NoDents Samba Member
Posted: Thu Nov 30, 2017 9:47 pm Post subject: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
I've been trying to figure out if there are supposed to be rubber grommets that surround the fluid lines as they pass through the body on their way to the master cylinder. See diagram for the location in question:
Are there supposed to be grommets here? I can't seem to find them referred to in any part documentation, yet it appears there should be.
Have a part number????
Thanks |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 792 Location: dallas, tx
Posted: Fri Dec 01, 2017 7:14 am Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
for the brake line/hose to pass thru the body down to the master? on my '74 there is. if i remember, it's about 1.5-2" long x .75" in height and has 3 holes.
zero help in where to get one tho. _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Fri Dec 01, 2017 8:25 am Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
Quote: |
where to get one tho |
Harbor Freight has an assortment collection of grommets. It has those and even wiper arm grommets in the 'mix'. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
PolarBearVW Samba Member
Posted: Fri Dec 01, 2017 10:28 am Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
_________________ 1974 Ghia Coupe |
Posted: Fri Dec 01, 2017 1:27 pm Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
Yes, that is what I'm looking for.
Anyone have a clue on where to get one or have the Part number? |
c21darrel Samba Member
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Sat Dec 02, 2017 5:51 am Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
c21darrel wrote: |
If you are not doing a concourse restoration....just find grommets that fit. Harbor freight, home depot, amazon.... |
Better yet, remove the fluid reservoir from the trunk area and get the appropriate retrofit reservoir and plug it straight into the master cylinder. |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Mon Dec 11, 2017 7:50 am Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
70 140 wrote: |
c21darrel wrote: |
Do you have a picture of what you are suggesting? It sounds like a good idea, but would be interesting to see and find out what type of reservoir to mount at the Master Cylinder. Thanks. _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Mon Dec 11, 2017 10:38 am Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
rbsurfguy wrote: |
70 140 wrote: |
c21darrel wrote: |
Do you have a picture of what you are suggesting? It sounds like a good idea, but would be interesting to see and find out what type of reservoir to mount at the Master Cylinder. Thanks. |
Old volvo brakes were supplied by ATE as well.
But you can get them from CIP and others now. |
Posted: Mon Dec 11, 2017 2:01 pm Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
I positioned mine with the cap to the rear.
Posted: Mon Dec 11, 2017 4:45 pm Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
Gee guys, thanks for revealing this little gem...Nice idea and cleans up the trunk area without having that residual brake oil leaking everywhere!! Outstanding!
Just need to know how it is mounted there, using a special connector or does it more or less drop in place??? _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Posted: Mon Dec 11, 2017 6:09 pm Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
Quote: |
using a special connector or does it more or less drop in place |
Uses the same rubber grommets that come with the MC. The 'ends' of the new reservoir fit right in. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
70 140 Samba Member
Posted: Mon Dec 11, 2017 6:36 pm Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
Sorry. I didn't give a very detailedf reply. Glad the others posted some photos. It's a great option for getting the brake fluid out of the trunk and cleaning up the perpetual corrosion associated with it.
An older Volvo 240 reservoir will typically plug right into the m/c using the existing rubber plugs that the hose ends mounted with. Also, this CIP part looks to be a similar replica and also references a part# for new rubber grommets:
https://www.cip1.ca/ProductDetails.asp?ProductCode=VWC%2D113%2D611%2D301%2DDCC |
Posted: Sat May 16, 2020 5:42 pm Post subject: Re: 1971 Ghia Brake Fluid Reservoir Line Grommets? |
Reviving this thread after more than 2 years.....
I'm to the point of final assembly on my 71 Vert. I did find some grommets that fit: Part Number: 111-971-9112
Purchased a year ago at Hot VW Drag Day swap meet.
They fit perfectly. _________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
