bob cook Samba Member
Posted: Wed Dec 06, 2017 11:03 pm Post subject: PVC for support |
i was thinking of fiberglassing 1/2" pvc pipe in a area I;m fixing see any thing wrong with this |
oprn Samba Member
Joined: November 13, 2016 Posts: 12701 Location: Western Canada
Posted: Thu Dec 07, 2017 5:36 am Post subject: Re: PVC FOR SUPPORT |
A little short on detail... |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Dec 07, 2017 7:38 am Post subject: Re: PVC FOR SUPPORT |
"in a area" leaves a lot of space for the imagination to wander....
Posted: Thu Dec 07, 2017 8:55 am Post subject: Re: PVC FOR SUPPORT |
in front of the gas tank was damaged I'm repairing that area where the fibrglass rolls over on the very front I thought I might put a peice of 1/2 pvc for a more ridge lip |
slalombuggy Samba Member
Posted: Thu Dec 07, 2017 9:04 am Post subject: Re: PVC FOR SUPPORT |
Scuff up the PVC before you lay it in to give the resin a surface to adhere to, and make sure the 'glass goes all the way around the tube. It's the tube that the 'glass forms that will make the structure, not the PVC itself as it is flexible compared to the finished 'glass
brad |
oprn Samba Member
Posted: Thu Dec 07, 2017 8:58 pm Post subject: Re: PVC for support |
I wonder if the difference in temperature related expansion will be a problem? PVC expands a lot more than fiberglass.
Just a thought... |
wythac Samba Member
Posted: Fri Dec 08, 2017 6:52 pm Post subject: Re: PVC for support |
Bob, you might want to look at this thread and see if using a metal support doesn't work better for you:
https://www.thesamba.com/vw/forum/viewtopic.php?t=510484&highlight=headlight+supports
I'm not recommending you glass it in if you used metal. Not sure though that supporting and strengthening that area with PVC would be significantly stronger than original construction without also tying it in to the front beam. |
Posted: Fri Dec 08, 2017 7:30 pm Post subject: Re: PVC for support |
I will make supports off the beam for support thanks |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Fri Dec 08, 2017 10:40 pm Post subject: Re: PVC for support |
That's usually done with steel
