loveevan Samba Member
Joined: September 19, 2014 Posts: 27 Location: San Diego
Posted: Tue Dec 12, 2017 2:42 am Post subject: grinds only into 3rd, could it be something other than syncro? |
hello,
I have a 1978 vw high roof camper bus. I bought it from a family friend, site unseen, for a nice low price.
He said he doesn't remember any gear grinding when he drove it, fairly recently.
For me though, it grinds, a lot, going into 3rd gear from 2nd, and downshifting to 3rd from 4th.
I can shift out of second, wiggle it around a bit in neutral, and ease it into 3rd from the far right (while the engine speed reduces as well) and get it into 3rd with much less and sometimes no grinding.
i can shift down from 4th, hang out in neutral while the engine slows a little, then shift while accelerating and get less grinding into the downshift to 3rd.
double clutching doesn't seem make a difference
I was informed that the previous owner had just gotten a new clutch installed, so perhaps something happened there, because while the old clutch shuddered at bit, he does not recall any problem shifting to 3rd.
other than the grinding into 3rd, the trans works great, no popping out of gears, even under load, and all other gears shift smooth every time.
so, the question is, is there anything that could cause this other than a worn or broken syncro... ...as in anything I can fix or adjust without paying a whole lot for a rebuild and install?
thanks
Joined: January 01, 2007 Posts: 16859 Location: sticksville, ct.
Posted: Tue Dec 12, 2017 5:51 am Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
If the clutch is adjusted correctly then its rebuild time. Do it sooner rather than later before there is nothing left to rebuild _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Tue Dec 12, 2017 8:34 am Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
Indeed the first thing to check would be the clutch cable adjustment. If you have too much free play, then the clutch could be not completely disengaging when you are pushing the pedal down - which is very hard on the syncros.
Adjust the clutch cable so the free play is as specified in Bentley.
If it still grinds going into 3rd after that, then Skills already told you what's next. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Tue Dec 12, 2017 8:53 am Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
Why don't you have your friend drive it and see if he sees anything odd in the way it shifts. As others mentioned it could be an out of adjustment clutch. Did you change the gear oil in the tranny? These units typically don't like GL-5 oils which is the reason the VW recommended using only GL-4 oils.
tommu Samba Member
Posted: Tue Dec 12, 2017 2:09 pm Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
loveevan wrote: |
hello,
Have you adjusted the shift plate? And how are you shifting? Because of the length of the shift rod I'm slower to shift in my Bus than my Ghia or any other manual car I've owned. It's curious that double clutching doesn't help too. It really should. Where did you learn the technique? _________________ |
SGKent Samba Member
Posted: Tue Dec 12, 2017 2:35 pm Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
the stop plate might be broken also. It commonly breaks on the 3rd gear side. If that isn't it then shift slower. Mark the position of the stop plate and cover before removing it. Also check the bushing for the shift tube nose, and the tightness of the shift cage.
They break where the red arrows are:
. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16958 Location: San Diego, California
Posted: Tue Dec 12, 2017 8:44 pm Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
Rebuild time, sorry. I’ve been there before. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Tue Dec 12, 2017 9:14 pm Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
aeromech wrote: |
Rebuild time, sorry. I’ve been there before. |
Are you volunteering, aeromech? . The OP is also in Sandy Eggo... |
Posted: Tue Dec 12, 2017 9:25 pm Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
Sure but I won’t be open for a couple months _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue Dec 12, 2017 11:12 pm Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
Thanks for the replies,
I didn't get out there today to work on it, hopefully tomorrow.
to sum up the suggestions, or maybe to ask for clarification and consensus, is it possible to get grinding in just one gear due to sloppy linkage or maladjusted clutch cable or shift lever?
or is all grinding inherently a syncro issue?
obviously I'm hoping for an easy fix, but I can take the news if that is not ever as cause of grinding
on a hopefully unnecessary side note, what does it cost to rebuild one of these late bay trans?
thanks for helping, i appreciate it |
SGKent Samba Member
Posted: Wed Dec 13, 2017 7:52 am Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
grinding can be a synchro or the wrong oil (too slippery). It can also be that the wrong gear is being engaged. Synchro would be the first suspect because it spins the gear up to the same speed before the hub locks it. GL4 gear oil is the preferred gear oil because GL5 and synthetics can contaminate moly coated synchro rings and make them too slippery. Also shifting slower can help a little too. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Dec 13, 2017 8:02 am Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
A few years ago my buddy Dan and I went together to flip this 1978 bus
It would gear grind when shifting from second to third.
The rebuild cost us about $850 as I recall
You can bet we tried all options before pulling that transmission
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Samba Member
Posted: Wed Dec 13, 2017 8:08 am Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
Gary - you are so lucky to be near Eric. He is a great transmission builder. To others - when Rick Long closed up shop he told me that Eric is the best in the business these days. http://www.transworks.biz/ _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Dec 13, 2017 8:11 am Post subject: Re: grinds only into 3rd, could it be something other than syncro? |
SGKent wrote: |
Gary - you are so lucky to be near Eric. He is a great transmission builder. To others - when Rick Long closed up shop he told me that Eric is the best in the business these days. http://www.transworks.biz/ |
He's got one of mine in work right now
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
