Jashley1965 Samba Member
Joined: May 15, 2013 Posts: 8 Location: Cape giradeau, MO
Posted: Mon Dec 04, 2017 2:21 pm Post subject: Problems with ignition! |
So i purchased my very first bus after owning a couple bugs and boy are they way more work. I am having problems with power staying on after the key is taken out of the ignition. I then went and unplugged the ignition to check it and power is still staying on.
I would love to know if someone could help me out.
Bus is a 78 riviera with the 2.0L in it.
Thanks! |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Mon Dec 04, 2017 2:30 pm Post subject: Re: Problems with ignition! |
What do you mean by “power is staying on?”
Is the bus still running after you turn the key off and remove it?
Or, is the power to the accessories (ie, radio, interior lights) staying on?
If it’s the accessories maybe you have a second fuse panel that runs directly off the battery or a second battery if your bus has one. I am planning this on my next bus. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Mon Dec 04, 2017 2:33 pm Post subject: Re: Problems with ignition! |
So you recently purchased the bus and it's always had this problem since you bought it?
When you say power stays on with the key removed... does that mean things like your dash lights and stereo remain powered or the engine will not shut down?
Best to be careful. I understand that an alternator can be damaged if you remove the battery cable with the engine running. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Mon Dec 04, 2017 2:38 pm Post subject: Re: Problems with ignition! |
So it has been having this problem since bought it. Power to the dash lights and and and all accessories are staying on after the key is out. |
Posted: Mon Dec 04, 2017 2:40 pm Post subject: Re: Problems with ignition! |
No second battery or fuse panels. I have to put a fuse from the power cord to the fuse box to get all accessories to power off. |
Posted: Mon Dec 04, 2017 2:43 pm Post subject: Re: Problems with ignition! |
I'd start by getting a wiring diagram and looking at where the big power feed wire from the back on the bus is hooked up to. I think it's solid red. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon Dec 04, 2017 2:54 pm Post subject: Re: Problems with ignition! |
I would guess that a PO plugged some of the wires into the wrong spots on the fuse box. |
