DanHoug Samba Member
Joined: December 05, 2016 Posts: 4799 Location: Bemidji, MN
Posted: Tue Dec 12, 2017 10:30 am Post subject: low pressure OEM style coolant cap available? |
this talk of blowing senders out got me thinkin' and Googlin' to no avail...
is there a low pressure version of the Blau cap available? it seems the pressure tank deforms right around the OEM cap pressure of 15psi and many have blown the sender or other hoses. i'd love to drop my system pressure down to 7psi.
i know the RMMW aluminum tank is the answer, with the cap PSI of your choice.
-dan |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Tue Dec 12, 2017 10:48 am Post subject: Re: low pressure OEM style coolant cap available? |
the black caps are lower pressure.
what pressure does your system run at? _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Tue Dec 12, 2017 10:49 am Post subject: Re: low pressure OEM style coolant cap available? |
have a new blue Blau, so whatever pressure the OEM one runs. anyone have a PN on the black one?
-dan |
yiucycle Samba Member
Posted: Tue Dec 12, 2017 11:17 am Post subject: Re: low pressure OEM style coolant cap available? |
Just remember if you run lower pressure cap, you also lower your coolant boil over temperature too and overheat your engine. _________________ 1980 2.8LV6 Fiero ASI/Riviera Vanagon
"there is no point in being embarrassed of all the stupid shit i done and will continue to do"
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Tue Dec 12, 2017 11:47 am Post subject: Re: low pressure OEM style coolant cap available? |
The cap is somewhat (crudely) adjustable by removing the fitting that holds the valve and spring together. Weakening the spring will lower the operating pressure. Trial and error - best done with an old spare cap.
I did not know that the black caps were lower (my 84 came to me with a black cap, possibly original). |
Posted: Tue Dec 12, 2017 12:04 pm Post subject: Re: low pressure OEM style coolant cap available? |
at a 60% glycol solution, we have the following boil temp/pressures:
16psi = 273F
8psi = 253F
given that the design of the pressure tank is flawed with respect to withstanding pressure, i'd say you run greater risk of a system failure by blowing the tank/sensor than you do dropping the BP 20F.
interestingly, the ruptures seem to occur at idle suggesting the idle speed recirculatory volume is too low. plenty of cool coolant in the rad, just can't bring it in fast enough.
soooo.... a slightly fast idle along with a low pressure cap seems to make sense. or maybe just a fast idle is enough. a snap action spst thermostat, bonded to a coolant hose, and tied into the PS switch might not be too stupid.
-dan |
tencentlife Samba Member
Posted: Tue Dec 12, 2017 12:26 pm Post subject: Re: low pressure OEM style coolant cap available? |
I have seen systems where coolant at the heads was actively spot-boiling at idle when the cap held only 6psi. As yiucycle noted, peak coolant temp is regulated by system pressure. In fact, the glycol only provides 1/3 of the elevation in boil point, system pressure is responsible for 2/3rds. There's a reason it's commonly called "anti-freeze" rather than "anti-boil", the ambient boil-point increase in a 50/50 mix is pretty small.
You'll see people who claim they run a no-pressure system with glycol/water (as opposed to straight glycol, which can work because straight glycol boils at over 360ºF.) and they claim it never boils over, so all is good. Right? Wrong. Just because the overall mass of coolant isn't boiling enough to keep expelling liquid from the system doesn't mean it isn't actively spot-boiling at the heads (to believe that, one would need to believe that coolant temp is the same everywhere in the system, but of course if that were the case there would be no cooling effect whatsoever). Vapor formation at the heads radically lessens the amount of heat being absorbed by the coolant, so coolant temp is actually lower, while the heads are actually running hotter. And the coolant's boil point is now only about 225ºF, rather than the 240º+ it would be under containment, and the critical temp runs right in that range. And because of the very uneven cooling, the heads develop stresses which can hasten cracks and warping.
But the gauge says the engine's running cool, even cooler than normal, so all is well. NOT. But it doesn't keep blowing coolant out the filler. SO WHAT? It only has to expel the small amount the vapor bubbles displace one time, and after that, unless the boil rate increases, there will be no more liquid lost. But don't the vapor bubbles entrain with flow and collect in the top of the radiator, and then displace coolant out of the filler? Of course not, the bubbles are water vapor (aka "steam") which turns back into liquid water as it cools, and the radiator is real good at cooling things. Contrast that with a fire ring leak where the combustion gas mixture, although partly water vapor, is mostly inert N and other trace gasses which will remain gas, that's why fire ring leaks displace more and more coolant, but spot-boiling doesn't.
Your system will actually run at about 10psi at normal temps, leaving 4psi headroom before release of pressure. Every component in the system in good nick can easily contain much higher pressures. Lowering system pressure is not how to avoid problems, having a good tight system without unduly aged components, a radiator with sufficient heat rejection capacity with fan that assists at the appropriate times, and a working cap that limits peak pressure are all that's needed. Oh, and a pump to move it all around.
I agree the OEM plastic caps can be problematic in several ways and being able to switch to a more sturdy and common bayonet-style dual-action cap is reason enough to get the RMW or similar tank. But deliberately reducing system pressure is, in my oh-so-humble opinion, just trading a headache for an upset stomach. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Tue Dec 12, 2017 12:35 pm Post subject: Re: low pressure OEM style coolant cap available? |
good points, Chris. the spot boiling at the heads, with it being reabsorped as the steam cools freaks me out and is total justification to keep the pressure up.
maybe we just need a coolant booster pump that is tied to the throttle idle switch! actually, i'd prefer the simpler approach like i had on my old Fiats... a throttle lock knob next to the choke knob that allowed you to set the idle at whatever you wanted.
-dan |
Posted: Tue Dec 12, 2017 1:03 pm Post subject: Re: low pressure OEM style coolant cap available? |
Personally I would rather boil a bit of coolant from time to time than to blow a hose or fitting. Over the many hundreds of thousands of miles my family has driven these vehicles, I am sure I have dumped my coolant at least ten times when some hose or fitting or tank blew up. Heads crack no matter what happens, so I am not worried at all about any slow damage that might occur when compared to the instant death that very likely will occur when a coolant manifold or other piece fails all at once.
From memory I have had the following parts fail:
3 hoses, two being large and one small one for the oil cooler
2 coolant towers/manifolds
2 or 3 times that ends blew off of the coolant pipes
2 cracked pressure tanks, one failed suddenly and cause extensive leaking
1 expanded pressure tank where the cap blew off
1 level sensor blew out of tank
For myself I will run a low pressure cap from this point on as I have done for the last two years on my 83 1/2, thus the worry about a sudden loss of coolant is greatly lessened.
On the '91 that I converted to a Subaru maybe ten years back now and replaced the long pipes with stainless steel, zero leaks so far. |
Posted: Tue Dec 12, 2017 1:11 pm Post subject: Re: low pressure OEM style coolant cap available? |
Dan, I have an extra switch on the dash that runs the rad fan at low speed on demand, it's great for off-roading, or to cool down the rad a bit extra as I near home so the fan won't end up running after shutdown. Since it's Digifant the switch also patches 12V to one of the two aux inputs (AC and PS) to the ISCU. That raises idle speed about 50rpms, to increase coolant flow rate a bit. Put a diode into the trigger line so those functions don't back-trigger your fan switch.
As stock, the rad fan runs after shutdown to control the pressure spike when coolant within the engine envelope soaks heat after flow stops. Lowering the rad temp reduces average system temp and hence pressure, offsetting the local temp rise in the engine, for a lower overall rise in pressure. Not a big deal in the short term, but over time the number of pressure spikes system components experience have a cumulative effect on strength. So on warmer days, when I think about it, I switch my fan on when I'm almost home.
The 2nd or 3rd fan speeds on vans that have the 450w fan are both switched by relays, so it's easy to use a low-amp switch to just trigger either relay (although a diode may need to be used so you don't back-trigger some other circuit, it depends on your approach). To aux switch low speed, you pretty much need to put a relay into the large feed wires so you can use a low-amp switch at the dash. Slightly more complicated but no biggie if you know your way around a wiring diagram and have basic electric skills. Low-amp switches and relays are cheap, quality big-amp switches are not, and you don't want to be running fat wires back to a dash switch.
I used to just trigger the 2nd speed relay, but it was too much cooling, and loud as well, so I did the extra effort to switch the low speed cuz it can just be left on when I'm off-roading and the noise is much less. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
