garrett.fell Samba Member
Posted: Mon Jun 04, 2018 4:51 pm Post subject: Re: 1970 Automatic Fastback |
Okay - update.....
I am getting power to the AAR when the car is running. I do get a little bit of resistance when I test the AAR. Right now the AAR is in the open state.
I got it started again today after MUCH cranking. It was flooded horribly and came to life very slowly as it blew the fuel out.
I had it running for a bit - stopped and started it a few times, but again when I let it run for a little while (and I guess get warmer?) I turned it off and was unable to get it started again...... Just lots of cranking and the smell of fuel.
What's going on here? |
Posted: Tue Jun 05, 2018 4:31 pm Post subject: Re: 1970 Automatic Fastback |
Man!!!
It seems like I just can't win with this thing. After last nights flooding episode I tried it again after work today and managed to get it started about an hour ago. *Very* slowly came to life after quite a bit of cranking and smoking......throttle wide open barely running for 20-30 seconds before it cleared up and started behaving normally. I did a couple quick stop and starts - not letting it run for very long between cycles.
So then I let it run for a good 10 minutes, set the ignition timing with a strobe and was generally pleased with myself and the way it was running. I had clamped-off the fuel hose that led to the CSV - it can't flood if there's no fuel - right? I didn't use a proper clamp with jaws that are completely parallel, but I did use a pair of long forceps - I am guessing It was effective, but not 100% sure.
Anyway - same damn thing. Running great - flip the key off and try to restart and get nothing! Just cranking and cranking with the smell of fuel.
It's gotta be these injectors right??? I couldn't see *one* leaky injector making it not start. Oil level looks okay, but it does smell like fuel a bit for sure.
Help please!
-Garrett |
Posted: Mon Jun 11, 2018 12:50 pm Post subject: Re: 1970 Automatic Fastback |
Update -
After a bunch of testing yesterday, we seem to have isolated the pressure loss issue. I am not sure if it's what's causing my hot-hard-start-flooding issue, but something is amiss there for sure. Earlier I had mentioned that the fuel system wouldn't hold pressure in general. It leaks down pretty quickly after shut-down and even when you flip the key to pressurize the system before you start it. When you start it - it takes a bit for pressure to build as well.
So - I took a cooling system pressure tester and used it to pressurize various components. I isolated the CSV, the fuel pressure regulator and the pressure-side of the brand spanking new high-dollar 3-port fuel pump and found....
* CSV is fine! It held 30 PSI no problem
* Regulator is fine! It holds pressure and you can hear it burp at pressures over 30.
* The check valve on the new pump seems to be leaking. It won't hold pressure!
Questions/Observations -
1. Is the check valve serviceable at all? It's under a little metal hat - can I remove this thing? I'd rather not break a $600 pump if I can help it.
2. I let the car idle for quite a while and ran it through numerous start-stop and restart cycles. It was behaving okay for maybe dozen of these - then started pulling it's old no-start tricks. Prior to this it would start up very quickly when cold. Even after it got warm it started pretty quickly, but not instantaneously like it did when totally cold. After it flooded I didn't continue to crank it. It started up this morning just fine.
3. Theory - do you think it's possible that the low pressure is causing the gas to not atomize correctly and this could be leading to the no-start flooding issue?
We did adjust the regulator slightly to about 29 pounds. It was running 31/32 previously.
Any ideas are welcome - this is super frustrating!
-Garrett |
KTPhil Samba Member
Posted: Mon Jun 11, 2018 2:12 pm Post subject: Re: 1970 Automatic Fastback |
Jim Adney rebuilds the new style pumps, and has some tooling he made to do it right. He may quote you a price to rebuild just the check valve.
At low pressure, the injector will inject, but the spray pattern and droplet size will be poor. When I first got my fastback on the road after years of storage, the pressure was 24. It was hard to start, ran crappy once it did, and smelled rich, even though the poor fuel atomization meant it was lean from imperfect combustion. I adjusted the pressure back up to 28 and it ran dramatically better. I'm not sure it would flood the engine, though. |
chicagovw Samba Member
Joined: January 06, 2007 Posts: 1424 Location: Chicago IL/CHandler AZ
Posted: Mon Jun 11, 2018 4:17 pm Post subject: Re: 1970 Automatic Fastback |
I am the owner of this Fastback and as Garrett mentioned, we ran some tests yesterday. The pump that is on the car was rebuilt by Blodgett's Automotive, and I am not sure if they are related to Jim Adney. There definitely seems to be an issue with the check valve, as it would not hold 30psi - the drop was immediate. The car did indeed start and restart multiple times, even after we let it warm up for considerable time. Until it didn't. |
KTPhil Samba Member
Posted: Mon Jun 11, 2018 4:28 pm Post subject: Re: 1970 Automatic Fastback |
No relationship. Some "rebuilds" do not touch the check valve. Jim takes the metal "tophat" off, and refits a better-than-OEM part inside, then covers it back up properly. There is some finesse required and he's experienced. Jim's words from another thread:
Quote: |
There is a small rubber nipple in the pressure relief valve that is starting to go bad in all these pumps by now, so I've rebuilt quite a few of them, more than 50. When that rubber part fails, it disintegrates, and the motor will still run but no pressure is generated. I replace that rubber part with a Teflon part that I make.
I'm not sure of his current pricing. You can contact him at:
[email protected]
...or through this Samba ad:
https://www.thesamba.com/vw/classifieds/detail.php?id=1821211
You can see the rubber nipple in the third photo of the ad, at the far left, along with the spring and ball.
He stands behind his work. He is probably getting ready to head to the Type 3 Invasion in 'Bama this week so he may take a bit to get back to you. |
Bobnotch Samba Member
Posted: Thu Jun 14, 2018 9:41 am Post subject: Re: 1970 Automatic Fastback |
Yup, that little valve IS what causes most of us to go to the Ford Ranger style pump. I've had 3 go bad, and even 1 of Jim's fail after a rebuild, and yes he did make it right, but by then I'd already swapped it to the ford style pump. I gave it back to him (at an Invasion), so it could be used by someone else or someone doing a concourse resto.
I only say that about the built in check valve, as it has a 2nd function, in that it's what actually builds flow from the pump. When it goes bad, you can't build any pressure at all. When the valve goes bad, it just recirculates fuel in the pump. This is really a misleading problem, as most people WILL hear the pump run, but not check the pressure.
Ask Ray Greenwood (he's here in this forum sometimes, but spends most of his time in the type 4 forum) what he thinks about the stock Bosch pump, since the type 4 (411/412) use the same pump. He'll tell you real world stuff and info you won't get anywhere else.
The Airtex E2000 pump and the Precision E16020 pumps don't have a built in check valve, but they do build fuel pressure quickly, which eliminates the warm start issue. A check valve from McMaster Carr could eliminate the problem with the ford style pump IF it becomes a problem. I haven't had that issue with one.
I like using the ford style pump, because I can get a new one almost anywhere in the USA for less than a 100 bucks. They're available at the Zone, NAPA, Advanced, CarQuest too if you have one, and O'Reilly's. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Jun 18, 2018 7:36 am Post subject: Re: 1970 Automatic Fastback |
Okay - so we’ve made the decision to do the fuel pump conversion to see if that fixes the hot start issue. Mike picked up the “Precision” pump from O’Relies over the weekend. It’s not installled yet. A couple questions / observations
1. The pump seems to have an internal check valve. I pressurized the output port with a cooling system tester pump and noted that it holds 30 PSI just fine.
2. What do you all do for the fuel line connections? These ports are NOT barbed and although I’ve seen some pictures with people just clamping them to the smooth ports - that just didn’t seem right. Seems like you’re asking for trouble doing that. I tried picking up a “Dorman” quick release connector with 5/16 barbed connection on one end and it couldn’t get it to “click” and grab the step on the steel port. What kind of connector should be used here? Even if you could get the connector on - I don’t see how you could insert one of those release collar tools on the line after to remove the connector if you wanted to. There would be no room because you’re up against the pump body at that point. What say ye?
I tried one of these.
https://www.dormanproducts.com/p-24796-800-120.aspx
I was also having a hard time finding a replacement for the screw-on fitting on one end of the pump. It’s not an NPT fitting - it’s straight thread like 3/8 24 if
I remember correctly.
I’d love to be able to find a 5/16 barbed one for that end to save on the overall length - but have not been able to locate one. |
Posted: Tue Jun 19, 2018 8:28 am Post subject: Re: 1970 Automatic Fastback |
garrett.fell wrote: |
Here's a thread for installing the E2000, or E16020 ford style pump.
https://www.thesamba.com/vw/forum/viewtopic.php?t=488576
It includes wiring help as well as plumbing help.
I hope it helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Jun 29, 2018 9:02 am Post subject: Re: 1970 Automatic Fastback |
Okay - another update.
I made the switch to the Ford-style "Precision" fuel pump. The fuel system now properly holds pressure. Previously it would bleed down to 0 within a few seconds.
So, I started the car let it run a little here and there for less than a minute each time...started and stopped it a few times only to find that......
The problem is still there!!! Now I can't get it to start again. Ugh... It seems to be the same thing. I suspect It's flooding again since I can smell gas. I should be able to get it started tomorrow after things dry out a bit.
Any ideas here? Please... this is driving me nuts. |
Posted: Fri Jun 29, 2018 10:39 am Post subject: Re: 1970 Automatic Fastback |
Nope, no ideas. Since it's now holding pressure, that means the injectors are basically sealed (not leaking). But, I'm wondering if they are correct for your system. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Jun 29, 2018 10:48 am Post subject: Re: 1970 Automatic Fastback |
Bobnotch wrote: |
Nope, no ideas. Since it's now holding pressure, that means the injectors are basically sealed (not leaking). But, I'm wondering if they are correct for your system. |
That's pretty much the same thing I was thinking - I don't know exactly what kind of injectors are installed in it. They were installed by a mechanic who had the car before me last fall/winter. I think getting a known injector installed will be the next-step.
The system seems to be holding pressure well - maybe dropped a pound in the last 2 hours. |
Posted: Fri Jun 29, 2018 11:08 am Post subject: Re: 1970 Automatic Fastback |
Bobnotch wrote: |
Sounds like the system is holding well then.
You are getting good spark right?
Have you tried holding your foot to the floor to get it to "warm" start? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Jun 29, 2018 11:17 am Post subject: Re: 1970 Automatic Fastback |
Bobnotch wrote: |
Bobnotch wrote: |
Have you tried holding your foot to the floor to get it to "warm" start? |
I'll admit, I have not validated how "good" the spark is, or not. I guess I could just pull a spark plug boot, and hold it near a good ground and watch for a spark jump, yes? I've got an old Sun coil tester from the 40's/50's but I've never used it. It might work - it's more garage decoration at this point, but it may very well be functional.
Right now, It will not warm start with throttle all the way open - it just cranks and cranks and cranks - and smells like gas.
Tomorrow if I go out and start it - it'll either start right up, or it will take a bit of cranking with it slowly coming back to life after it spits all the fuel out.
-Garrett |
Posted: Sat Jun 30, 2018 8:44 am Post subject: Re: 1970 Automatic Fastback |
I may be on to something here with the ignition system. I tested the coil and found that the spark is very-very weak.
I tested with an OHM meter and found the following
* On the coil between + and - I get 3.6 ohms
* On the coil between HT and either + or - i get 8.8K
* All spark plug wires test out at between 1.0K and 1.1K
* The HT wire that goes from between the coil and center cap tests out at 5k which seems a little odd. Could this be the issue?
I've got a new blue coil coming from Amazon today (Bosch 00012)
I took a little video of the coil spark test here. The spark is barely there.
https://youtu.be/vkhcsxT-Wvs |
Posted: Thu Jul 05, 2018 10:59 am Post subject: Re: 1970 Automatic Fastback |
Well DAMN - That wasn't it either. I was hoping I was on to something.
I have not been able to get the car restarted since it died last-time which was post-fuel pump install. It ran a few times quite nicely on the new fuel pump, but after one particular shut-down it has since refused to start again.
I replaced the coil the other day, and the spark plugs with NGK 4210's today - the plugs I removed did look rather fouled so I was hoping that was it. Nope....
I bench-tested both coils with a 12v jumpstart pack and both seem to give similar results. They will spark a plug, but I would have expected a much hotter/fatter spark than what I am seeing.
I did get it to "kick" a few times the other night after a bunch of cranking, but the car refused to come to life. I am currently left here scratching my head - clueless.
Can anyone help me with ideas on what could be wrong? I never hit a wall with one of these things before and I am afraid I am about there.
-Garrett |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Jul 05, 2018 11:25 am Post subject: Re: 1970 Automatic Fastback |
That spark doesn't look all that bad to me. Are the coils you are using Bosch Blue made in Mexico? If so, consider it defective and get a Brazilian one. If it's not defective now it will be.
How's the battery charge and charging system?
The other thought I have is that your MAP sensor may very well have a cracked diaphragm. Got another one to try?
Forgive me if this has been covered already... I'm just jumping in with both feet. Wait... SHARKS, you say?
Check posts 2 and 4 in this world famous thread for some troubleshooting info you may find useful.
https://www.thesamba.com/vw/forum/viewtopic.php?t=514048&start=0 _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Jul 05, 2018 12:16 pm Post subject: Re: 1970 Automatic Fastback |
Tram wrote: |
https://www.thesamba.com/vw/forum/viewtopic.php?t=514048&start=0 |
Looks like I got lucky and the coil is Brazilian! The battery is of unknown condition - it seems to crank the car over pretty well, but I am unsure what kind of voltage it puts out under load. I've been hooking the battery up to my ctek charger after i abuse it. I did notice earlier today (after cranking) I did have sub-12 volts at the coil. It was in the mid 11's if I recall correctly.
I may hook a jump-pack up in line and see if that makes a difference.
Looks like last time I cranked it earlier today, post plug replacement, I didn't hook power up to the coil - so nothing was gonna happen there. It's wired back-up now with power to the coil when the ignition is on. I am sure it's flooded per usual now.
Charging system is in unknown condition at this time as well. I've lost many of the lights on the dash as of a few months ago. They were all working fine (with the exception of turn signals - another story) at one point, but one day just decided to quit. Now the only light I get is the generator light when I turn the ignition on.
Oh - I do not have another MAP sensor to try. |
raygreenwood Samba Member
Posted: Thu Jul 05, 2018 12:57 pm Post subject: Re: 1970 Automatic Fastback |
If you are truly getting spark.....and actually injecting fuel....and no longer losing fuel pressure.....it should fire up unless you are grossly rich or lean...or no longer actually injecting.....or possibly way off in initial timing or have no advance (even then it should fire up)
What have you done to check injection signal function?
Bear in mind that there should not be any injection typically when you bump the key and buzz the pump. But...if you stroke the gas pedal with the key on and engine not running....the injectors will each inject once for each segment the wiper arms pass over in the TVS.
If you have fuel pressure...and have spark...know you have it....and have basically correct timing....know for a fact that you have it.....and it does not seem to run....check all of the ground wire bundles on the case centerline...check the state of ground of the TS-2 (cylinder head temp sensor) and teh connection to this sensor......and check the three pin plug to the trigger points. For that matter if you have not done so...remove teh trigger points, clean them, check resistance and check their function with a volt meter by turning the rotor through 360 with the probe hooked up. Ray |
Posted: Thu Jul 05, 2018 1:32 pm Post subject: Re: 1970 Automatic Fastback |
raygreenwood wrote: |
Okay....
Q - What have you done to check injection signal function?
A - Nothing recently. Several weeks ago when I has the injectors out I put them in a glass jar and did note that they will give a little splash of gas in pairs when the key is flipped. I can smell fuel when I crank, and it's spitting black liquid junk out of the tailpipe.
Q - If you have fuel pressure...and have spark...know you have it....and have basically correct timing....know for a fact that you have it.....and it does not seem to run....check all of the ground wire bundles on the case centerline...check the state of ground of the TS-2 (cylinder head temp sensor) and teh connection to this sensor......and check the three pin plug to the trigger points. For that matter if you have not done so...remove teh trigger points, clean them, check resistance and check their function with a volt meter by turning the rotor through 360 with the probe hooked up. Ray
One by one....
1. If you have fuel pressure. Yes! Gauge is still hooked up and reads 29 PSI. It will hold pressure for days at a time now
2. have spark. Yes! I just validated this by hooking a spark plug (admittedly it was a different wire, different plug) up to one of the posts on the cap, grounding it out, and watching the spark at the plug.
3. basically correct timing. Yes! I set timing with a strobe dead-on when it was running a few weeks ago.
4. check all of the ground wire bundles on the case centerline. Yes! Visual inspection shows a bunch of stuff there. Looks tight.
5. Check the state of ground of the TS-2 (cylinder head temp sensor) and teh connection to this sensor. I am a little confused on this one. The cylinder head temp sensor has just one wire coming out of it. This goes to some sort of what I would guess is some sort of (fat-red) resistor thing, then it goes to a plastic plug and then it connects to the wiring harness.
6. Check the three pin plug to the trigger points. I disconnected and reconnected this. Seems tight. The function of this is to "pulse" the fuel once per revolution right? Would this keep it from starting, or just from running?
This is so crazy because as of recently it would start up just fine, and run and run and run and run until I shut it down.....sometimes. Now it just refuses to start at all |
