RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Fri Dec 08, 2017 3:31 pm Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Just checked with CB Performance, no luck there....
Guess it maybe carb upsize time. Any ideas on Vent Peeps out there? That
is if it is feasable.
Engine really begins to run out of Breath around 5,200 rpms. RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Dec 08, 2017 3:49 pm Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Alstrup wrote: |
esde wrote: |
If identical carbs (idf and dells) were tuned correctly, I don't think anyone could tell what brand they were driving from the drivers seat. |
But you can hear it.
T |
Yes, with Dellortos you immediately get 20-30 birdpower. _________________ modok wrote:
Posted: Sat Dec 09, 2017 7:40 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Ok, been looking around for 36 vents for my 40 DRLA's, No Luck yet...
So in a previous post on the thread it is said that the IDF's are inferor to DRLA's.
Do I have this correct for Street Use? So the DRLA's have a few more HP as well? RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
esde Samba Member
Posted: Sat Dec 09, 2017 8:09 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Like Modok said, there are many models of IDF, so making an accurate IDF to DRLA comparison is not easy. Somewhere here (just searched but didn't find it) he listed some of the models and variations. I recall reading there were differences in top bore/bottom bore/ stock venturi size, number of progression ports. So, just specifying a size might not get you an apples to apples comparison.
I replaces some weber 40's with the old style roller accelerator pump with freshly rebuilt dellorto 40's, and the owner couldn't tell the difference. But, he's also the sort of guy to drive a mile before realizing he has a flat tire. But they're at least close enough to fool someone thats not paying attention. _________________ modok wrote:
Posted: Sat Dec 09, 2017 9:39 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Thing is like I hit on previously. That there are the New Empi D's on the Mkt., plus there are some reputable people out there to get used DRLA's from. They just costs...
See what I heard and noticed on two cars is that the Webers had what I thought were spikes in there RPM Transioning. Meaning as you excellerated slowley, the DRLA's were steady while the IDF's had spikes and you had to inticipate that if you were driving technical roads... Basically saying the DRLA's are a "Safer" carb for Type 1's for Street Use for they do not "Crack In" as you throttled slowely were as the IDF's did some.. But one car was a New Single Carbed 2110 w/Redline Intake and the other was a 6 cylinder Porsche, so I really don't think these cars are a good bases for me to draw on for info other than that... RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
modok Samba Member
Posted: Sat Dec 09, 2017 3:13 pm Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Sorry I'm not saying much but I swear.....we already discussed this 2-3 years ago.
36 idf, 44idf, 48 idf, 40idf-78-83 web-orto, ALL the DRLA carbs, IMO they can ALL work GREAT on the right engine. As good as port fuel injection.
I don't like the weber 40 IDF-70 model as much, so I leave that off the list, but it's better than a solex The 40HPMX is improved, but not as good as he web-orto yet.
44idf and 48 idf has divorced idle circuit, these are better suited to more radical engines with radical cams and more radical heads, but if you get the combo right they will accelerate up from idle at any throttle position with no hiccups at all. By"right combo" I mean the heads with the right flow ratios, not overly large exhaust.
They aren't as suited to getting the best MPG or driving on snow/ice.....but if they are on a radical engine combo .....you would not be expecting them to be super good at that ANYWAY.
36mm vents could work, but look at the aux vents in the larger models of dellorto and think about how you could modify your full circle aux vents to flow more. The ID of the full circle ones is only about 38mm, not enough
Posted: Sat Dec 09, 2017 4:10 pm Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Ok Modok with the analysis, you are saying if I have this right from memory that on a X & Y graph, the Linear Curve of the powerband is the same with them all if on a Vertical access is RPM and on the Horizontal Access of the graph is HP? So in fact they all perform the same? That is if my graph that I wish I could make and show right now... RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
modok Samba Member
Posted: Sat Dec 09, 2017 4:41 pm Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
The carburetor does not make the powerband, it just sprays fuel.
If you use the right carburetor for the job, it will work very well. They are all very good at doing the job they were designed to do IMO.
How about this:
You can build the engine to match any carburetor.
BUT.
You can't build a carburetor to match all engines.
If the engine combo is screwy then you could try every carburetor and its not going to fix the problem. |
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Sun Dec 10, 2017 8:52 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
RailBoy wrote: |
Ok, been looking around for 36 vents for my 40 DRLA's, No Luck yet... |
If you're looking for Dellorto parts, I get mine from Carbs Unlimited.com. and CB Performance sells the Dellorto tech manual to properly tune those carbs and has calculations that will help you determine main and idle jet sizes for any engine combination.
Good luck with your search.
VeeWeeman |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sun Dec 10, 2017 9:46 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Alfa1750 on eBay can get your 36mm DRLA venturies and whatever else you need. http://stores.ebay.com/ALFA1750S-CARBURETORS-PARTS-STORE?_trksid=p2047675.l2563 _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Sun Dec 10, 2017 11:44 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Hey RacerDave, do you think that 36 Vents are within operational limits of 40 DRLA's? Meaning that there will be no negative effects, air turbalance, fuel atomization issues? RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Posted: Sun Dec 10, 2017 12:48 pm Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
No I don't. You will spend $200 on vents and jets and shipping but you won't get your moneys worth with the rest of your engine combo. They will work and the engine will run, but since you have a 5000 RPM limit on your engine larger vents will only help the top end. It will not help in the 2000-3500 RPM range where you do all your street driving.
My best suggestion is to not spend a nickel on your current engine and build the new engine you were talking about. With what you have now you will always have to compromise on something. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Danwvw Samba Member
Posted: Sun Dec 10, 2017 1:17 pm Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
2X I've been ordering some Zenith Carb Parts parts from this guy. The shipping is really quick and not a lot charged for little stuff. If he does not have them check with Eurocarb. And they have a e-bay seller eurocarb_ltd.
I have been looking for some DRLA 40's My self. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Sun Dec 10, 2017 1:31 pm Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
I’m a dellorto man, but now That the empi carbs are having success it makes it real hard to justify taking a chance on some old dells. I bought the 48’s that I run for $600 about 11 years ago. (Before empi has 48’s). It cost me $600 to have them made like new at ACE not long after I bought them.
I have some 45’s I got on eBay for $280 that run like brand new though.
I’ve always felt like dells are more forgiving about jetting. The biggest issue I’ve had with both is buying sets offline that show up worm out. _________________ Rides:
300HP 900lb turbo VW rail 18/15 travel
Never ending jeep/rzr hybrid build!
http://www.thesamba.com/vw/forum/viewtopic.php?t=546712 |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Mon Dec 11, 2017 5:21 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
RB what size header u running? What goes in MUST come out _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Mon Dec 11, 2017 7:06 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
I started off with a mosh of items from a $1,200 Engine...
I am running a 1 3/4" Berg Header w/Heat. Heads are CB Street Eliminators w/ 42mm x 37.5mm Valves, also currently I have 1to1 Ratio Rockers in it. Heads are ported and intakes are matched ported.
But yea, the engine is coming out and maybe cracking it open to re-balance it. Not sure yet, only time you can tell it needs balancing is over 5,400 RPMs, which is suitable for street use.
Yea, I am not 100% sure I can re-balance it do to availability of my VW Mechanic friend's time for he has a 40 hour a week job as well and people waiting for him to help them out as well. I am pulling my engine for trans work.
Oh, currently running a Engie 120 Cam... Yep, a mosh,lol.. RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Mon Dec 11, 2017 8:40 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
If the motor was balanced when you nassembled it...how did it get un balanced?As in it didnt loose or gain weight...which is waht balancing is all about _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
Posted: Mon Dec 11, 2017 9:50 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Yea no doubt, we were in a rush to get it done at lowest cost at the time. Everything was thought to be within reason, which it is until 5,400RPMs..
But now since the trans is coming out, the case may get split if there is time for the builder, another guy. Both have good repuations though, the crank was thought to have been balanced in the other engine.. But new pressure plate, disk, and flywheel were added. So, there the theory goes that it was within reason, guess that went out the door though with the flywheel and all..
But like RacerDave said it is a great street engine and runs solid and smooth up to 5,000 RPMs. Throttle is Super responsive. Thing is when you want to wine it up it simply can't do it. Breathing wise nor Balancing wise, thus really it just has a Max RPM of 5,000 RPMs, so that is how I drive it with in that limitation... RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
mark tucker Samba Member
Posted: Mon Dec 11, 2017 7:40 pm Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Paul.H wrote: |
A hole is a hole so at full throttle it's a hole. Jetted correctly the power is determined by the size of the hole not by what brand of hole you have on there |
not necessarily. things on both side of the hole and in the hole can affect the flow quite a bit. as for the performance thats in the tuning and how the carbs work. witch isant just jets. a bigger carb that dosent automixe&mix the fuel right at all rpm may not out perform a smaller carb.and just what performance are we talking about anyway? most power at topend? drivability?mpg? lots of variables. if I didnt know better and I jumped into my car and had never seen it before I would think it was injected. is it better than dells? better than webblers? I dont know Ive never run dells or webblers. but Ive never seen other peolples cars that always run like mine.most have issues...witch IMHO are owner inflected...or they just dont know how good they could be . so what ever you get you need to be able to 1 tune it, 2 understand them, 3 beable to work on them. 4 be able to tune the entire motor. 5 have a total solid combo. |
Posted: Tue Dec 12, 2017 3:32 am Post subject: Re: Comparing IDF PowerBand to DRLA PowerBand, Misconceptions? |
Yea, Mark hit on a good note about tuning and drivabilty when carbed. I have heard smaller carbs are good for low end grunt if tuned right.
My car runs like a top off idle-5,000 RPMs. Has crisp throttle responce through out that intire RPM range. Also, I average 24 mpg in the moutains on highways and back roads, though when tuning I got 13 mph once,lol, but that is another story of just being on it in the mountainous backroads. But on flat highways for I take those as well, I average 28 mpg. This is averaging around 65mph.
What is a coiencidence is that my engine starts to run out of breath around 5,400 RPMs when the balancing becomes an issue, so as long as I am below 5,000 rpms or so the car runs great and performs great.
So yea, we will see about rebalancing the engine, up to the builder and if he has a slot to make it happen??? Then I will be looking for carbs for sure, but will be in no rush for the engine is tuned for lower rpms for time being.. RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
