pdub Samba Member
Posted: Thu Dec 07, 2017 4:46 pm Post subject: SINGLE 44 IDF ok for street? |
I have a 2276 with dual 44 IDFs (HPMX) but they are in need of work/replacement so Im thinking of going with CB's single 44 on my mostly street driven Baja bug. I have a short commute to work and Im wondering if the singles warm up and idle fairly fast or will it just be getting warmed up and idling right about the time I roll up to work? I know the performance wont be as great and they need pre-heat and specific jetting but do they have decent street manners, especially for a lot of shorter trips? |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Thu Dec 07, 2017 7:04 pm Post subject: Re: SINGLE 44 IDF ok for street? |
If you have pre heat off the exhaust it will heat up fast. You’ll never dial it in like duals though.
It really depends on what cam and head you have if it will run acceptable or be a power drain.
You may can just clean up theHPMX carbs if they are not from the first batch. I’m not sure if anyone can fix a first batch set to be good. I swore them off at first, but they have a great reputation with what they are selling currently. _________________ Rides:
300HP 900lb turbo VW rail 18/15 travel
Never ending jeep/rzr hybrid build!
http://www.thesamba.com/vw/forum/viewtopic.php?t=546712 |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1059 Location: St. Louis
Posted: Fri Dec 08, 2017 7:31 am Post subject: Re: SINGLE 44 IDF ok for street? |
If someone can explain this I'd definitely welcome it. I agree that the science of preheat can't be denied, it is the best option. If for whatever reason that is too difficult, this intake setup seems to work very well. I can take the lower section off, and bolt up my old Bugpack aluminum manifold without preheat hooked up, and it runs way worse. I have yet to explain to myself why. It likes much richer idle jets with the aluminum cast style intake. Something about the steel IR style manifold makes witchcraft happen.
_________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
