saw2 Samba Member
Joined: November 06, 2008 Posts: 321 Location: nw Oregon
Posted: Wed Sep 19, 2018 9:18 pm Post subject: Re: First stroker build 92X82 |
67rust, glad to hear you’re getting ready to fire up and break in lifters. Going to be a little bit of a tough wait till next spring or who knows when with our weather. I went for a cruise today knowing I’m not going to drive a street buggy that much longer around here. I am a dry weather driver only I’ll get a day here and there. Actually the cool fall dry days are some of my favorite days for cruising.
Anyway, glad you are getting it sorted out. |
Xevin Samba Member
Posted: Wed Sep 19, 2018 9:51 pm Post subject: Re: First stroker build 92X82 |
Well shoot. Guess I’ll have to wait and hear this engine at Averys next year About.......the same time I get Xatie’s finished _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Thu Sep 20, 2018 1:39 am Post subject: Re: First stroker build 92X82 |
Awesome brother. Even though you've had some issues, you're learning. Looking forward to next spring and summer myself. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9663 Location: Oregon
Posted: Fri Sep 21, 2018 10:59 pm Post subject: Re: First stroker build 92X82 |
So I did a lot of maintenance on my 67 today. And after that I had some time on my hands to get things moving forward on the 2180.
I straightened out the push rod tube ends and installed new seals. Also applied some Permatex sealant to the PR seals before seating them into the case and heads. Just a thin coat to keep oil in check.
I know that I'll get some heat for doing this. But this is a sealing method that a well respected air craft mechanic recommends.
This was followed up with installing the heads. Before I set the rocker box head washers on the studs. I applied some Curil T to the mating surface of the washers. I did this in a very thin coat using a craft paint brush from the Dollar store.
When I apply Curil T. I wear a disposable glove and squeeze the sealant to the glove like an artist would do on a pallet.
I then applied the head nuts and torqued them sequentially and incrementally. Sorry no pic of the procedure.
The clean up of the Curil T from the brush is done using IPA in a discarded tomato sauce can.
I know this is pretty boring stuff here. But someone wanted pics.
I swear that the #2 piston never had any combustion on the first build. It just shows no sign of carbon on the piston top like the #1 does.
Funny pic. The modern Blue Rocket in the background. Rarely gets driven. The little ZenithBlau beetle is the preferred mode of transportation.
There will be more progress tomorrow after I recheck the head torque.
And yes pics too. _________________ I have learned over the years.
Buy Once, Cry Once!
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
jpaull Samba Member
Joined: February 22, 2005 Posts: 3456 Location: Paradise, Ca
Posted: Fri Sep 21, 2018 11:39 pm Post subject: Re: First stroker build 92X82 |
Glad its moving along!
I used to use aviation on the pushrod seals also. It works, but the only thing I dont like is the aviation does harden in spots and makes cleanup a pain later. I use Curil T now on almost everything including the pushrod seals.(thin coat like how you did). The only place I like the aviation better is on the oil pump cover as the aviation holds the high pressure oil inside abit better then Curil when not using a gasket. |
Posted: Sat Sep 22, 2018 3:58 am Post subject: Re: First stroker build 92X82 |
vince1 wrote: |
Nice to see this build moving. Did you check pushrods vs tubes clearance ? You might be in trouble with your Scat rockers and stock pushrod tubes. |
No carbon on number 2. That would make me.stop and wonder why. There should be carbon
..even a tiny bit. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Sat Sep 22, 2018 4:15 am Post subject: Re: First stroker build 92X82 |
fivelugshortaxle wrote: |
vince1 wrote: |
..even a tiny bit. |
That was the one with the valve guide issue from the first set of heads.
Thanks for asking. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sat Sep 22, 2018 4:20 am Post subject: Re: First stroker build 92X82 |
jpaull wrote: |
On the first go around of the build. I had used Curil T on the push rod tube seals.
They leaked a little. So I thought I's give the aviation sealant a try this time around. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sat Sep 22, 2018 4:25 am Post subject: Re: First stroker build 92X82 |
vince1 wrote: |
I have not checked the clearance yet. The push rod tubes are "windage" tubes.
I guess I'll find out today when I cut the push rods and install them.
Thanks for the heads up. _________________ I have learned over the years.
Buy Once, Cry Once!
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9880 Location: Huntington Beach, CA
Posted: Sun Sep 23, 2018 7:49 pm Post subject: Re: First stroker build 92X82 |
Looking good! I am getting excited again!
FWIW. I only use 30wt oil on the push rod tube seals. They get a light rub of oil. When I install them, they go in and I rotate them. Have not had a leaky one in decades.
Vrooom, vrooom!!!!! _________________ Jimbo
TDCTDI wrote: |
Posted: Mon Sep 24, 2018 5:16 pm Post subject: Re: First stroker build 92X82 |
VW_Jimbo wrote: |
Vrooom, vrooom!!!!! |
Actually on the first build of this engine. Was the first time I have tried using any sealant on the PR tube seals.
Is the past I have always installed them dry and had little issues. I thought the Curil T would work. But I had leaks on the case ends. So I decided to try the aviation sealer.
Time will tell if it works or not.
Thanks for the input. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Mon Sep 24, 2018 5:23 pm Post subject: Re: First stroker build 92X82 |
VW_Jimbo wrote: |
Thanks for the input. |
You are welcome. I got to try a few different methods through the years. Curil T, silicon, Indian shellac, Gasgacinch, aviation something or other. The list is long and familiar. Bottom line was 30 wt oil worked the best. Rotated a little while installing the head, seams always up on top.
As always, wishing you the best! _________________ Jimbo
TDCTDI wrote: |
Posted: Mon Sep 24, 2018 5:24 pm Post subject: Re: First stroker build 92X82 |
I promised pics of the rocker geo. But my dial indicator mag stand had stripped threads. So I had to get a replacement.
"0" lift
Half lift
Full lift
This is after sanding 0.060" off the bottom of the rocker blocks.
If someone see's something out of place. Please let me know.
I need to shim the side play on the rockers. The extra shims that came with the rockers are a bit thick. So I ordered a shim kit from AC.net yesterday.
Thank you all again your your valuable input. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Mon Sep 24, 2018 7:31 pm Post subject: Re: First stroker build 92X82 |
I always do this to motivate me to complete the build. Yea it's not even close to being complete yet. But it gets the juices flowing.
Have a great night! _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Mon Sep 24, 2018 8:08 pm Post subject: Re: First stroker build 92X82 |
Thats a bueatiful thing! _________________ Jimbo
TDCTDI wrote: |
Posted: Mon Sep 24, 2018 8:38 pm Post subject: Re: First stroker build 92X82 |
VW_Jimbo wrote: |
Thats a bueatiful thing! |
It's getting there Bro.
I'm waiting on the rocker shims to get the side play sorted.
Once that's set it's just a matter of finishing the ancillary goodies to get it finished.
I'm running an electric FP this time around too.
I have seriously began considering fuel injection lately.
I'm just not that technically advanced to understand all the in's and out's of going that way.
But it just sounds so much more linear on the tune up.
I mean, what's another 3K at a build?
Thank you for your support! _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Mon Sep 24, 2018 10:35 pm Post subject: Re: First stroker build 92X82 |
Your welcome, bu honestly it is just cool to watch someone put their heart into something. So, thank you!
Fuel injection is no walk in the park. Be careful what you wish for. Just take your time. It is worth it!
On the electric fuel pump. Get a relay in the circuit that shuts it off when it no longer sees a signal from the coil. Last thing you want in an accident is fuel being dispense with sparks! _________________ Jimbo
TDCTDI wrote: |
Posted: Tue Sep 25, 2018 1:32 am Post subject: Re: First stroker build 92X82 |
Sorry to hijack brother...here's that 57 oval euro I just picked up. The semaphores work.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Tue Sep 25, 2018 4:24 am Post subject: Re: First stroker build 92X82 |
VW_Jimbo wrote: |
On the electric fuel pump. Get a relay in the circuit that shuts it off when it no longer sees a signal from the coil. Last thing you want in an accident is fuel being dispense with sparks! |
The relay is already installed. Works great. Turn the key to the run position, the pump runs for three seconds. Then it shuts off. Unless there's rpm detected.
Thanks for the advice. _________________ I have learned over the years.
Buy Once, Cry Once!
