Joannekay Samba Member
Joined: September 18, 2016 Posts: 274 Location: Brightwaters
Posted: Fri Dec 15, 2017 7:25 pm Post subject: Re: New engine build by ladies |
Posted: Fri Dec 15, 2017 7:27 pm Post subject: Re: New engine build by ladies |
Thanks guys
Bracket amended.
Thermostat tested
Installed |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Fri Dec 15, 2017 7:37 pm Post subject: Re: New engine build by ladies |
Helfen wrote: |
All new rotating parts must be balanced if you want a reliable engine. Heck my last NEW set of Mahle pistons were 20 grams apart! |
The Moresa pistons I used in my 1600cc rebuild last year were MUCH closer than that, actual value is somewhere in my thread https://www.thesamba.com/vw/forum/viewtopic.php?t=664950&highlight=resurrection+1970
I weighed the pistons together with the wrist pins they shipped with, they were so close that I didn't have to mess with adjusting the wrist pins from one piston to another. I seem to remember that they were all +/- 0.10 gram from the mean; I used an electronic balance discarded from my workplace as some were deemed too expensive to re-qualify. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Fri Dec 15, 2017 8:16 pm Post subject: Re: New engine build by ladies |
Danwvw wrote: |
Well it's a stock rebuild with a stock crankshaft which you can't do much with as far as balancing the crankshaft. |
I took my crank, flywheel, pressure plate, pulley, and rods to get balanced locally when I built my current bus engine, and the shop owner told me the crank was the most out of balance part in the whole schlab.. he did balance it all out and said he had to take a good bit off the crank, which was a stock 69mm std/std. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Fri Dec 15, 2017 9:13 pm Post subject: Re: New engine build by ladies |
Look, I and some of us are saying that balancing the rotating assembly is part of a sound rebuild and every reputable shop will tell you this. We don't say this to be mean or cause disruption or to be disparaging in any way. Some of us say this because we've seen the results of misguided advise. I've been in this business for over 50 years. I have nothing to win or loose in this. It's just free sound advise. Joannekay, did you even look at the you tube link I provided?? |
Danwvw Samba Member
Posted: Fri Dec 15, 2017 10:11 pm Post subject: Re: New engine build by ladies |
A counterweighted crank will reduce the wear and tear on the case more than just balancing the standard crank not that balancing is not a real nice thing to do for your engine. I always do. With the cost of a new case being so high I figure counterweight crankshaft, full engine balance and full flow filtered oiling is the best way to protect the case's value. But they originally ran well and for a long time.
That engine looks like it was a 1300cc to start with?
Nice! Don't forget the 8mm nuts there:
This would be sweet:
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Fri Dec 15, 2017 10:26 pm Post subject: Re: New engine build by ladies |
Helfen thanks but as I said NO MACHINE shop local or close.. |
Posted: Fri Dec 15, 2017 10:42 pm Post subject: Re: New engine build by ladies |
Thank u on nuts
Engine was a 1500...
Petrol filter bracket installed.
Safety first.. |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
notsnarb Samba Member
Posted: Sat Dec 16, 2017 9:34 am Post subject: Re: New engine build by ladies |
flyboy161 wrote: |
Joannekay wrote: |
Safety first.. |
THAT is a VERY cool bracket!! Where did you get it, or did you make it? |
here on samba:
https://www.thesamba.com/vw/classifieds/detail.php?id=2062082 |
Posted: Sat Dec 16, 2017 2:25 pm Post subject: Re: New engine build by ladies |
A friend from calafornia...not available in Australia |
Posted: Sun Dec 17, 2017 11:07 pm Post subject: Re: New engine build by ladies |
Heater exchange just about done..after market....had 2 use tomatoe paste can 4 large gap
Carby installed.
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Mon Dec 18, 2017 11:31 am Post subject: Re: New engine build by ladies |
Don't forget to slide the accelerator cable through. It can be difficult once everything's in. Also looks like you went with a 30 pict 1 instead of the h30/31? Agree , nice work !
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
That looks clean enough to eat off of it!
Does that fuel pump sit okay with the alternator without interference? _________________ Jesucristo es mi Señor y Salvador! |
Posted: Mon Dec 18, 2017 12:36 pm Post subject: Re: New engine build by ladies |
Looks like there’s enough room 4 petrol pump & alternator..thank u..
Posted: Mon Dec 18, 2017 12:43 pm Post subject: Re: New engine build by ladies |
Petrol pump close to generator on old engine..
Posted: Mon Dec 18, 2017 12:44 pm Post subject: Re: New engine build by ladies |
Thank u..will try accelerator cable 2day.. |
Posted: Mon Dec 18, 2017 2:01 pm Post subject: Re: New engine build by ladies |
I think this is what an "Engine build sponsored by Mid America Motorworks" would look like! _________________ Robert in Memphis
