bug me Samba Member
Posted: Tue Dec 12, 2017 5:20 pm Post subject: what size will fit in 64 bug ?? |
I'm thinking of replacing the engine in my 64 bug. If I decide on going with a long block what size will fit into a 64. from what I've read some long blocks are a very tight fit . So before I can do anything more I'd like to know what fits.. any info on what works or what dosent work would be helpful. Thanks |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Tue Dec 12, 2017 5:25 pm Post subject: Re: what size will fit in 64 bug ?? |
There is no set size. It's how it was built. Wider engines don't easily fit. I can build a 1600 with long rods and get a wide engine. A short rod engine with B or C pin height pistons would make a 2L+ engine narrower than stock. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Tue Dec 12, 2017 6:17 pm Post subject: Re: what size will fit in 64 bug ?? |
I've seen 2276cc engines in ovals, so if you build it to fit... it can be done.
1954 2276cc
_________________ Glenn
Member #1009
#BlueSquare |
boxkiteflyer Samba Member
Joined: May 22, 2008 Posts: 261 Location: Taylorsville, KY
Posted: Tue Dec 12, 2017 7:47 pm Post subject: Re: what size will fit in 64 bug ?? |
I have Cima 90.5 P/Cs, Berg 190 VW rods and Berg 69mm crank for my 1776. With dual Kads it was a little tight. Had to get smaller air filters to close the lid. All in my '59 Type I |
carcrazed Samba Member
Posted: Wed Dec 13, 2017 5:30 pm Post subject: Re: what size will fit in 64 bug ?? |
boxkiteflyer wrote: |
Same here, but you can build pretty much any large size and get it to fit. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
