What went in this hole originally?
Metal Twister
Metal Twister is offline
PostPosted: Tue Nov 28, 2017 10:27 pm    Post subject: What went in this hole originally? Reply with quote
For the life of me i cant imagine what this hole is for... Help please?
Change is Opportunity!
Instagram=metaltwister
Semper_Dad
Semper_Dad is offline
PostPosted: Tue Nov 28, 2017 10:56 pm    Post subject: Re: What went in this hole originally? Reply with quote
Windshield washer reservoir
74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map:
http://bit.ly/1axDF1r
Gitm registared boys!
Officially, there are only 112 181s in the world
Metal Twister
PostPosted: Tue Nov 28, 2017 11:10 pm    Post subject: Re: What went in this hole originally? Reply with quote
Got it thanks. Are those the kind that uses the air in the spare tire to power the spray?
carsdlt
carsdlt is offline
PostPosted: Tue Nov 28, 2017 11:41 pm    Post subject: Re: What went in this hole originally? Reply with quote
Yup...
Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own."
Semper_Dad
PostPosted: Wed Nov 29, 2017 3:09 am    Post subject: Re: What went in this hole originally? Reply with quote
Yes however, I replaced the air valve in my wiper switch with a micro-switch and hooked up a electric pump. Worked great,.....for a while. Too much current for the switch. Lasted for about a year.
Plan B will be to replace the wiper switch back to original and use a accumulator tank since my spare tire is rack mounted on the back.
Metal Twister
PostPosted: Wed Nov 29, 2017 6:37 am    Post subject: Re: What went in this hole originally? Reply with quote
Same as a bug or Thing unique?
Semper_Dad
PostPosted: Wed Nov 29, 2017 7:25 am    Post subject: Re: What went in this hole originally? Reply with quote
Part number for the reservoir and cap start with a 311 so it's probably out of a Type 3. The tire to reservoir hose starts with a 411 so it's probably out of a type 4.
Metal Twister
PostPosted: Wed Nov 29, 2017 7:31 am    Post subject: Re: What went in this hole originally? Reply with quote
Got it thanks... Maybe i should just set it up with an after market electric assyembly if needed. Thanks again.
