scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
onetuza Samba Member
Joined: June 20, 2012 Posts: 579 Location: Sebastian, FL
Posted: Sun Dec 10, 2017 4:04 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
Be that as it may, I completed the fix and tested it at 15 psi before bleeding.
SOAB! Nothing leaking but the friggin stopper and a dribble from the new reservoir hose where the hard line comes out of it. They don’t have the braided hose any more. It’s smooth rubber. Gunna try a clamp on that one, but the stopper has been a recurring problem through the years. Seams like a really inadequate design. Why not have another flare fitting like all the other’s?
Is the supply line supposed to have a flared end? Picture on WW doesn’t show one. But my old one dad one. Re-used it but it’s a little rough so I’m going to try to bend up a new one.
Anyway, anyone have similar problems and found a fix? _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Not screaming, like the other passengers in his car! |
Posted: Sun Dec 10, 2017 4:48 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
OK I think I just realized something. I’m using one of those bottles that you pump up and pressure bleed through the reservoir cap, so I think I’m pressurizing something that isn’t normally under pressure during braking. Am I correct. _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Sun Dec 10, 2017 4:51 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
Yes.
Use clamps on the non pressurized side of the res.. That way you don't blow off the supply lines to the MC. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Dec 10, 2017 7:37 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
onetuza wrote: |
OK I think I just realized something. I’m using one of those bottles that you pump up and pressure bleed through the reservoir cap, so I think I’m pressurizing something that isn’t normally under pressure during braking. Am I correct. |
Correct.. there is nothing but head pressure from the reservoir on those lines.. you could pretty much call it 0 PSI. Clamp the lines if you want, or just leave it alone if they aren't leaking static. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
boxkiteflyer Samba Member
Joined: May 22, 2008 Posts: 261 Location: Taylorsville, KY
Posted: Sun Dec 10, 2017 9:02 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
onetuza wrote: |
Well I’m screwed now! I thought I was home free. Got the other nut loosened. loosened two of them all the way out then started on the other one and it was a little tight and the freaking brake line busted and wouldn’t you know it is the one that goes all the way through the car to the back. Not sure what I’m gonna do now. I guess remove the MC and then figure it out. |
My '59's brake lines were rotten and some broke while trying to remove the flared end from slave cylinders, etc. so I just replaced them all. It was a bit of work but these should last at least a hundred years because I'm using silicone brake fluid. Ya just gotta be able to stop!
Glad you are able to get things done! |
nvrgvupjw Samba Member
Posted: Fri Jan 12, 2018 3:06 pm Post subject: Re: Mysterious Massive Brake Fluid Leak |
onetuza wrote: |
Because I'm doing similar brake stuff on my '63, I just found these older posts. $.02 worth below.
NEVER use compression fittings in a brake system! Flares in a brake system must be the double-flare type.
When the fitting was rusted to the line, I have used a torch to break the rust bond. It can take several tries of heating/cooling. Be careful and have your extinguisher nearby.
I have never had to bench bleed a master cylinder in some 50 years of doing brake stuff. On every vehicle I've worked on, the master was mounted higher then the rest of the system. This allows most of the air to rise up through the master and out of the vented cap. However, the rest of the system must still bled as previously described.
Be safe. |
