MedievaL Samba Member
Joined: October 15, 2017 Posts: 9 Location: Warrior, AL
Posted: Tue Nov 28, 2017 4:02 pm Post subject: Why would someone have done this? |
I assume they were trying to get to something in the tunnel but I am not sure what. I was planning to patch it this weekend but being pretty new to the VWs I was curious what you guys thought. |
anthracitedub Samba Member
Posted: Tue Nov 28, 2017 4:21 pm Post subject: Re: Why would someone have done this? |
To get to a broken clutch cable tube. |
c21darrel Samba Member
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Tue Nov 28, 2017 6:50 pm Post subject: Re: Why would someone have done this? |
My tunnel had a dodgy patch on the top (not as dodgy as your hacked hole) so I cut it out and welded a new patch piece in. I did a rectangular hole but did a radius on the each corner (good practice to avoid locations where cracking can start). The tunnel is the structure for the whole chassis so it is crazy that people hack holes and don’t fix them properly. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Tue Nov 28, 2017 7:18 pm Post subject: Re: Why would someone have done this? |
Either a broken clutch cable tube OR your car was originally an auto-stick and the prior owner had to weld in a new clutch cable tube when it was converted to manual. _________________ 1966 Karmann-Ghia convertible |
Posted: Wed Nov 29, 2017 3:23 pm Post subject: Re: Why would someone have done this? |
I finished cutting that "hatch" out today and cleaned it up a bit in preparation of patching it. I vacuumed the tunnel out as best I could and stuck my phone in there and took some pictures. I can't see any issues with any of the tubes in there so hopefully I can just weld in the patch and be done with it. I am going to wait until I cut the pans out to finish it so I can get the seat track out of the way. |
PolarBearVW Samba Member
Posted: Wed Nov 29, 2017 3:55 pm Post subject: Re: Why would someone have done this? |
Might be a good time to run a fuel line first. I’ve lived the dream of fishing one through....ugh _________________ 1974 Ghia Coupe |
kingkarmann Samba Member
Posted: Thu Nov 30, 2017 10:14 am Post subject: Re: Why would someone have done this? |
Last spring, in a clutch I had to do a "Field" repair which has held up really well. I did bend the acess flap back into place but haven't had I welded up yet. I'll admit I thought mine was fugley but that might be the worst I've seen. Looks like they used a hammer & chisel to open that up!
_________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Posted: Thu Nov 30, 2017 10:15 am Post subject: Re: Why would someone have done this? |
MedievaL wrote: |
Thought you might be interested in what I found in my tunnel........
Mike Gerson
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6593 Location: Houston, Texas
Posted: Thu Nov 30, 2017 12:55 pm Post subject: Re: Why would someone have done this? |
At least you didn't find a mouse. _________________ www.vwnos.com [email protected]
xzener Samba Member
Posted: Thu Nov 30, 2017 9:05 pm Post subject: Re: Why would someone have done this? |
My 70 beetle had the infamous loose clutch cable squeak... I purchased my Ghia, and was thankful the PO cut open the tunnel and fixed the loose cable tube. I installed Dynamat right over the cuts. Will be accessible if it were to come loose again. Hopefully it will hold. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Thu Nov 30, 2017 10:52 pm Post subject: Re: Why would someone have done this? |
xzener wrote: |
My 70 beetle had the infamous loose clutch cable squeak... I purchased my Ghia, and was thankful the PO cut open the tunnel and fixed the loose cable tube. I installed Dynamat right over the cuts. Will be accessible if it were to come loose again. Hopefully it will hold. |
Hopefully dynamat will hold cuts in the chassis together, lol _________________ 1962 Karmann Ghia
Posted: Fri Dec 01, 2017 6:43 am Post subject: Re: Why would someone have done this? |
Ha! I keep thinking of that scene in Herbie. Now put some “stress relief” in the roof and your all set. _________________ 1974 Ghia Coupe |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 791 Location: dallas, tx
Posted: Fri Dec 01, 2017 7:39 am Post subject: Re: Why would someone have done this? |
Yea, it an't purdy but I'd cover it up and move on... it might be useful further down the road (let's hope not). _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
Posted: Sat Dec 02, 2017 8:43 pm Post subject: Re: Why would someone have done this? |
kingkarmann wrote: |
MedievaL wrote: |
Yep, mine was just like that. |
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Mon Dec 04, 2017 3:40 pm Post subject: Re: Why would someone have done this? |
You found a drill? How did that get in there? |
