Old school U.S. Wheels - found NIB.
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
joey1320
joey1320 is offline
PostPosted: Sat Dec 09, 2017 12:52 pm    Post subject: Old school U.S. Wheels - found NIB. Reply with quote
These U.S. Wheels - 15" x 7" were found by my older brother on Craigslist in the summer. I made a trade with him last month and now they will be going on my '71 Super. Gotta figure out the spacing and such, but I absolutely love the look. Already mounted 175-65-15 on them, and just got my extended lug bolts. Hopefully I'll get some time tomorrow to mount them all and check fitment, specially in the front.
What y'all think?
**1971 Super Project
ps2375
ps2375 is offline
PostPosted: Sat Dec 09, 2017 6:17 pm    Post subject: Re: Old school U.S. Wheels - found NIB. Reply with quote
Wheels look like a nice match with car, but fitment looks bad. Unless you like tire rub. Not sure if a set of Bus Snubbers would help.
chickengeorge
chickengeorge is offline
PostPosted: Mon Dec 11, 2017 9:58 am    Post subject: Re: Old school U.S. Wheels - found NIB. Reply with quote
You could narrow the rear end as well. The arms below will net you 1". You also need to locate short side axles from an automatic type III.
I went a little farther with mine and got and 1-5/16 on each side with some machine work to the rotors and relocation of the brake caliper.
https://www.thesamba.com/vw/classifieds/detail.php?id=1725100
W1K1
W1K1 is offline
PostPosted: Mon Dec 11, 2017 10:36 am    Post subject: Re: Old school U.S. Wheels - found NIB. Reply with quote
cool wheel, but totally wrong offset for a super, if the rears look like that , the fronts will be worse. New wider fenders, or pass them off to someone else. Supers need a high offset like porsche wheels +50et for proper fit.
http://vdubengineering.com/wp-content/uploads/2011/05/WHEELFITMENTGUIDE1.pdf
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
chickengeorge
PostPosted: Mon Dec 11, 2017 4:57 pm    Post subject: Re: Old school U.S. Wheels - found NIB. Reply with quote
Missed the Super Beetle part. Yeah, the front will be farther out than the rear and there's not much to do about it up front.
theastronaut
theastronaut is offline
PostPosted: Mon Dec 18, 2017 3:50 pm    Post subject: Re: Old school U.S. Wheels - found NIB. Reply with quote
Roll the fenders and negative camber if possible, 3-4* might get them to tuck? Might have to drop back to 155 or 165 width tires up front. I did this when I swapped wheels on my Festiva; they stuck out about one inch; after with rolling/pulling the fenders and -3.5 camber they now fit without rubbing. Handles much better with the added camber too. Tire wear won't really be an issue if you run zero toe.
Edit- lowering it will add a little bit of negative camber in the rear, and shorter sidewall tires will help them fit better. It'll drive better with shorter tires as well. I found this pic after a quick google search, I love the look.
Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
