New door panel install window crank doesn't set flush
Justagirlandher69beetle
Justagirlandher69beetle is offline
PostPosted: Mon Dec 11, 2017 6:09 pm    Post subject: New door panel install window crank doesn't set flush Reply with quote
Completed door panel install over the weekend. Everything was going good until I popped the clips in the drivers side panel and realized that the window crank pin is sticking so far out that when I go to screw the handle back on there is an inch gap. Any idea how I can fix this? Or why would it happen? The panel wasn't warped and the other side is fine with everything being flush up against it.
Tim Donahoe
Tim Donahoe is offline
PostPosted: Mon Dec 11, 2017 6:23 pm    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
You're missing a conical spring that fits over the winder spindle. This spring pushes the panel out.
Tim
Let's do the Time Warp again!
Richard O'Brien
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Mon Dec 11, 2017 8:42 pm    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
Stock window with a vent wing? Or is it a one piece with the 65 dual post regulator. That older regulator has a longer window crank shaft.
Jimbo
PostPosted: Tue Dec 12, 2017 6:50 am    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
Tim
Do you know where I can purchase the spring?
PostPosted: Tue Dec 12, 2017 6:54 am    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
It's just the stock job. Is it possible mine is a frankenstein and someone put the longer window crank shaft on it?
lovethatconvertible
lovethatconvertible is offline
PostPosted: Tue Dec 12, 2017 7:00 am    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
Justagirlandher69beetle wrote:
Tim
Go to the home page, and under classifieds on the left side, type in door spring.
There's a ton of em for sale.
1960 Convertible
Q-Dog
Q-Dog is offline
PostPosted: Tue Dec 12, 2017 7:02 am    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
Here it is, if you can't find used.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111837229
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
PostPosted: Tue Dec 12, 2017 9:02 am    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
Tytyty!!
hitest
hitest is offline
PostPosted: Tue Dec 12, 2017 9:42 am    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
Before you buy a new one- look down in side your door. I can't count how many I've found laying down in the bottom trough.
FU#5
sb001
sb001 is offline
PostPosted: Tue Dec 12, 2017 6:43 pm    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
I'm curious as to how the other side door panel seems flush, without the need for the spring. Got any pictures you can show?
Also, do you have the black plastic collars/ spacers/ whatever that fill up the space between the door panel and the spindle end of the crank handle?
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111837595A
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Tim Donahoe
PostPosted: Tue Dec 12, 2017 7:49 pm    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
Steve, for some reason, when I installed my new TMI door panels, the window-winder spring was not needed.
And Steve makes a good point: there are two round plastic spacers that go between the door panels and the back of the winder. If these are missing, that may be the cause of the problem.
Tim
Richard O'Brien
Cusser
Cusser is offline
PostPosted: Wed Dec 13, 2017 8:01 am    Post subject: Re: New door panel install window crank doesn't set flush Reply with quote
Ivy - does the door panel "dish in" towards the door as it is now? Can you post good photos? On both sides of the VW as well?
Yes, there is a little conical spring that goes there, under the panel. Sometimes that's a little tricky to get that to stay in place when you reinstall the panel. The little plastic "buffer" that fits just under the winder handle is pretty thin, won't fill a 1-inch gap.
