cpd419 Samba Member
Joined: November 19, 2014 Posts: 83 Location: Williamsburg, Ky
Posted: Sun Dec 10, 2017 4:36 pm Post subject: Drop spindle conversion |
My 66 beetle has 2.5" drop spindles with drum brakes. Does anyone know if they can be converted to disk brakes? I don't know if the drop spindles that were bought specifically for drum brakes can even be converted. Many thanks. _________________ 66 beetle |
rabbit20v Samba Member
Joined: June 18, 2015 Posts: 24 Location: Buffalo, NY
Posted: Mon Dec 11, 2017 9:41 am Post subject: Re: Drop spindle conversion |
IIRC, you need drop spindles specifically for disc brakes.
Otherwise there is no where to attach the caliper carrier. |
HomeGrown Samba Member
Joined: December 24, 2007 Posts: 3 Location: COLORADO
Posted: Mon Dec 11, 2017 10:25 am Post subject: Re: Drop spindle conversion |
buy a disk brake kit for drum spindles |
anthracitedub Samba Member
Posted: Mon Dec 11, 2017 12:07 pm Post subject: Re: Drop spindle conversion |
FWIW... a good working drum system will work just as good in most cases. |
cpd419 Samba Member
Posted: Mon Dec 11, 2017 1:58 pm Post subject: Re: Drop spindle conversion |
Thanks! My brakes are decent to good anyway might be a waste. _________________ 66 beetle |
Posted: Mon Dec 11, 2017 5:59 pm Post subject: Re: Drop spindle conversion |
My 62 beetle has a well sorted stock drum system all the way around... works perfect and will lock up all four wheels if you jump on them.
I have a 57 Ghia that I put wide five disc on the front... they are a little more assuring than the OE drums... takes a little less pedal pressure to lock it up...
But ultimately, the weak point is the light front end and tiny tire foot print that most of us have.
In an emergency situation, we’re just gonna slide, hold on and hope for the best.
The trick is, drive within the means of your car and your environment... always drive defensively and watch out for dummies....just let’em go on by. |
cpd419 Samba Member
Posted: Mon Dec 11, 2017 9:33 pm Post subject: Re: Drop spindle conversion |
My brakes work well. They have all been replaced with new seals and a new master cylinder (unfortunately). I always allow a little more space between me and the next vehicle and don't get in a hurry. I just thought if they could be converted why not. Thanks for all the help everyone. _________________ 66 beetle |
cpd419 Samba Member
Posted: Mon Dec 11, 2017 9:34 pm Post subject: Re: Drop spindle conversion |
This is the bug by the way _________________ 66 beetle |
Murt Samba Member
Joined: October 01, 2017 Posts: 304 Location: Suffolk, England
Posted: Mon Dec 11, 2017 11:53 pm Post subject: Re: Drop spindle conversion |
That's a lovely Beetle
What wheels and tyres sizes are you running ? _________________ 1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi |
cpd419 Samba Member
Posted: Tue Dec 12, 2017 6:31 pm Post subject: Re: Drop spindle conversion |
Wheels are 15" maybe by 5.5. Not sure. The front tires are smart car tires, again not sure about the size. Maybe 145's? _________________ 66 beetle |
vwoldbug Samba Member
Posted: Thu Dec 14, 2017 2:38 pm Post subject: Re: Drop spindle conversion |
Great looking beetle . |
cpd419 Samba Member
Posted: Tue Jan 09, 2018 12:13 am Post subject: Re: Drop spindle conversion |
New pic
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Tue Jan 09, 2018 5:45 am Post subject: Re: Drop spindle conversion |
cpd419 wrote: |
Wheels are 15" maybe by 5.5. Not sure. The front tires are smart car tires, again not sure about the size. Maybe 145's? |
You do realize the tire size is clearly molded into the sidewall right? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
planenut Samba Member
Posted: Tue Jan 09, 2018 8:02 am Post subject: Re: Drop spindle conversion |
Try CB Performance. They seem to have the adapters and disc kits. |
cpd419 Samba Member
Posted: Tue Jan 09, 2018 6:07 pm Post subject: Re: Drop spindle conversion |
Sharp64 wrote: |
cpd419 wrote: |
You do realize the tire size is clearly molded into the sidewall right? |
Yea but it's in winter storage so it will be awhile. _________________ 66 beetle |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Tue Jan 09, 2018 6:18 pm Post subject: Re: Drop spindle conversion |
Just abut everyone will tell you that adapters won`t work with dropped spindles. But I`ve seen posts on here of people modifying them to work. But I would just change spindles. _________________ If you`re going to do something, do it right. |
cpd419 Samba Member
Posted: Wed Jan 10, 2018 12:24 am Post subject: Re: Drop spindle conversion |
Since I already changed the tie rods and what not to use the drop spindles would it be as easy as changing the spindles only to a disc type? I had to change quite a bit to convert to the drop spindle. _________________ 66 beetle |
Posted: Wed Jan 10, 2018 3:29 am Post subject: Re: Drop spindle conversion |
cpd419 wrote: |
Since I already changed the tie rods and what not to use the drop spindles would it be as easy as changing the spindles only to a disc type? I had to change quite a bit to convert to the drop spindle. |
Why did you have to change the tie rods? Spindles are a bolt on. Nothing else should have required changing. What else did you change? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Wed Jan 10, 2018 8:00 am Post subject: Re: Drop spindle conversion |
Dropped spindles use later tie rod ends. And wheel bearings. Nothing major though. _________________ If you`re going to do something, do it right. |
