converting to fuel injection
Septimus
Septimus is offline
PostPosted: Sun Jun 14, 2009 6:36 pm    Post subject: converting to fuel injection Reply with quote
I have a 72 bus that needed a new engine so I bought a junked 75 bus with a 2L fuel injection system. I've taken the engine out and all the fuel injection components on the bus out and I am just about to weld the bracket for the air intake box from the parts bus into mine. Is there any reason I should mount it somewhere other than the way it was in the parts bus? I'm also going to cut the hole for the computer tomorrow. I'm also planning on putting this in the same spot. Has anyone else done this before? If so, what are your top pieces of advice or caution? Thanks for any help!
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Jun 14, 2009 6:40 pm    Post subject: Reply with quote
Be sure to put a return line in the fuel tank while the engine is out. If you end up using th esingle outlet, remove the fuel "sock" and use a "Y" as opposed to a "T"
fukengruvenoval
fukengruvenoval is offline
PostPosted: Sun Jun 14, 2009 6:50 pm    Post subject: Reply with quote
72 busses don't have the upper engine access hatch. Setting up the FI and adjusting it (the AFM for example) will be a nightmare without it.
Since you're welding in the air cleaner arm (and yes, I suggest you put it in the exact same spot) why not cut and weld in the metal for the access hatch?
Also, when doing a swap like this there are some often forgotten pieces of wiring... Like, for example, the fuel pump harness. It's fairly simple (+ and - to the fuel pump, fuel pump trigger to the starter, 78+ also have the +VE hook up for the FI system to the starter). Pull this out complete and reuse it. It is often referred to as the "bus side" connector for the double relay, and it's hard to find.
'75 busses didn't have 2L engines. Are you sure it's a 2L? In '75 they had 1800CC FI engines. If it's an 1800, it should fit your tranny without too much worries, but the gearing won't be great. If it's really a 2Lyou will have problems mating the 2L to the '72 tranny.. Is that what you're planning on doing? You should probably swap in the tranny from the parts bus as well. It would have the larger bellhousing for the 228mm flywheel and better ratios for the 2L.
EDIT - Very good point from Randy in Maine... Again, since you've bought the parts bus, might as well swap in the whole tank. And do all the venting while you're there.
Check out my video series at www.youtube.com/midnightoilgarage
Current: 12 Fiat 500 Sport, 09 Ford Flex, 76 Westfalia 2L FI, 72 Euro Super Auto-Stick, 69 Type 1 Cal-Look, 56 Type 1
Past: 94 Jetta Diesel, 92 Golf, 79 Bradley GT, 74 Thing, 73 Super Euro Spec, 72 Super, 68 Type 1 Convertible, 66 Single Cab, 65 Beetle, 57 Type 1 Parts Car, 57 Porsche Speedster Kit Car (CMC), 00 New Beetle GLS
Septimus
Septimus is offline
PostPosted: Mon Jun 15, 2009 11:53 am    Post subject: Reply with quote
Thanks for the responses. I've thought about cutting out a panel and putting the access hatch in but I'm hesitant to do it myself. I'm worried I'll botch it.Has anyone out there ever done this? I'm swapping out the transmission as well. I used to have a 2L with a mismatched transmission and the RPMs were always pretty high. I'm pretty sure this is a 2L engine.
Bleyseng
Bleyseng is offline
PostPosted: Mon Jun 15, 2009 12:14 pm    Post subject: Reply with quote
I'd swap in the 091 tranny too if you are going with the 2.0L engine..
The engine hatch is a great swap in but welding is a hassle if you don't know how...any small shop can do it for you before the engine is installed!
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!
76 Porsche 914 2.1L L20c, 120hp Djet
1977_L63H_P27
1977_L63H_P27 is offline
PostPosted: Mon Jun 15, 2009 1:25 pm    Post subject: Reply with quote
A '75 should have a 1.8L instead of the 2.0, but still the matching tranny wouldn't be a bad idea. I'm hoping to put the fuel injection back on our '77. It seem like quite a bit of work, so I admire you for putting it on a vehicle that never had it. Peace!
busdaddy wrote:
...and try a few chubby ones until you find one you like.
1977 Westfalia P27 Green Bay Bus
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club
Septimus
Septimus is offline
PostPosted: Mon Jun 15, 2009 4:24 pm    Post subject: Engine ID Reply with quote
Ok, my engine code is GD001598 but the bus was made in August 1975 so according to what I've found, that means that the engine is a 2L but the bus should have an 1800cc. Does that sound right?
rustbus
rustbus is offline
PostPosted: Sun Apr 08, 2012 6:45 am    Post subject: Reply with quote
guys (and any gals)
i'm working on my fuel injection conversion....moving from the 1700 to a fuel injected 2L and 091 trans.
i think i've found the best location for the fuel pump but im a little concerned about interference and wanted some input
the later FI buses are "missing" some reinforcing brackets from the rear tube
79 bus: you can barely make out the FI pump bracket but its there (before i chipped it off)
now on the 72 theres this giant bracket in the way:
theres about 3.5" of space here, but im worried about a pinch point if i were to hit a huge bump...
the bump stop would have to compress something like almost 2" to make this fuel line get pinched. i forget the measurement but you can almost scale it in the second picture.
anyone think i'm at risk here? i want to keep the pump as close to the original position in order to use the original metal fuel lines as much as possible...
i suppose im willing to take some material out of the bracket to move this upward...but would obviously rather not. either way looks like VW didn't feel the bracket was necessary or cost effective any more at some point, or reinforced elsewhere
thoughts??
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
[email protected]
Samba Peckerhead
PostPosted: Sun Apr 08, 2012 6:58 am    Post subject: Reply with quote
if you were to hit a bump that would pinch that line, i would think you would have way bigger problems than that. i suppose if you were worried about it, drill a hole in the bracket, put a grommet in the hole and run your line through that. your line may have a bit of a 's' in it, so i don't know if it is possible to do it that way.
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
busdaddy
busdaddy is offline
PostPosted: Sun Apr 08, 2012 9:06 am    Post subject: Reply with quote
Or move it to the outside of the frame further forward like VW did on early FI buses. You'll have to fabricate some hard lines but that may be the best option for clearance. You could also mount it to the bottom of the tank compartment above the transmission, I don't know how much noise that would make but the lines would be much shorter.
As Skills says it would work where you've got it, but things get pretty crowded once the heater tubes are in there and might be tight.
pgtips
pgtips is offline
PostPosted: Sun Apr 08, 2012 1:35 pm    Post subject: Reply with quote
Hi,
I've got a fully running 75 2.0L FI if you need any assistance or pics etc.
PG
rustbus
rustbus is offline
PostPosted: Sun Apr 08, 2012 6:35 pm    Post subject: Reply with quote
cool thanks guys, some good ideas. i was hoping to put it kinda where it is in the pictures only because i have the metal line for overtop the trans.
i did stick the heater tube on to see how close things are getting, but now the results of that are escaping me - i'll have to do it again.
i'm thinking i may go for this location and maybe just notch out that bracket just a little halfmoon-ish.?
i thought of over the trans but i worried about getting at the fuel filter easy and - oh yea - i have the original FI fuel pump/reverse switch/double relay wiring harness that i'm going to use so i have to stay in this area in order for that to work. i'm very partial to the original wiring Rolling Eyes yeah lame i know, hack away then im a baby about the wiring Wink
pqtips if you have any pictures or your install that would be great, particularly the fuel pump. i have the aircleaner bracket all sorted and the ECU cutout and steady-bracket sorted
my Bus thread
shiningstar76
Samba Brewer
shiningstar76 is offline
PostPosted: Sun Apr 08, 2012 6:42 pm    Post subject: Reply with quote
I'd do the engine hatch right. I rode in a 72 with a whats in your pipe style access hatch, and it was so loud in that bus and the fumes were terrible.
KK4NTP
96 Tacoma
86 4Runner
My bus caught on fire and is now on the other coast with someone who gave me money for it.
rustbus
rustbus is offline
PostPosted: Sun Apr 08, 2012 6:48 pm    Post subject: Reply with quote
engine hatch i have sorted already, i have a huge 411 or whatever car unit welded in. lifesaver. fume free!
my Bus thread
mikewire
mikewire is offline
PostPosted: Sun Apr 08, 2012 8:15 pm    Post subject: Reply with quote
Hi Rustbus! I took a few pictures of my setup for you, I hope they help. They are a bit big, for detail, so you may have to let them load a minute.
I think I have my pump set to the rear a bit more, but the height looks to be the same.
I chose to run my fuel line along the rear of that bracket, up and over the transmission to the tank. The filter sits just above the heater tube, out of the way. There's no rubbing on the fuel line, and a very small chance of anything hitting the line or filter:
-Mike
@countdowngarage
1972 VW Kombi 9 Passenger Deluxe w/ 2.0L F.I. VWAC swap
View user's profile Send private message Send e-mail Visit poster's website Twitter Instagram Classifieds Feedback
thewalrus
Big Jack
thewalrus is offline
PostPosted: Mon Apr 09, 2012 9:41 am    Post subject: Reply with quote
Wrong. I know it's an old topic but '75 was the first year old the 2.0L F.I.
http://www.thesamba.com/vw/forum/viewtopic.php?t=503859&highlight=early+type
'73 Transporter 1.7L Dual Carb
notchboy wrote:
You ran over some #Vanlife'ers hopes and dreams?
60vwnewengland wrote:
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards!
rustbus
rustbus is offline
PostPosted: Mon Apr 09, 2012 12:49 pm    Post subject: Reply with quote
thanks mikewire, i was just reviewing your thread earlier and i was wondering hows your install ended up in regards to the pump.
thanks for the pics! shame i'm low on 11mm hose, may have to get more.
my Bus thread
mikewire
mikewire is offline
PostPosted: Mon Apr 09, 2012 2:56 pm    Post subject: Reply with quote
You bet, it's worked out great for me. Awesome progress! Yours looks like a great setup too - the best of luck to you. Go '72's Very Happy
-Mike
@countdowngarage
spaine
spaine is offline
PostPosted: Sun Jan 25, 2015 10:10 am    Post subject: Reply with quote
I too have a 72 bus and am considering switching to fuel injection. It was not originally an FI engine. When looking at versions of fuel injection used on busses, it looks like the later versions are the better option. Is this correct? if so, what years should I be looking for? there are 2 "complete" FI parts listings in the forum:
http://www.thesamba.com/vw/classifieds/detail.php?id=1702300
and
http://www.thesamba.com/vw/classifieds/detail.php?id=1739635
Would either of these be a good option for a conversion such as the one in this thread? I am aware of the fuel tank issue as well as adding a fuel pump and filter.
64 Beetle
72 Westfalia
72 Super with Autostick
71 Squareback
jtauxe Premium Member
jtauxe is offline
PostPosted: Sun Jan 25, 2015 10:27 am    Post subject: Reply with quote
It is certainly less convenient, but i would not call it a nightmare. I have to contend with the same problem with the 2.0-L FI engine in my double cab pickup. One approach is to invert the AFM 180 degrees, so that the cap is on the bottom. I really do not have the option of adding a hatch, unless I want a hatch in the middle of the pickup bed, which I do not. Besides, once the FI is set up right, it should not need a lot of futzing with.
John
"The bus came by and I got on. That's when it all began..." - Garcia/Weir/Kreutzman
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab, 1978 Irish 4-door double cab RHD
