PopPop Jambon Samba Member
Joined: November 23, 2016 Posts: 125 Location: Florida
Posted: Tue Nov 28, 2017 2:00 pm Post subject: how do I tell if my wheels are 4.5 or 5.5 |
I have what appear to be stock rims on my 68 Beetle. What I would like to know is how do I tell if the rims are 4.5" or 5.5" since they already have tires on them?
Is there a marking that I could look for??
Thanks _________________ Eric
VWLM
1968 Beetle 1600 DP
Sort of a Baja
(PO removed the deck lid, cut out the rear skirt and added rear fiberglass fenders, that's about it) |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Nov 28, 2017 3:30 pm Post subject: Re: how do I tell if my wheels are 4.5 or 5.5 |
Take some good pictures of them so we can see them. Are your rear wheels deeper than your front wheels or just bigger tires?
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Wed Nov 29, 2017 5:20 am Post subject: Re: how do I tell if my wheels are 4.5 or 5.5 |
Factory wheels had the size stamped on the ribbing under the hub cap. Factory wheels on a 1968 beetle would be stamped 4J X 15 which is 4" wide. 4.5J would be a 4.5" wheel, etc.
Not all aftermarket wheels were stamped with the size.
Also, rims are measured to where the tire bead mounts, so if you can manage to measure to the outside lip of the rim, that measurement is usually 1" wider than the rim size. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Wed Nov 29, 2017 1:10 pm Post subject: Re: how do I tell if my wheels are 4.5 or 5.5 |
Mike Fisher wrote: |
Take some good pictures of them so we can see them. Are your rear wheels deeper than your front wheels or just bigger tires? |
All rims are the same size. The rear tires are bigger than the front. I will get some pics today. That pic is where the car was sitting when I purchased it. _________________ Eric
VWLM
1968 Beetle 1600 DP
Sort of a Baja
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
