jootman Samba Member
Posted: Fri Dec 01, 2017 11:55 pm Post subject: What do I have? Diff-lock? (62 split bus) |
Hi all,
My name is Joost from the Netherlands, I bought this bus a couple of months ago off thesamba and have since been busy getting it on the road again
Here is the result so far
Last week I passed technic check and I got it registered to hit the Dutch and Belgium roads
I want to make it suitable for light offroading so I put a 9000lb winch in front, made custom bumpers (not sure about them because they limit ground clearance)
Also I bought a gearbox with some kind of locking differential, and I wondered if anyone has seen something like this?
On left side of the gearbox 2cables stick out, when I pull them some kind of differential lock seems to be activated. (both wheels spin at the same time)
I made a bug handbrake in front to activate them.
Can anyone tell me something more about this system? I have not tested it offroad, only in my garage. It seems to work. When I start the bus with one wheel jacked up , both wheels start spinning.
This week I will lift the bus some more by putting a 'cut and turn' early bay front axle and respline the rear.
about lifting the rear: I have seen the dropped gearbox idea on several theads on this site. I like the idea but this is a future plan for me. For now I just want to respline it, can anyone tell me how far I can go without breaking things? I am afraid I put the axles in a strange angle when I lift it too much.
Thanks for the input! |
Danwvw Samba Member
Posted: Sat Dec 02, 2017 12:04 am Post subject: Re: What do I have? Diff-lock? (62 split bus) |
I have never seen a locking one before Thanks for showing us. Hot VW magazine last year had an article on the angle axles go and what to do about it. I will look for it. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
oldschool5er Samba Member
Posted: Sat Dec 02, 2017 9:53 am Post subject: Re: What do I have? Diff-lock? (62 split bus) |
I have rebuilt lots of ZF swingaxle limited slips but I have never seen a factory installed manual locker on a tunnel Trans. Very interesting. If you ever pull it apart please post some pictures on it. I used to get containers of trans cores from Europe back in the early 80's but even then I never saw one of these. Might be a Kubelwagen trans installed in it. I guess I never thought about researching this but will now. Thanks for posting. |
Danwvw Samba Member
Posted: Sat Dec 02, 2017 11:20 am Post subject: Re: What do I have? Diff-lock? (62 split bus) |
The Hot VW Magazine TECH article "Swingaxle Low-Down" was published in the March issue 2017 By Bruce Simurda.
It shows a photo of a man holding an I phone that has a level app for measuring the angle from level something is. It shows the technician turning the axle and holding at it at the angle where he starts to feel it bind when turned through the full 360' degrees. The axle they had showed if the axle was angled more than 11.6' degrees from straight it started to bind.
According to Hot VW there is no modification that can be done to a swing axle to help this.
I know there are ways to put an IRS axle into an early bus. My bay window vw bus uses a Bus transaxle that is IRS and it's CV joints are compatible with 22' degree or something like that CV Joints available for the Porsche 944 and the VW Things.
Brian Samba Moderator
Posted: Sat Dec 02, 2017 12:04 pm Post subject: Re: What do I have? Diff-lock? (62 split bus) |
I would love to see a tear down on it as well.
But that's rad, I love seeing some good offroad buses. They'll take you pretty damn far. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Sun Dec 03, 2017 1:17 am Post subject: Re: What do I have? Diff-lock? (62 split bus) |
Thanks for the info on the axles.
converting to IRS is no option yet, First I want to try the locking diff. I hope it will hold up, if not I will open it, I am very curious too!
I am waiting on new ball joints for the earlybay front axle, when finished I will take it offroad and post my findings! |
dustymojave Samba Member
Posted: Mon Dec 04, 2017 8:46 pm Post subject: Re: What do I have? Diff-lock? (62 split bus) |
Have you already swapped the front axle for a ball joint bay window axle? Or are you planning to swap it soon?
The bay window axle will not bolt into a split window bus.
For offroad use, I would rather use the original split window linkpin front axle than the bay window ball joint for much the same reasons that link pin is preferred in offroad Bugs. Also swapping to ball joint will require different brakes and wheels. _________________ Richard
SoCalBajas Member
Posted: Tue Dec 05, 2017 4:27 am Post subject: Re: What do I have? Diff-lock? (62 split bus) |
yes this fits, it's allready under.
wheels also will fit on early bay beam.
now waiting for new ball joints to be pushed in by a friend.
I hope to put it on it's wheels tonight
motor and tranny also out to do the transmission drop.
I will post some pictures tomorrow |
Posted: Thu Dec 07, 2017 9:01 am Post subject: Re: What do I have? Diff-lock? (62 split bus) |
hi Here are some pictures of the transmission drop
Raises the bus significant.
I trimmed the cradle so I won't lose bottom clearance. I boxed and reinforced the cradle with 4mm steel.
I put the jack under the new cradle to test the strength. If it can hold up 1100kilograms, it will be fine holding the 100kilogram engine
In previous post you see the diff lock cables, I made them from bicycle brake cable. This felt too weak. Now I took a type2 clutch cable and e-brake cable (needed two different lenght outer cables)
seems to work fine now.
Engine back in, I can put bug air filter
engine sits lower so I had to make the engine tin higher.
Tomorrow I will move on to the front of the bus.
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Dec 07, 2017 9:18 am Post subject: Re: What do I have? Diff-lock? (62 split bus) |
That is quite the modified muffler. Did that come with the bus or did you make it? Looks like a power robber... |
Posted: Thu Dec 07, 2017 9:24 am Post subject: Re: What do I have? Diff-lock? (62 split bus) |
Bashr52 wrote: |
It was a bug muffler. It was too loud to my opinion so I put a bus pipe to it and welded the other hole. Buses have mufflers like this. I notice no loss of power.
I know it could have been done better but no one will see when the bumper is in place |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 977 Location: Las Vegas, NV
Posted: Thu Dec 07, 2017 4:32 pm Post subject: Re: What do I have? Diff-lock? (62 split bus) |
So you were able to drop the trans for lift without losing ground clearance? That is neat. I want to see some Dutch split bus off roading. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
