58 antenna question
veedubfreak59
veedubfreak59 is offline
PostPosted: Sat Dec 02, 2017 7:45 am    Post subject: 58 antenna question Reply with quote
Whats going on here? Which holes do i need to weld up. Why are there 3 holes here.
Sharp64
Sharp64 is offline
PostPosted: Sat Dec 02, 2017 8:21 am    Post subject: Re: 58 antenna question Reply with quote
Grab your attenae, figure out which holes work and weld up what’s not needed. Antennas were dealer options so there isn’t truly a rule as to what or even where they are. A PO probably slapped on whatever they found at their FLAPS back in the day and rather than trying to use the old holes drilled new ones.
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
mukluk
mukluk is offline
PostPosted: Sat Dec 02, 2017 10:16 am    Post subject: Re: 58 antenna question Reply with quote
Looks to me like the car had a two post antenna installed, once in the vertical position and once at an angle following the A pillar rake.
panicman
panicman is offline
PostPosted: Sat Dec 02, 2017 1:13 pm    Post subject: Re: 58 antenna question Reply with quote
As mukluk states- someone had a 2-post antenna as pictured. If you are sticking with an antenna, then choose if you want vertical or raked to align with the A pillar. Or weld them all if you want to use a radio delete. Here is a vertical mounted antenna:
Plate of shrimp
my59
my59 is offline
PostPosted: Sat Dec 02, 2017 2:39 pm    Post subject: Re: 58 antenna question Reply with quote
In Feb 59 the dealer put a two post vertical on mine, with a Motorola am radio.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
Q-Dog
Q-Dog is offline
PostPosted: Sat Dec 02, 2017 2:50 pm    Post subject: Re: 58 antenna question Reply with quote
Do it however it feels good to you.
(stolen from the gallery)
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
