Glenn Mr. 010
Joined: December 25, 2001 Posts: 76946 Location: Sneaking up behind you
vamram Samba Member
Posted: Mon Nov 27, 2017 3:22 pm Post subject: Re: 20 years ago |
Wow, came a long way from "car in tow!" Do you drive it in Long Island winter? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Glenn Mr. 010
Posted: Mon Nov 27, 2017 3:26 pm Post subject: Re: 20 years ago |
vamram wrote: |
Wow, came a long way from "car in tow!" Do you drive it in Long Island winter? |
nope... it's a weekend car now.
But I used to.
_________________ Glenn
Member #1009
#BlueSquare |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Nov 27, 2017 5:26 pm Post subject: Re: 20 years ago |
What offset are you running on the rims? Tire size? Looks good. Nice car. |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Mon Nov 27, 2017 5:50 pm Post subject: Re: 20 years ago |
Pruneman99 wrote: |
Glenn has a link to his build at the bottom of his post
Suspension Specs: IRS - Ball Joint / 4 Wheel Independent
Front Beam - VW (German), Gene Berg AVIS adjusters, Ghia spindles (adjustable, lowered 3")
Rear Trailing Arms - Sway-A-Way Adjustable Spring Plates
Antiroll Bars - Sway-A-Way 19mm front and 25mm rear, urethane mounts
Shocks Front - KYB GR2, low pressure gas, Opel GT (shorter for lowered beam)
Shocks Rear - KYB GR2, low pressure gas, stock length
Brakes Front - Volkswagen, Type 3 calipers (ATE) and Brembo rotors, Mintex pads, Aeroquip steel braid hose
Brakes Rear - Volkswagen, Ate drums, Mintex shoes
Wheels - Porsche/Pedrini, 914 Aluminum alloys 5.5x15
Tires - BF Goodrich g-Force Sport, 195/55VR-15 front and 205/60VR-15 rear
Misc. - M&H Racemaster 26x6x15 slicks mounted on Porsche/Fuchs 914 forged alloys 5.5x15 _________________ 1960 Convertible |
Glenn Mr. 010
Posted: Mon Nov 27, 2017 5:54 pm Post subject: Re: 20 years ago |
Pruneman99 wrote: |
Wheels are "real" Porsche/Pedrini 5.5x15 ET42
Tires are BF Goodrich g-Force 195/55VR-15 front and 205/60VR-15 rear.
Front is dropped 3" and the rear 1".
Member #1009
#BlueSquare |
