Bobnotch Samba Member
Posted: Sat Jan 06, 2018 1:39 pm Post subject: Re: 1970 Automatic Fastback |
garrett.fell wrote: |
KTPhil wrote: |
Trunk light: Original style is NLA. ISPwest has a retro unit with a switch that looks pretty close.
Fuel pressure: The pump has a check valve in it to hold pressure; yours has failed. This can make it hard to start, and may require you to pulse the key on and off a few times before starting. This wears out the switch, though. Some add a secondary switch to run the pump before startup (see Jim Adney). Or you can rebuild your pump (also see Jim), or you can replace it with a Ford Ranger/Airtex pump, with a little plumbing change up front. |
Ah.....I have noticed that if I turn the key on and off a few times, this seems to help it start. Sometimes it'll crank and crank, then with a quick flip of the key on/off a couple times it starts right up!
I was under the impression that it has a new fuel pump installed in it. Maybe new just means "different one" - I dunno.....
I don't know exactly how quickly the pressure bled-down - for sure within the5 seconds it took me to get out of the seat, and to the rear of the car. |
Supposedly you're supposed to have a drop off down to 20 psi after 5 minutes, and then it should hold that 20 psi for at least a half an hour. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
garrett.fell Samba Member
Posted: Sat Jan 06, 2018 2:39 pm Post subject: Re: 1970 Automatic Fastback |
KTPhil wrote: |
This pump check valve you're speaking of. Does it look like a little round "disc" on the front beam? Or is this internal to the pump itself. I checked and the car does have a very new looking/clean pump installed in it.
I cannot find a reference to this in the Bentley. Is this it?
[/img] |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Sat Jan 06, 2018 3:05 pm Post subject: Re: 1970 Automatic Fastback |
That's the fuel pressure damper. Can you show us a picture of the pump? _________________ 71 Elm Green FI A/T Squareback |
Posted: Sat Jan 06, 2018 3:12 pm Post subject: Re: 1970 Automatic Fastback |
Donnie strickland wrote: |
That's the fuel pressure damper. Can you show us a picture of the pump? |
Yes - The pump looks like this!
Posted: Sun Jan 07, 2018 10:11 am Post subject: Re: 1970 Automatic Fastback |
You don't see any reference in Bentley for the check valve, because it's built into the pump.
The round disc shaped part is the fuel pump dampener. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KTPhil Samba Member
Posted: Sun Jan 07, 2018 12:13 pm Post subject: Re: 1970 Automatic Fastback |
The check valve is internal as posted. It's inside that shiny "top hat" sticking out of the pump sideways at the fuel line end. |
chicagovw Samba Member
Joined: January 06, 2007 Posts: 1424 Location: Chicago IL/CHandler AZ
Posted: Thu Jan 11, 2018 9:35 am Post subject: Re: 1970 Automatic Fastback |
As has been advised, I am planning to replace all of the fuel hose. I did some searching on the samba and there have been a multitude of threads on this subject, and there may not be a definite answer. First, the size seems to be about 5/16 from what I am reading. That is just under 8mm. Most supply houses that I find list the fuel hose at 7mm. If I wanted to stick with a German brand, would 7mm work, or is 8mm closer to the actual correct size?
ISP West and Bus Depot both offer German braided high pressure fuel hose, which I like because it will look original, but there seems to be mixed feelings on safety/quality/longevity. Any thoughts on this hose? |
Posted: Thu Jan 11, 2018 9:46 am Post subject: Re: 1970 Automatic Fastback |
I used 5/16 fuel injection hose from the auto parts store. It works perfectly.
Unless you're entering the car in a judged show, there's no need to worry about the appearance of the fuel lines. _________________ 71 Elm Green FI A/T Squareback |
Posted: Thu Jan 11, 2018 2:16 pm Post subject: Re: 1970 Automatic Fastback |
Unless you're entering the car in a judged show, there's no need to worry about the appearance of the fuel lines. |
Exactly. Same applies to the fuel pump.
When I plumbed my wife's car back in 2008, I used standard 5/16ths fuel hose. I replaced all of it at that time. I used a 25 foot roll of the stuff, along with 34 FI style hose clamps. I haven't noticed a problem with it yet, but I might take a good look once it warms up and dries out in a few months (it is almost 10 years old now). However, I also used an Airtex E2000 fuel pump on it, as the old Bosch pump was long gone. I moved the new pump to the center opening of the beam to get a nice lazy bend in the feed hose, due to the added length of the pump.
Keep in mind that a lot of the guys are now going to dedicated FI hose, due to the mix of fuels being available. Some of the cloth wrapped stuff isn't really compatible with the newer fuel blends. It's a little more expensive, but it does give a piece of mind that it'll last a while longer than standard fuel hose. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Jan 11, 2018 2:23 pm Post subject: Re: 1970 Automatic Fastback |
I am trying to make the car as correct as possible-I did spend the money and effort to get the correct type fuel pump, and would prefer the look of the original fuel hose material, but certainly if it is not safe I would prefer the modern stuff. |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Thu Jan 11, 2018 7:03 pm Post subject: Re: 1970 Automatic Fastback |
On my '67 Mercedes 230 I used 5/16" Gates Barricade hose and covered it with a nylon braided sleeve commonly used for wiring harnesses. It takes a little extra time, but the results look much better than having modern hose in a vintage car.
_________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
Posted: Fri Jan 12, 2018 8:25 am Post subject: Re: 1970 Automatic Fastback |
VWfreek61, that looks good and seems to give the best of both worlds-modern safety with vintage appearance. Do you know the size of that covering? |
Posted: Fri Jan 12, 2018 12:28 pm Post subject: Re: 1970 Automatic Fastback |
vwfreek61 wrote: |
That's a great solution for those who want their car to "appear" stock. You'd really only have to do the engine bay, as the rest is hiding under the car. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Jan 12, 2018 2:57 pm Post subject: Re: 1970 Automatic Fastback |
chicagovw wrote: |
I don't remember the exact size because it's been a couple years, but I think it was 1/2". _________________ Kenneth
dougefresh Samba Member
Joined: June 22, 2002 Posts: 74 Location: Lakeland, FL.
Posted: Fri Jan 12, 2018 6:47 pm Post subject: Re: 1970 Automatic Fastback |
I used this 5/16 hose from Amazon. cost $20 for 25 feet. Sure beats paying $3 a foot from the local auto parts store.
https://www.amazon.com/gp/product/B00UVNXJEU/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1 _________________ Doug
Lakeland, FL.
79 SB Conv
70 Fastback. Currently in elective surgery for BMW 2002 front brake calipers and Porsche 944 rears.
2001 Dodge Dakota, 273K miles. |
Posted: Sat Jan 13, 2018 11:29 am Post subject: Re: 1970 Automatic Fastback |
dougefresh wrote: |
https://www.amazon.com/gp/product/B00UVNXJEU/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1 |
Just so you know that's not FI rated hose, but it can be used on our cars as I mentioned above. On my wife's car, I used the 30R7 version of it, versus the 30R6. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Jun 02, 2018 7:55 am Post subject: Re: 1970 Automatic Fastback |
I am back at it - working on this fastback.
Last we messed with it it was running okay, not great, but since we replaced all the fuel lines and everything in the brake system we decided to take it for a ride (1/2 mile) to fill the tank up at a local gas station. It actually rode up there pretty good, but wouldn't start back up. It was flooding horribly. Finally did get it started back up once we towed it home and it sat for a few hours - it took a lot of cranking!
Anyway, since it was leaking oil from what I presume was the oil cooler, I pulled all the sheet-metal, replaced the cooler with a refurbished one and did the seals. Next step will be to try and troubleshoot all the FI stuff one by one and see what's working right and what isn't
So - what the hell is this thing? I can't find a reference to it anywhere. Not in the bentley, not on sites which sell FI stuff, etc...
It's obviously broken, both by site and I get no continuity through it when tested.
It was getting power from the coil attached through an in-line fused link.
Dfasty Samba Member
Joined: November 22, 2005 Posts: 528 Location: north bay,ca.
Posted: Sat Jun 02, 2018 10:36 am Post subject: Re: 1970 Automatic Fastback |
that was the kick down switch for the auto. _________________ 70 fastback automatic 06 invader |
Posted: Sat Jun 02, 2018 11:10 am Post subject: Re: 1970 Automatic Fastback |
Dfasty wrote: |
that was the kick down switch for the auto. |
Ah - Excellent. Thanks! |
