busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Fri Dec 08, 2017 3:21 pm Post subject: Rear Seat Back Rail Removal |
To convert the rear of my 71 bug I have drilled the spot welds holding the rear seat back carpet rail thingy holder, putting in a 5/8" pine sanded plywood base which will be secured to the old parcel tray, have a hinged opening for battery and VR access and be carpeted. When I showed the idea to a body man in OKC he flipped out said the metal in the rear would buckle causing the trans to hit the body, now structurally I find that hard to believe for there is not going to be hundreds of pounds stored back there plus the plywood is getting secured. Cardboard template in place.
Anybody have any thoughts on this or is it just wives tales about the buckling?
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Fri Dec 08, 2017 3:38 pm Post subject: Re: Rear Seat Back Rail Removal |
Man, in your pics, that color looks like fresh Bahama Blue!
I find the proclamation of your luggage shelf/tray buckling to be completely laughable. Even with a few hundred pounds distributed evenly across it, it won't collapse...unless you're jumping your Bug baja-style in Moab, doing bone-crunching landings that would completely fold and obliterate your suspension. I think you'll be fine. |
Posted: Fri Dec 08, 2017 3:42 pm Post subject: Re: Rear Seat Back Rail Removal |
It is fresh Marina Blue L54D, turned the inside into European style |
vwoldbug Samba Member
Posted: Fri Dec 08, 2017 4:06 pm Post subject: Re: Rear Seat Back Rail Removal |
As bustom says you will be fine . Nice idea . |
Posted: Fri Dec 08, 2017 6:07 pm Post subject: Re: Rear Seat Back Rail Removal |
Nice. I was wondering why the effort to beautify that part |
Posted: Fri Dec 08, 2017 7:04 pm Post subject: Re: Rear Seat Back Rail Removal |
Which part? |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Fri Dec 08, 2017 7:21 pm Post subject: Re: Rear Seat Back Rail Removal |
You might consider a hinged door for battery maintenance.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Fri Dec 08, 2017 7:37 pm Post subject: Re: Rear Seat Back Rail Removal |
Already part of the plan, once the plywood is cut then the access hatch will be cut, hinged, platform anchored, top padded with jute then carpeted. |
Posted: Fri Dec 08, 2017 9:35 pm Post subject: Re: Rear Seat Back Rail Removal |
busman78 wrote: |
Which part? |
The interior sill just below the rear window, and the interior quarters just behind the side windows. Isn't that your effort to make a Euro interior? |
Posted: Sat Dec 09, 2017 7:05 am Post subject: Re: Rear Seat Back Rail Removal |
A feeble attempt but that is the idea
Posted: Sat Dec 09, 2017 11:12 am Post subject: Re: Rear Seat Back Rail Removal |
It looks great...brings more of the outside beauty of the car INSIDE
I also like the omission of the padded dash. |
Tindjin Samba Member
Joined: February 26, 2018 Posts: 20 Location: Albuquerque, NM
Posted: Mon Dec 17, 2018 10:07 pm Post subject: Re: Rear Seat Back Rail Removal |
I know this is a bit old but wondering how it turned out. Thinking of doing something similar with my ''73. Thanks. _________________ 1973 SuperBug - Project just starting.
Do not seek death.
Death will find you.
But seek the road
which makes death a fulfillment. |
Posted: Tue Dec 18, 2018 5:34 am Post subject: Re: Rear Seat Back Rail Removal |
Worked out pretty good
