Goach2 Samba Member
Joined: November 20, 2017 Posts: 522 Location: Niagara Region, Ontario
Posted: Thu Dec 07, 2017 1:37 pm Post subject: Steering Column Test Before Assembly |
So one of the PO's of this bus took the column apart and just put the wheel back on. All the other parts were found in the glovebox (hopefully all the parts) Ratwell has a great tutorial on this assembly, but since I have no clue why it was disassembled and before I reassemble it, is it possible to make all the connections required on the floor, to test them out first?
Also, the PO is mailing me the key, so that's out of the equation for now... |
Starbucket Samba Member
Posted: Thu Dec 07, 2017 4:09 pm Post subject: Re: Steering Column Test Before Assembly |
Try asking the PO why it's apart, much easier. |
Goach2 Samba Member
Posted: Thu Dec 07, 2017 4:33 pm Post subject: Re: Steering Column Test Before Assembly |
Already did;) it was the PPO and he had no idea why. |
SGKent Samba Member
Posted: Thu Dec 07, 2017 4:43 pm Post subject: Re: Steering Column Test Before Assembly |
locking column gone bad
turn signal switch not working or shorted
headlights not cycling between high and low beams or shorted
occasional unwanted horn honk from a shorted wire / column / rubber puck
missing tab at bottom of column
prep for a complete restoration
some of those will require more than a couple wires to test
. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Goach2 Samba Member
Posted: Fri Dec 08, 2017 6:44 am Post subject: Re: Steering Column Test Before Assembly |
Thanks SGKent, maybe I'll test the electrical connections while it's off, but sounds like I will have to reassemble for the rest. |
