Rear decklid lock cylinder removal
sdthing
sdthing is offline
PostPosted: Sun Nov 26, 2017 4:37 pm    Post subject: Rear decklid lock cylinder removal Reply with quote
So does anyone know what is needed to remove the lock cyl. out of the latch on the rear of the 1974 Thing? I would imagine the type 1 is the same. Not get the latch off the decklid but the cylinder out of the latch?
TIA
'74 VW type 181
1600 cc DP
dual Weber 34 ict carbs
electronic ignition
009 distributor
A/M exhaust
oil filter
cut and twisted beam
owned since 1983
In San Diego since it was new
No accidents
2nd owner
Other VW's I have owned: '74 Super beetle (bought new), '68 Baja (tilt Front, 1835), '64 Variant (factory sunroof), '69 slammed Cal look beetle, '62 slammed beetle (sunroof, built motor)
"Only the real messiah would say he's not the messiah"
sdthing
sdthing is offline
PostPosted: Sun Nov 26, 2017 8:31 pm    Post subject: Re: Rear decklid lock cylinder removal Reply with quote
Anyone? Bueller?
'74 VW type 181
1600 cc DP
electronic ignition
009 distributor
A/M exhaust
oil filter
owned since 1983
No accidents
2nd owner
Al Capulco Premium Member
Al Capulco is offline
PostPosted: Sun Nov 26, 2017 10:07 pm    Post subject: Re: Rear decklid lock cylinder removal Reply with quote
A tiny little screwdriver.
sdthing
sdthing is offline
PostPosted: Mon Nov 27, 2017 8:33 am    Post subject: Re: Rear decklid lock cylinder removal Reply with quote
And what would one do to facilitate the removal of the lock cylinder with a "tiny screwdriver"?
Does anyone have a serious answer to this question?
Please don't waste time with an incomplete "time wasting answer"
Why would you give an incomplete answer like that Al Capulco?
Either you know or don't know. I'm guessing you don't.
'74 VW type 181
1600 cc DP
electronic ignition
009 distributor
A/M exhaust
oil filter
owned since 1983
No accidents
2nd owner
PostPosted: Mon Nov 27, 2017 10:45 am    Post subject: Re: Rear decklid lock cylinder removal Reply with quote
You asked what was needed. Someone with your attitude should learn to use the search button.
kenj06
kenj06 is offline
PostPosted: Mon Nov 27, 2017 2:48 pm    Post subject: Re: Rear decklid lock cylinder removal Reply with quote
here's a thread that covers some of it:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8241315
And a tiny screwdriver is needed. Surprised
