normal side?...It just seems like smoke coming from the crankcase is never good... |
