Tom K. Samba Member
Joined: March 10, 2005 Posts: 1605 Location: Central Pennsylvania
Posted: Tue Dec 12, 2017 8:55 am Post subject: CV Joint Analysis (Picture) |
Have been hearing an annoying gristle sound from the rear of my 1970 IRS Beetle when coasting (with or without brakes depressed). Crawled under to check the four CV joints and detected some play in the the driver side outside axle. Pulled the axle and removed the CV joint. The balls are pearly smooth but the outside races have distinct grooves - all six. the inside races too. Here is a picture.
What do you think? Bad enough to replace? I can afford the $65 from jbugs but am trying to keep the China to German part ratio to a minimum. Any advice here would be welcome. _________________ '91 Vanagon Westfalia
'70 Beetle Convertible
'71 Super Beetle Semi-Automatic: https://www.thesamba.com/vw/forum/viewtopic.php?t=714131&highlight=
'65 Ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=762478&highlight= |
Zundfolge1432 Samba Member
Posted: Tue Dec 12, 2017 9:02 am Post subject: Re: CV Joint Analysis (Picture) |
Cannot tell from pics how deep are grooves? If really deep and you are bucks down look for good used buy the new boots and rebuild. Lately I get the impression people are afraid to tackle this job. If money is not a concern buy the Lobro German replacements. On the extreme you could upgrade to the larger type 2 CVs. There are still piles of good used cv joints gathering dust |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Tue Dec 12, 2017 9:38 am Post subject: Re: CV Joint Analysis (Picture) |
Waayy-sted +
Avoid the asian krap.
Tom K. wrote: |
...... hearing an annoying gristle sound ..... detected some play in the the driver side outside axle. ....... the outside races have distinct grooves - all six. the inside races too.
What do you think? Bad enough to replace? I can afford the $65 from jbugs but am trying to keep the China to German part ratio to a minimum. Any advice here would be welcome. |
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Tom K. Samba Member
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Tue Dec 12, 2017 10:43 am Post subject: Re: CV Joint Analysis (Picture) |
It looks shot to me.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Tue Dec 12, 2017 2:46 pm Post subject: Re: CV Joint Analysis (Picture) |
They're toast. _________________ 1960 Ragtop w/Semaphores "Inga" |
shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Tue Dec 12, 2017 3:28 pm Post subject: Re: CV Joint Analysis (Picture) |
I'm into the same job. Bought all nos cv joints. I would go ahead and replace them since you already have them out. There seems to be plenty of quality joints around. _________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
gt1953 Samba Member
Posted: Tue Dec 12, 2017 3:29 pm Post subject: Re: CV Joint Analysis (Picture) |
They are defective....Orielly's has lifetime replacements the complete shafts. I have them on my car for oh um eight thousand miles. No problems. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Mudpump Samba Member
Posted: Tue Dec 12, 2017 4:17 pm Post subject: Re: CV Joint Analysis (Picture) |
Good rule of thumb is if you can feel it it's shot. I would shop around for some Lobro CV's |
mark tucker Samba Member
Posted: Tue Dec 12, 2017 4:49 pm Post subject: Re: CV Joint Analysis (Picture) |
the empis offroad cv's are some of the best made....I havent a clue as to the std stuff.but I would relay worry about it but i would make sure everything is right. for some reason those dont look like something was right... but if thats all assembles right and thay dont travel any more than that you could flip it and have a new serface to wear out... witch if I had to have it going and didnt have time to wait I would do.(if thats flip able I dont recall but I think it is)....brain fade....too many cv's rolling around in my head. and I aint no cv exspurt.... |
slalombuggy Samba Member
Posted: Tue Dec 12, 2017 7:58 pm Post subject: Re: CV Joint Analysis (Picture) |
On CVs if you can even see grooves they're finished.
Ya mark, I've flipped CVs before to get a few more miles out of 'em but it's only a bandaid. Works the best on vans where the axle angles are a little greater.
brad |
vwoldbug Samba Member
Posted: Wed Dec 13, 2017 11:37 am Post subject: Re: CV Joint Analysis (Picture) |
Are you getting a klunk klunk klunking noise or a growling noise especially on curves or corners . |
Danwvw Samba Member
BUGGED11111 Samba Member
Joined: February 03, 2006 Posts: 1819 Location: Oregon
Posted: Wed Dec 13, 2017 4:35 pm Post subject: Re: CV Joint Analysis (Picture) |
I wonder if a "Loebro" is the same as a Lobro or is that how you say hello to your bro
cbeck Samba Member
Posted: Wed Dec 13, 2017 5:46 pm Post subject: Re: CV Joint Analysis (Picture) |
gkn lobro 45.79 each at rock auto
https://www.rockauto.com/en/cart/ _________________ shakers73
'74 Super Beetle
'67 Beetle
Danwvw Samba Member
TX2IAgirl Samba Member
Joined: April 23, 2018 Posts: 2 Location: San Antonio, Texas
Posted: Tue May 15, 2018 7:32 pm Post subject: Re: CV Joint Analysis (Picture) |
The boot for the inner passenger side has a huge tear in it. I will need to replace it. Can it be replaced without having to take the shaft or trans out? What would you recommend for a 71 standard beetle? |
mukluk Samba Member
Posted: Tue May 15, 2018 7:38 pm Post subject: Re: CV Joint Analysis (Picture) |
TX2IAgirl wrote: |
While I do believe there are split boots available for type 1 CV joints, they usually don't hold up well at all so I would recommend sticking with the original one piece style boots. As such, you will need to disconnect the axle shaft at the inner end at a minimum so you can pull the CV joint off and replace the boot; if you haven't cleaned and repacked the CV joints in quite some time, this would be the perfect opportunity to do so. Removing the trans is not required. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue May 15, 2018 8:06 pm Post subject: Re: CV Joint Analysis (Picture) |
Unfortunately, you’ll need to remove the CV joint. It’s not that difficult a job, if you have the proper tool to loosen the bolts.
Be sure to clean out the bolt heads squeaky clean before attempting to remove them.
You have to remove them because you have a tear and you need to check for damage to the joint. Also, it’s a lot easier removing the joint when the shaft is placed in a vice.
Richard O'Brien |
