rotorimp Samba Member
Joined: June 18, 2007 Posts: 253 Location: Surprise AZ
Posted: Wed Nov 29, 2017 6:24 am Post subject: 65 Sundial camper (Jarvis) |
We found a 65 Sundial in Colorado last summer and I'm finally ready to start the restoration. It is incredibly dry and complete for having spent more than a decade outside with just some primer on it.
It is special to me because I found it in the town I grew up in and it is my favorite bus color (velvet green). The only rust I have found is on the driver side door bottom. Otherwise more of the areas needing repair is from accident damage and a previous owner trying to fit some kind of radio and tearing up the dash.
I started on the rear because it seems to be the worst area, it will also get a new battery tray while I'm in there.
Looks like the driver's side is screaming for help....
My goal with the bus is a usable restoration that I can run a side business from (selling coffee). The primary objective is to get it back to its former camping status. I will be modifying bolt on items such as converting to front disk brakes, better gearing for the trans and a slight bump in HP so it can keep up with modern traffic. _________________ 1965 walkthrough Sundial |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1262 Location: Yulee FL
Posted: Thu Nov 30, 2017 10:27 am Post subject: Re: 65 Sundial camper (Jarvis) |
Damn nice bus to start with! |
Posted: Fri Dec 01, 2017 7:58 am Post subject: Re: 65 Sundial camper (Jarvis) |
Got the bus in the shop, ready to start the metal work. Most of the pieces should be here today!
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri Dec 01, 2017 9:21 am Post subject: Re: 65 Sundial camper (Jarvis) |
hopefully one of the parts is an actual bus exhaust so you can fix the cutout in the apron _________________ regards
Uli
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Fri Dec 01, 2017 12:41 pm Post subject: Re: 65 Sundial camper (Jarvis) |
It is so un-rusty, sheesh. |
Posted: Fri Dec 01, 2017 12:42 pm Post subject: Re: 65 Sundial camper (Jarvis) |
it does look sweet _________________ regards
Uli
Posted: Fri Dec 01, 2017 6:58 pm Post subject: Re: 65 Sundial camper (Jarvis) |
Yes, we are "fixing" the exhaust "mods"...
metal came in so...let the games begin....
Posted: Sun Dec 03, 2017 4:05 pm Post subject: Re: 65 Sundial camper (Jarvis) |
Got the engine out...seems to be a solid 1600 and I'll run it while I build another motor after I get it painted.
previous owner "fixes"
Rodentia residence
A little cleaner
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Sun Dec 03, 2017 4:14 pm Post subject: Re: 65 Sundial camper (Jarvis) |
WOW! _________________ Some people are so busy being clever they don't have time enough to be wise. |
HBCRUZR Samba Member
Joined: April 23, 2004 Posts: 603 Location: The center of TheRoddersJournal #45 sucka's!!!
Posted: Sun Dec 03, 2017 6:28 pm Post subject: Re: 65 Sundial camper (Jarvis) |
Looks good Jason! _________________ SBS #89 |
Posted: Wed Dec 06, 2017 6:51 am Post subject: Re: 65 Sundial camper (Jarvis) |
The last 50 years were not kind to the interior...it has to go. If it was westy stuff I would take measures to preserve it but the Sundial stuff is not very good quality or worth trying to save. Jarvis will continue to be a camper but with new stuff.
Small rodents had also taken up residence in the ceiling...
felt like I needed gloves and a mask the whole time.
better
Posted: Wed Dec 06, 2017 6:55 am Post subject: Re: 65 Sundial camper (Jarvis) |
Looks like someone tried to heat up the back of the chair to get it to recline more? wouldn't come off the tracks the metal was broken on both sides.....funny thing.... it was comfy to sit in.
Posted: Wed Dec 06, 2017 7:00 am Post subject: Re: 65 Sundial camper (Jarvis) |
Only a few bolts have needed heat to be persuaded off.
Doors are now off.
most of the glass too.
Maximillion Samba Member
Joined: August 07, 2016 Posts: 46 Location: Seattle, WA
Posted: Wed Dec 06, 2017 8:19 am Post subject: Re: 65 Sundial camper (Jarvis) |
Looks awesome! Have fun and that's a great idea to sell coffee - people are going to LOVE Jarvis. You'll have to figure out some kind of bus-themed cup design.
The metal around the rear right brake light looks disturbingly similar to my bus. If I didn't know any better I'd have thought it WAS my bus. (Also a '65!) |
Posted: Wed Dec 06, 2017 9:15 am Post subject: Re: 65 Sundial camper (Jarvis) |
Maximillion wrote: |
I guess backing up is hard for hippies LOL _________________ 1965 walkthrough Sundial |
Posted: Thu Dec 07, 2017 4:42 am Post subject: Re: 65 Sundial camper (Jarvis) |
Great progress! _________________ SBS #89 |
Posted: Tue Dec 12, 2017 8:01 am Post subject: Re: 65 Sundial camper (Jarvis) |
The rest of the bus is stripped, I can get to the metal work now.
There were no shortage of self-tapping screws between 1965 and now
4 billion to go.......
getting ready to fit the rear panel
Lots of bad bodywork to fix
Posted: Tue Dec 12, 2017 8:09 am Post subject: Re: 65 Sundial camper (Jarvis) |
The only real issue I had stripping the front apart was the pin on the emergency brake lever. The search button said that it was a very common problem and I should go straight to the saws all...worked great and now I have extracted the lever. On the plus side, there is a Samba member that sells a pin with a grease fitting so this will not be a problem in the future.
I had to put the lever in a 20ton press to finally get the pin free....
Posted: Fri Dec 15, 2017 7:24 am Post subject: Re: 65 Sundial camper (Jarvis) |
Got the bus media blasted, was very reasonable and will make getting it into paint much quicker. It was a wet. glass media that I chose so there was no chance of warping the metal. Took about 6 hours and I am still super stoked as to how rust free the bus is.
