bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sun Dec 10, 2017 10:37 am Post subject: Dual circuit conversion with 67 reservoir |
I'm converting my 65 to dual circuit using 67 reservoir. I'd lie to see how people have enlarged the hole to fit the 67only reservoir. Thanks!
Byas _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sun Dec 10, 2017 11:00 am Post subject: Re: Dual circuit conversion with 67 reservoir |
bnam wrote: |
Byas |
Would you REALLY need to enlarge the hole???? You'd be running a "tee" anyway from the single reservoir to the duel-inlet master cylinder, why not use an adapter tee and have the first hose be the right size and from the tee go slightly larger to mate up with the dual circuit master cylinder? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bnam Samba Member
Posted: Sun Dec 10, 2017 6:45 pm Post subject: Re: Dual circuit conversion with 67 reservoir |
Using a Tee with a single chamber reservoir is pointless -- you lose one circuit and you lose both. The 67-only reservoir has 2 chambers and 2 outlets but fits in the same area as the original -- similar shape too, just protrudes out a bit more and needs a larger opening for the 2 pipes that exit the reservoir.
Before I start cutting, it would be helpful to see how and what others have cut.
THanks!
Click to view image
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
Posted: Sun Dec 10, 2017 7:33 pm Post subject: Re: Dual circuit conversion with 67 reservoir |
Byas,
The image below is a pic of the backside of my 67 dual MC res. through the rear side of the spare wheel well. Note that there is a little bit of foam insulation. The insulation is factory installed!
Keep in mind that this is from a 67 Type1. Not a 65 Ghia. But being the resourceful man that you are. You'll figure it out.
Good Luck.
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Last edited by 67rustavenger on Mon Dec 11, 2017 5:25 pm; edited 1 time in total |
bnam Samba Member
Posted: Sun Dec 10, 2017 10:24 pm Post subject: Re: Dual circuit conversion with 67 reservoir |
Perfect! Thank you. This gives me a better sense of what the original opening looked like and the orientation of the metal tubes that come out of the reservoir. I do have the insulation as well. This portion is identical between the KG and the Beetle.
Click to view image
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Mon Dec 11, 2017 2:00 am Post subject: Re: Dual circuit conversion with 67 reservoir |
I've been thinking about getting a dual circuit for my '65, and putting a bus reservoir on top. If it would fit, that is.. then I can use the stock '65 reservoir to feed the dual bus reservoir. Haven't tried any of that yet so it may not even work! But just an idea. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
jimdubs Samba Member
Joined: August 31, 2016 Posts: 152 Location: Buffalo, NY
Posted: Mon Dec 11, 2017 4:26 am Post subject: Re: Dual circuit conversion with 67 reservoir |
Here's another pic that should help
Cusser Samba Member
Posted: Mon Dec 11, 2017 8:04 am Post subject: Re: Dual circuit conversion with 67 reservoir |
bnam wrote: |
Using a Tee with a single chamber reservoir is pointless -- you lose one circuit and you lose both. The 67-only reservoir has 2 chambers and 2 outlets but fits in the same area as the original -- similar shape too, just protrudes out a bit more and needs a larger opening for the 2 pipes that exit the reservoir. |
I didn't know that the 1967 was dual circuit reservoir. Never mind ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bnam Samba Member
Posted: Mon Dec 11, 2017 9:28 am Post subject: Re: Dual circuit conversion with 67 reservoir |
jimdubs wrote: |
Thanks!! _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Posted: Mon Dec 11, 2017 5:27 pm Post subject: Re: Dual circuit conversion with 67 reservoir |
I added a couple of extra routing pics in my post above for you Byas.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34014 Location: Conejo Valley, CA
Posted: Mon Dec 11, 2017 5:48 pm Post subject: Re: Dual circuit conversion with 67 reservoir |
Cusser wrote: |
bnam wrote: |
I didn't know that the 1967 was dual circuit reservoir. Never mind ! |
There have been some odd variations for the '67 that I can't quite remember, including mismatched hose barb sizes, addressed with a weird green hose that had different sized ends, and perhaps other tweaks. There have been threads with photos. But the main think is to use blue brake hose and not regular fuel line, and make sure there are no cracks that can leak fluid out or suck air in. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Mon Dec 11, 2017 5:52 pm Post subject: Re: Dual circuit conversion with 67 reservoir |
bnam wrote: |
jimdubs wrote: |
Thanks!! |
Thats exactly what I did on the 63 that we converted. Don't forget that you need a MUCH longer retaining strap. Was glad I remembered that before we painted the car.. _________________ D-Dubya Manx clone - 63 Short pan,1914.
turbotype1 Samba Member
Posted: Tue Dec 12, 2017 8:34 am Post subject: Re: Dual circuit conversion with 67 reservoir |
scrivyscriv wrote: |
I've been thinking about getting a dual circuit for my '65, and putting a bus reservoir on top. If it would fit, that is.. then I can use the stock '65 reservoir to feed the dual bus reservoir. Haven't tried any of that yet so it may not even work! But just an idea. |
I was gonna try that as well.... The ports on the master cylinder for the front brake lines are in the way of the bus lower reservoir.... _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Tue Dec 12, 2017 8:46 am Post subject: Re: Dual circuit conversion with 67 reservoir |
Or just get rid of it altogether
_________________ 1963 Ragtop Bug |
bnam Samba Member
Posted: Tue Dec 12, 2017 9:20 am Post subject: Re: Dual circuit conversion with 67 reservoir |
Why is nothing straightforward???
The metal lines on the 67-only reservoir are 6mm OD. While the elbow on the MC is 8mm. How did the original set up work? The WW repro looks pretty good in quality -- did they just get this part wrong or was the original also like that?
Click to view image
bnam Samba Member
KTPhil Samba Member
Posted: Tue Dec 12, 2017 9:48 am Post subject: Re: Dual circuit conversion with 67 reservoir |
bnam wrote: |
Byas |
This is what I was hinting at in my post above. A few years ago this was discussed in detail with photos. Search may find that thread and give you answers. |
Cusser Samba Member
wayne1230cars Samba Member
Posted: Tue Dec 12, 2017 1:51 pm Post subject: Re: Dual circuit conversion with 67 reservoir |
bnam wrote: |
Byas |
[img]
From the gallery a pic of 1967 hoses. The adapters that are presently available look like they should work.[/img] _________________ 1960 beetle
1970 beetle convertible |
boxkiteflyer Samba Member
Joined: May 22, 2008 Posts: 261 Location: Taylorsville, KY
Posted: Tue Dec 12, 2017 7:54 pm Post subject: Re: Dual circuit conversion with 67 reservoir |
I'm going to put a dual circuit MC in my '57. I'm going to use the stock reservoir for the front circuit and put another reservoir next to the MC for the second circuit. It will still appear to be 'stock'. I'll use Dot 5 fluid (silicone) so I don't have the worries of paint getting damaged in case of spills. |
