markeaton Samba Member
Joined: July 09, 2013 Posts: 686 Location: Seacoast NH
Posted: Thu Dec 07, 2017 11:04 am Post subject: Who sells gas tanks with filler at the top center of the tank |
Hello-
I am looking for a new gas tank to fit into my dune buggy restore (1974 bug).
It's a fiberglass body. The one that was in there when i bought it was cut at the spout; weld closed; and reopened to meet in the center of the hood.
I do not want to do that as it occasionally leaked. Aside from making a new cut in the fiberglass to accommodate a side filler, does anyone sell new modified tanks?
Thank you,
Mark |
Dale M. Samba Member
Posted: Thu Dec 07, 2017 11:40 am Post subject: Re: Who sells gas tanks with filler at the top center of the tank |
Probably nobody..... My solution was to buy new tank, mark, cut, drill etc, and have welder acquaintance weld it all in place....
Posted: Thu Dec 07, 2017 12:54 pm Post subject: Re: Who sells gas tanks with filler at the top center of the tank |
Thanks Dale. I think you are correct that nobody sells them. I've been looking.
I do work for a company that has welders and we can do an occasional "government" job and one of our guys would surely do it for me.
I also thought of keeping the tank as is, simply making a cut in the hood wherever the fill spout lands; and then put an emblem or some kind of cover over the existing hole in the fiberglass.
Thanks again. |
Manxdude Samba Member
Joined: November 02, 2002 Posts: 258 Location: The peach state
Meco Samba Member
Joined: January 09, 2009 Posts: 148 Location: Chula Vista, CA
Posted: Fri Dec 08, 2017 11:11 am Post subject: Re: Who sells gas tanks with filler at the top center of the tank |
Interesting idea on the Bolt-On Gas Tank Filler Neck Kit.... I'd would then still need to weld the open neck area.... Any clue on how connect a sending unit? |
Posted: Fri Dec 08, 2017 12:01 pm Post subject: Re: Who sells gas tanks with filler at the top center of the tank |
Put reserve valve under tank like early bugs...
joescoolcustoms Samba Member
Posted: Fri Dec 08, 2017 1:04 pm Post subject: Re: Who sells gas tanks with filler at the top center of the tank |
Those bolt on filler necks are a cool idea. But you miss out on a lot of tank volume that way. In a buggy, the tank is on more of a slope than that of a Beetle, so it traps air up higher. If you want the most use of your tank, get a welding shop to weld a neck either center top or like Dale showed, P-Side top.
It goes without saying, a used tank has to be cleaned to weld on it safely. Advantage to the bolt on filler neck in that instance. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Gary0302 Samba Member
Joined: August 29, 2007 Posts: 596 Location: Coastal NC
Posted: Fri Dec 08, 2017 2:22 pm Post subject: Re: Who sells gas tanks with filler at the top center of the tank |
Hi Mark,
If you decide to go the route of purchasing an aftermarket tank for modification, you may want to also inspect the bottom threaded attachment where the fuel line attaches. Years ago, I bought a gas tank from texasbuggies.com, and after installation I noticed a small gas leak.
Since you may end up modifying a tank anyway, I figure what the heck, run a bead of brazing around the lower attachment if you have any doubts about it.
_________________ Gary David Holbrook
Facebook and YouTube
Coastal North Carolina
Check out my videos on Youtube
"It's a buggy not a space shuttle...." - Dale M.
"When in doubt, blame it on the previous owner" - Gary0302 |
Posted: Sat Dec 09, 2017 8:32 am Post subject: Re: Who sells gas tanks with filler at the top center of the tank |
Good advice Gary... thank you. |
EVfun Samba Member
Posted: Sat Dec 09, 2017 1:18 pm Post subject: Re: Who sells gas tanks with filler at the top center of the tank |
markeaton wrote: |
Dale M. wrote: |
Put reserve valve under tank like early bugs... |
That is how my first buggy was set up, only it was a piece of the original filler neck from an early '60 Bug tank welded onto the flat spot where the gauge sender used to be. The tank only held around 9 gallons and the reserve as only about 0.8 gallon because of the angle of the tank. That bolt on filler and a late tank with a short section of hose and a cap to plug the rear fuel inlet would be no welding solution. _________________
Wildthings wrote: |
