jayinduluth Samba Member
Joined: August 16, 2012 Posts: 122 Location: Southern California via Duluth, MN
Posted: Wed Nov 29, 2017 5:26 pm Post subject: Throttle body pic - idle issues |
Does this look bad? Would someone recommend taking it off and cleaning up the gunk/buildup?
I'm having idle issues where I have the idle set high because when I would put van into gear, it would die/stall. Now the problem I have is that occasionally, it will die at a stop light or stop and go traffic. I had the injectors recently serviced by mr injector.
85 westy with a supposedly 91 2.1 engine, I say supposedly because I'm not exactly sure how to verify that as there a number of items that appear to be 1.9 related.
Thanks> _________________ 85 Westy with 91 2.1L |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4765 Location: Bemidji, MN
Posted: Wed Nov 29, 2017 5:47 pm Post subject: Re: Throttle body pic - idle issues |
these vans are antiques and so my opinion is that whenever you disassemble something, you clean and refurb as much as possible.
the throttle body will now unscrew with 2 phillips screws and your one screw i can see looks nice and not rusted! yes, clean the gunk out. there's been a fair amount of crankcase blowby schmuking up the throttle body, so it may portend to more severe things. but we're worriers here.
show a picture of then entire engine bay and we can tell you if it is a 2.1 or 1.9, at least in terms of the entire engine.
-dan
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9797 Location: Mt Lemmon, AZ
Posted: Wed Nov 29, 2017 6:16 pm Post subject: Re: Throttle body pic - idle issues |
Note that you will very likely want to use a new gasket when you reinstall it -- the gasket is a particular design, not something you can cut out of gasket material. |
Posted: Wed Nov 29, 2017 6:46 pm Post subject: Re: Throttle body pic - idle issues |
Thanks for the responses, I have at least 5 relatives who graduated from Bemidji St, including my dad and one of my brothers.
Here is a pic from a few years ago, I can take a better one tomorrow if need be.
I have a new throttle body gasket from van cafe, so I'm good there. _________________ 85 Westy with 91 2.1L |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7753 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Nov 29, 2017 6:53 pm Post subject: Re: Throttle body pic - idle issues |
That ^^^ has all the symptoms of a classic 1.9... Just sayin'...
Anyway, you're on the right track...DEFINITELY clean it up, dude...
FWIW: Best things I've done to help my idle has been clean all grounds (including @ ECU), replace vacuum
hoses, PLUS clean -or- replace all FI connections (injectors, relays, ICV, ICU, alternator power, etc...)
Git 'r done!
- Dave "Haav"
<<<Proud BHS Lumberjack AND BSU Beaver!>>> _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
westina Samba Member
Joined: October 01, 2017 Posts: 368 Location: Beacon/NY
Posted: Thu Nov 30, 2017 5:36 am Post subject: Re: Throttle body pic - idle issues |
Just did mine. Engine degreaser and an old toothbrush is your friend. Be gentle. |
Posted: Fri Dec 01, 2017 8:04 am Post subject: Re: Throttle body pic - idle issues |
cleaned up throttle body, hopefully will get it back in today.
In other news, I've seen this plug since I've gotten the van -
I've peeled off most of the corroded cover stuff. Could never figure out where it went to. Well after I pulled the throttle body off, I saw where it went.
Is this plug for something for a 2.1? _________________ 85 Westy with 91 2.1L |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3794 Location: VA/TN
Posted: Fri Dec 01, 2017 8:20 am Post subject: Re: Throttle body pic - idle issues |
I think that's an unhelpful diagnostic port. I have mine on my alternator. And for what its worth it looks like you have a 1.9l engine. Mine looks similar. _________________ Brandon
Instagram @joannthevan |
Posted: Fri Dec 01, 2017 8:25 am Post subject: Re: Throttle body pic - idle issues |
and CHANGE YOUR FUEL LINES before we read about you!!! looks awful original to me. they get so brittle they'll snap in two if you bend the ends together.
-dan |
Posted: Fri Dec 01, 2017 8:39 am Post subject: Re: Throttle body pic - idle issues |
Yep that engine pic is from 2011, fuel lines have been changed since then! _________________ 85 Westy with 91 2.1L |
