Drzdirtbag Samba Member
Joined: September 27, 2014 Posts: 80 Location: Kamloops bc
Posted: Thu Nov 30, 2017 7:08 pm Post subject: Saved a 1959 beetle.. Farm find, resto project.. |
I'm the lucky new owner of a 1959 beetle.. My first beetle.. Just started the teardown.. I will be counting on you guys for lots of help with this build!!!!
Danwvw Samba Member
Posted: Thu Nov 30, 2017 7:12 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
Looks like the original 36 horse engine are you going to restore it and keep the care original? The 58 is kind of my dream car. It's not a more valuable oval window from the 57 year but it's still the crash box and the 36 horse. I must say as far as an original crash box trans goes. They aren't too good as daily drivers. But the 36 horse on the other hand makes a really great town car. So If the trans is shot, not to big deal. Help - late transmission into '57 Oval. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Thu Nov 30, 2017 7:19 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
Wow looks like a great car to start with. Nice find. Take lots of pictures as you take things apart, and be thorough when labeling stuff. Even stuff you think you wouldn't forget, you'll forget.
Keep us in photos, we'll keep you in advice! |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Thu Nov 30, 2017 7:22 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
looks amazingly solid, don't throw away any parts, alot of the new stuff is crap compared to the real deal, good luck! _________________ If you can't join them, beat them! |
Posted: Thu Nov 30, 2017 8:33 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
Thanks guys.. I'm super stoked to bring her back to life.. I want to keep her as stock as possible.. The engine is super seized.. Soaking the cylinders now, and will try to free it up first before I tear it down.. It would be nice to try and get a bit more power out of the stock block.. But I'm aways off from there..
About to start to pull the body from the chassis and see how it is..
Did I mention how stoked I am on this!!!
Thanks fellas.. Randy.. |
Posted: Thu Nov 30, 2017 8:55 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
Man that car just screams restoration, but if you do swap engines or the like, keep the original parts, and don't do anything that can't be undone.
As stated, restore original parts if at all possible. Most of the aftermarket stuff is just garbage. |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Jim Hunter Samba Member
Joined: February 14, 2014 Posts: 107 Location: MB, Slovenjia
Posted: Fri Dec 01, 2017 2:40 am Post subject: Re: Saved a 1958 beetle.. Farm find |
Wow ! What a great save!
Also looks like a standard model (lack of side carpet and 100% standard model steering wheel)
Good luck! |
kinkerstinker Samba Member
Posted: Fri Dec 01, 2017 6:21 am Post subject: Re: Saved a 1958 beetle.. Farm find |
This thing would look KILLER just with new chrome and buffed paint. This is what dreams are made of. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Fri Dec 01, 2017 7:08 am Post subject: Re: Saved a 1958 beetle.. Farm find |
Step back and have the long term plan....skip the painting and get the vehicle systems fully functioning and then drive it as is. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
consvws Samba Member
Joined: April 07, 2009 Posts: 949 Location: Roseburg, OR
Posted: Fri Dec 01, 2017 10:18 am Post subject: Re: Saved a 1958 beetle.. Farm find |
very cool car! I have been fixing up a '58 canadian std. for a while now & was wondering about where to get door panels. Looks like they had the 58-59 colors, but just all one solid color on yours. |
mikec4193 Samba Member
Joined: July 15, 2014 Posts: 287 Location: Mechanicville NY (Upstate)
Posted: Fri Dec 01, 2017 10:51 am Post subject: Re: Saved a 1958 beetle.. Farm find |
Very cool find right there...hope you have fun rebuilding it...looks ok for it's age too..yeah dont worry about the outside...start on the bottom and work your way up...
my 2 cents...
MikeC _________________ Dad bought his first Beetle on Dec 17, 1953. |
Danwvw Samba Member
Posted: Fri Dec 01, 2017 2:46 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
Drzdirtbag wrote: |
The engine is super seized.. Soaking the cylinders now, and will try to free it up first before I tear it down.. It would be nice to try and get a bit more power out of the stock block.. Randy.. |
So you should not try to turn the engine over with a wrench or anything like that. If it is seized at the crank it could ruin the case. Probably is the cylinders though. Yes soak them then remove them with a soft rubber mallet when your get the heads off. You will be throwing the Piston and cylinders away anyway likely. Be careful not to break the fins on the heads. Never hammer with the soft mallet on the head fins. Yes hit heads at the studs to loosen. 36Horse engines are becoming rare and all the small parts are very important to save. People do get more power out of the 36 horse engine but it's expensive. There are dual port heads and manifolds that allow for running dual carbs and the 36 Horse engine has available for it larger than the old stock 77mm bore pistons and cylinders you can run. Also you can run a special 69.5mm stroke crankshaft and I think a 74mm one.
Best way to have a powerful bug is to just build up a 1971-1974 dual Port 1600 engine into a larger engine and either use Dual Weber IDF, IDA carbs or Fuel injection or some nice used Dellorto carbs. It is possible to with a Dual Port 71 or later beetle engine to make over one hundred horsepower for about what it would cost to rebuild the 36 horse with the 36 dp heads and stroker crank etc.. and maybe wind up with 70 Horsepower.
txoval's 36 horse: Twin Webers on a 36 hp engine.
I think these are 36mm Dells:
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Fri Dec 01, 2017 11:18 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
Gt1953.. I totally agree.. That's my plan. Concentrate on the mechanical side and not get too carried away with the body for now.. I just want to drive and enjoy it asap.. |
Posted: Fri Dec 01, 2017 11:24 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
Danwvw.. Thanks for the info.. I don't think I'll get to carried away with the engine.. I do want to keep her fairly stock.. Funds are kinda limited for now.. I appreciate the tips...
Cheers, randy.. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Sat Dec 02, 2017 7:09 am Post subject: Re: Saved a 1958 beetle.. Farm find |
If your funds allow, you can throw in a 69.5mm crank and Okrasa or other cam and still run the stock manifold with a 30mm carb. It would provide significant torque increase.
Here’s the best pic of my engine...new linkage. 36 IDF’s...I wish they were Dells
veedubfreak59 Samba Member
Joined: February 22, 2010 Posts: 228 Location: Denver, CO
Posted: Sat Dec 02, 2017 7:35 am Post subject: Re: Saved a 1958 beetle.. Farm find |
Always good to see people saving old girls. This is how mine looked when I pulled it out of the field.
Good luck with it, just know, that you'll likely never recover the amount of time and money you put it in it. But thats half the reason you save these silly cars.
If you have the room, just set the OG engine asside and drop in a built motor. You'll never really get enough power out of the old lawnmower to make it worth building. My 36horse is currently residing in storage back in texas. |
Posted: Sat Dec 02, 2017 1:41 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
veedubfreak59 wrote: |
just set the OG engine asside and drop in a built motor. You'll never really get enough power out of the old lawnmower to make it worth building. |
It would be well worth rebuilding it, especially if you don't have money for a "built motor" laying around. I daily drive a 36hp beetle & really enjoy doing it.
Enjoy the car, and get it running & driving as is before you start modifying things. You might like the 36hp more than you'd think |
boxkiteflyer Samba Member
Joined: May 22, 2008 Posts: 261 Location: Taylorsville, KY
Posted: Sat Dec 02, 2017 2:37 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
+1 what everybody is saying about taking it apart. Nice find! original 36hp and tranny is very drivable. |
pbenn Samba Member
Joined: November 21, 2007 Posts: 375 Location: Toronto
Posted: Sun Dec 03, 2017 2:31 pm Post subject: Re: Saved a 1958 beetle.. Farm find |
Drzdirtbag wrote: |
Slow down a little, maybe. Takes some planning. Car space, a cart or rotisserie with good dollies, a plan of action to avoid distortion.
There's lots of great builds in the forums, both in 58-67 and Body/paint, posts of body-offs, but generally you brace your door openings side to side and across the car, mig welding angled stock, joined by turnbuckles for any adjustments.
Before you lift it. Plus you'll want to media blast, which takes planning. Compressor noise, disposal, etc.
I wish I had your project. But short of a body-off, if it was me, I'd be media blasting the roof flanges and window openings windows-out, just to halt whatever might be going on with the patina rust. Lose patina, but gain peace of mind.
But I guess you don't want to paint it. What about a brush-on rust converter? |
