key profiles - which and what year/car for?
ratlooker
ratlooker is offline
PostPosted: Sun Nov 26, 2017 12:21 pm    Post subject: key profiles - which and what year/car for? Reply with quote
Hey, can anyone tell me what these keys are for?
On the upper row there's "339" on it...
What profile and what year?
Cheers
johnshenry Premium Member
johnshenry is offline
PostPosted: Sun Nov 26, 2017 5:41 pm    Post subject: Re: key profiles - which and what year/car for? Reply with quote
The ones on top are A profiles, I am pretty sure, bottoms possibly P profile.
John Henry
'57 Deluxe
'56 Single Cab
RareAir
RareAir is offline
PostPosted: Sun Nov 26, 2017 7:14 pm    Post subject: Re: key profiles - which and what year/car for? Reply with quote
Bottom Right looks like an SG code (1954-57)
The bottom Left marked Neiman is for a locking column. I have the same key on my Swedish 1956 Kabriolett
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
ratlooker
PostPosted: Mon Nov 27, 2017 4:15 pm    Post subject: Re: key profiles - which and what year/car for? Reply with quote
Thx you two very much!
And what year is the A-profile and the P-profile for?
RareAir
RareAir is offline
PostPosted: Mon Nov 27, 2017 7:45 pm    Post subject: Re: key profiles - which and what year/car for? Reply with quote
P-profile was used on the ignition portion of Pre ‘52 Beetles & Pre ‘55 Bus
I think 1953-57 Beetle glove box locks also used a P-profile
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
PostPosted: Mon Nov 27, 2017 7:54 pm    Post subject: Re: key profiles - which and what year/car for? Reply with quote
I think A ended in '50 sometime, then they went to P. But I'm not an expert. The A keys are the ones completely flat on one side, and A blanks are getting real hard to find. I paid $100 each for the last few that I bought. I think there is another non VW key that has the same profile as the VW A but is longer. If you take your time, you can grind them down to the proper length. Beetlekey (Marcus) know the answer, and I would like to know exactly when they went from A to P too, as I restore speedo pods.
John Henry
'57 Deluxe
'56 Single Cab
PostPosted: Mon Nov 27, 2017 9:59 pm    Post subject: Re: key profiles - which and what year/car for? Reply with quote
Yes, I don't exact the year range but they definitely did for at least '54-'56
rod_vw
rod_vw is offline
PostPosted: Thu Nov 30, 2017 7:35 am    Post subject: Re: key profiles - which and what year/car for? Reply with quote
Top right is certainly 'A' profile, I have a repro without the VW emblem from Marcus (beetlekey) for our '46 although I don't know the heritage of the ignition lock except that it was supplied original in a large knob dash panel.
Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build.
Bruce
Bruce is offline
PostPosted: Fri Dec 01, 2017 6:17 pm    Post subject: Re: key profiles - which and what year/car for? Reply with quote
johnshenry wrote:
....I would like to know exactly when they went from A to P too, as I restore speedo pods.
A was used up to Dec 31, 1951. Your top right key is an A.
P stared on Jan 1, 1952
P started with split dash cars, continuing through zwitters and was used for all 1953 ovals (to Dec 31, 1953).
The switch from A to P happened on the same day for Bus. But Bus used the P key up to Feb 28, 1955.
The top left key isn't a P. A P has two grooves on one side, and one on the other. Besides, that key is stamped with an R, so it's probably an OEM key for some other German car from the olden days.
Bruce
Bruce is offline
PostPosted: Fri Dec 01, 2017 6:39 pm    Post subject: Re: key profiles - which and what year/car for? Reply with quote
The bottom right is for shift locks and steering locks.
Shift lock, Jan 1, 1957 to Nov 30, 1959
Steering lock, Mar 1, 1954 to Dec 31, 1957
beetlekey
beetlekey is offline
PostPosted: Sun Dec 24, 2017 7:53 am    Post subject: Re: key profiles - which and what year/car for? Reply with quote
Cheers
R / A new style / Neimann A old head / Neimann O
Hebmüller 581
1953 oval Typ 11G metalblue
1966 1300
If you are searching for vintage keys, look here:
https://www.facebook.com/WagenmanufakturHO
