bluebus86 Banned
Posted: Mon Dec 04, 2017 2:08 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
yes, drain the reservoir, drain its tubing, to avoid brake fluid spills. wear rubber gloves, and safety glasses. this stuff is nasty, it eats automotive paint, dont get it on you, dont get glove prints of it on the paint. wash off immediatly with water is gets on paint, hose off the underside area when done also incase some dripped out during removal. I started wearing the glasses for this when while bleeding a burp of it got in my eye, burned instantly, ran so fast to the garden hose, flushing it out for 10 minutes or so, did care how wet of cold I got, it is lkke a hot iron burn, still burned like crazy, went to doctor, doctor flushed it more, still burned. it eventually got better, but boy did it burn.
the switch is the brake light switch, pressure operated. it has a tapered pipe thread, so dont over tighten it, as it will not stop by bottoming out, it will strip if over tightened, tighten enough to not leak, but not much more. The switch body is soft aluminum, strips easy.
Telfon pipe tape is sometimes used, but it aint factory, and can be an problem as it may fool a person too overtighten as it is so slick., and of course torn bits of tape could clog passages. assemble dry is fine, no tape should be needed. dont use any plumbers dope or sealers on the threads, you dont want risk of contamination in the system.
loosen all the flare nut fittings first (you got that flare nut wrench, correct?)
(I believe its an 11 mm, but you need to double check that) use of a regular open wrench on the flare nuts, if they are a bit stuck will ruin the flare nut.
see link....
https://www.google.com/search?q=flare+nut+wrench+vw+bug
dont forget the brake grease on all the other fitting, threads push rod etc. Brake compatible grease only is to be used here! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Dec 04, 2017 3:27 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
onetuza wrote: |
I ordered everything from the reservois to the MC. |
Hmmm - maybe a good time to replace the four flexible brake lines too ??? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
onetuza Samba Member
Joined: June 20, 2012 Posts: 579 Location: Sebastian, FL
Posted: Mon Dec 04, 2017 5:09 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
Pulled the line out of the MC grommet and drained the reservoir through a small hose into a bottle. Undid the reservoir strap and wiggled the whole thing out in one piece.
Multiple bends in the line. I believe the new one comes straight, so I think I can borrow a brake line bending tool from a friend and have some fun trying to match the shape of the old one.
TBC _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Not screaming, like the other passengers in his car! |
Posted: Wed Dec 06, 2017 7:13 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
Parts due by end of day tomorrow.
So far, so good.
Removed drivers seat and steering wheel. I’ve got a two tone leather cover on it and the white leather was getting worn so I cleaned and died it. Looks great.
Removed brake switch and cleaned it up. Just slightly loosened the two MC bolts. Had some trouble with the three connections at the MC. Got the nuts to move but the lines were moving with them. More Kroil and some PB blaster and got two of them free. Put more PB on the third and quit for the night.
Posted: Thu Dec 07, 2017 9:24 am Post subject: Re: Mysterious Massive Brake Fluid Leak |
Cusser wrote: |
onetuza wrote: |
Hmmm - maybe a good time to replace the four flexible brake lines too ??? |
Thanks, replaced them last year. _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Posted: Thu Dec 07, 2017 9:40 am Post subject: Re: Mysterious Massive Brake Fluid Leak |
bluebus86 wrote: |
The 11mm line wrench proved very illusive. Most APS's carry one with 10mm on one end and 12mm on the other, but, Eureka! O'Reilly's had it.
One of the three nuts is still turning the brake line with it. Hit it with more penetrating oil last night and quit. Hopefully tonight is a win.
While I'm here, another picky question in anticipation. When you push the metal supply line into the rubber stopper, do you push it part way, or do you push it all the way till the flared end of it pops out of the inner face of the stopper? _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
bluebus86 Banned
Posted: Thu Dec 07, 2017 11:53 am Post subject: Re: Mysterious Massive Brake Fluid Leak |
onetuza wrote: |
bluebus86 wrote: |
The 11mm line wrench proved very illusive. Most APS's 7carry one with 10mm on one end and 12mm on the other, but, Eureka! O'Reilly's had it.
While I'm here, another picky question in anticipation. When you push the metal supply line into the rubber stopper, do you push it part way, or do you push it all the way till the flared end of it pops out of the inner face of the stopper? |
I believe it goes all the way thru, (no, I am certain it goes all the way thru) but it works going in best if you first install the rubber bit on the master, then put the pipe in the rubber bit. use brake grease. if you install pipe in the rubber bit, then try to install the rubber bit with pipe into the master, you will have to fight it not fitting.
Good Luck, Bug On, Now Stop It with Conconfidence!!!!!
PS use that brake grease for reassembly of the pipes and on the flare nuts, get grease between the pipe and the nut, this will help avoid future rust and problems of the pipe stuck to the flare nut. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Cusser Samba Member
Posted: Thu Dec 07, 2017 12:29 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
onetuza wrote: |
Gawd - it's been years since I've done that. And last year in its resurrection I bought an entire new Brazilian master cylinder for my 1970, it had those installed already.
Maybe I can find the MC I removed from my 1970 last year, definitely would not have disposed of it, especially because I remember (at least in the past) that there was more than one type of plastic elbow.
I haven't done an early-model MC in decades, but so don't know what those elbows look like, but here's what the elbows look like for a late-model MC, they seat (at the top) until flush.
Posted: Thu Dec 07, 2017 1:40 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
Here’s mine.
Posted: Thu Dec 07, 2017 4:49 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
Well I’m screwed now! I thought I was home free. Got the other nut loosened. loosened two of them all the way out then started on the other one and it was a little tight and the freaking brake line busted and wouldn’t you know it is the one that goes all the way through the car to the back. Not sure what I’m gonna do now. I guess remove the MC and then figure it out. _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
KTPhil Samba Member
Posted: Thu Dec 07, 2017 5:14 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
Yeah, it's a job, but one tip is to make it in two sections, with a union under the rear seat. Easier to bend and feed two shorter sections, then join them. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Dec 07, 2017 5:24 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
The premade-to-the-correct-length brake line most aircooled VW shops sell is quite inexpensive and the job to replace it is really quite simple. Remove the driver seat and get busy ... it only looks intimidating.
Just be gentle with the new line so you don't kink it. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Cusser Samba Member
Posted: Thu Dec 07, 2017 6:08 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
SwageLok metric union to join the existing old metal line to a new piece of line? We used SwageLok in the chemistry lab, considered the best; even sealed hydrogen lines with SwageLok connections. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Dec 07, 2017 7:29 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
A friend came up with a possible fix by cutting off the line a few inches from the firewall and putting in a new fitting and flaring it if I can get a small enough flare tool to fit in the confined space. Then take a new piece of line, 2 new fittings, flare both ends, then bend as needed and put together, i.e., create a union there.
My car is pretty much a show car and I don’t like the idea of pulling up the carpet to access the line. Also the t-block in the rear and it’s fittings are prob 52 years old and full of crud and I’d probably fubar something there.
If this doesn’t work, then I may have it towed to my mechanic. Tempted to have him replace all the hard lines but $$$ and between Xmas and birthdays for three kids, we’ll you get the idea. _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Posted: Thu Dec 07, 2017 9:11 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
Upon closer examination of the little piece of line that broke off with the fitting, I don’t think I would have ever gotten it off. It’s rusted together pretty badly. I will probably have to drill it out, but I’ve got it submerged in Kroil right now. Hope to reuse it with a new length of flared pipe joined to the old with a brass compression union. Whadaya think? _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Cusser Samba Member
Posted: Fri Dec 08, 2017 6:50 am Post subject: Re: Mysterious Massive Brake Fluid Leak |
onetuza wrote: |
Hope to reuse it with a new length of flared pipe joined to the old with a brass compression union. Whadaya think? |
Isn't the line metric ??
I already suggested a SwageLok union, a well-designed tubing connector, and available in steel/stainless steel to match your steel brake line, and in metric sizes.
I sure wouldn't use a hardware store non-metric union !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Q-Dog Samba Member
I don't like couplings under carpet, even if they are done correctly, because leaks are hard to see. And a big NO to the compression fitting idea. It's the brakes ... do it right. _________________ Brian
'69 Dune Buggy
'70 Beetle |
Posted: Fri Dec 08, 2017 7:06 am Post subject: Re: Mysterious Massive Brake Fluid Leak |
Checked swagelok and didn’t see a size small enough. Maybe I missed it?
Not proposing the union in the cabin, but rather next to the MC.
Was hoping for a temporary fix so I can drive the car to my mechanic thirty-something miles away and maybe have him redo all the hard lines. _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
KTPhil Samba Member
Posted: Fri Dec 08, 2017 10:04 am Post subject: Re: Mysterious Massive Brake Fluid Leak |
A friend did the 2-piece thing and put the union just under the back seat. Others have done this after struggling with the 1-piece. Is there a trick to making the 1-piece work? rear first, front first, bend in the middle and then re-straighten, or what? |
Posted: Fri Dec 08, 2017 10:53 am Post subject: Re: Mysterious Massive Brake Fluid Leak |
OK, I'm set to try using a union with flares and if that doesn't work, I go to a temporary compression fitting.
Rented a small metric flare tool from AutoZone. Looks like it may be small enough to work in the confined space. Tomorrow will tell.
Bought both a compression fitting and a union with flare nuts.
