Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Sat May 26, 2018 8:18 am Post subject: Re: New engine build by ladies |
Have you tried filling the carb float bowl with fuel first? With that the engine should run a minute or more causing the fuel pump to prime up.
If you do disconnect any wire from the coil, pull the small one going to the distributor. The other small wire at the cable is not fused. So that wire happens to ground while you turn the engine over, it can fry the wiring harness. _________________ In Stereo, Where Available! |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat May 26, 2018 10:43 am Post subject: Re: New engine build by ladies |
Check your fuel lines at the pump are not backwards. The top bib is the in, the bottom bib is the out, and goes to the carb. It's hard to see in the picture but I think it's backwards. |
Joannekay Samba Member
Joined: September 18, 2016 Posts: 274 Location: Brightwaters
Posted: Sat May 26, 2018 1:50 pm Post subject: Re: New engine build by ladies |
Thank u..yes in & out right..
Posted: Sat May 26, 2018 1:59 pm Post subject: Re: New engine build by ladies |
Shorten up the flexible fuel lines between the fuel pump and carb. Metal fuel line should not be touching other pieces of metal, like the fan shroud. Metal pieces vibrating will rub and cut holes in each other. _________________ In Stereo, Where Available! |
Posted: Sat May 26, 2018 2:04 pm Post subject: Re: New engine build by ladies |
Ok yep that's right. I couldn't see they crossed behind the distributor in the other picture.
You can try to put your hand over the carb throat when someone cranks the engine. If you block the air, the carb will pull a huge vacuum and help pull the gas through the pump and gets the air block out. |
Posted: Sat May 26, 2018 2:10 pm Post subject: Re: New engine build by ladies |
Thank u heaps..great advice..will do both this morning.. |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Posted: Sat May 26, 2018 4:55 pm Post subject: Re: New engine build by ladies |
Pruneman99 wrote: |
That's a great tip! Be careful when fuel reaches carb, this mega-choke method will flood the engine in just a few seconds. _________________ Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231 |
Posted: Sat May 26, 2018 5:07 pm Post subject: Re: New engine build by ladies |
Wayne S. Johnson wrote: |
Pruneman99 wrote: |
That's a great tip! Be careful when fuel reaches carb, this mega-choke method will flood the engine in just a few seconds. |
Yeah just do it for a second or two at a time. Fuel pumps don't like to pump air. Once the carb pulls hard enough to get fuel pumping and the air block moving, it will pump normally. |
Posted: Sat May 26, 2018 5:32 pm Post subject: Re: New engine build by ladies |
We install fuel bracket but it doesn’t look like.
Help please..
Posted: Sat May 26, 2018 5:36 pm Post subject: Re: New engine build by ladies |
What's the question? |
Posted: Sat May 26, 2018 5:37 pm Post subject: Re: New engine build by ladies |
Have we got it on wrong angle..is there 2 much air in filter. |
Posted: Sat May 26, 2018 5:41 pm Post subject: Re: New engine build by ladies |
Joannekay wrote: |
Filters are rarely full, and during warm weather they can look empty while the engine keeps on running. _________________ In Stereo, Where Available! |
Posted: Sat May 26, 2018 5:42 pm Post subject: Re: New engine build by ladies |
Thank u |
Posted: Sat May 26, 2018 5:47 pm Post subject: Re: New engine build by ladies |
Mine is never full. I gave up trying to find out why years ago. I've never had fuel starvation issues, so I've elected to ignore it |
Posted: Sat May 26, 2018 7:53 pm Post subject: Re: New engine build by ladies |
We are having trouble removing hose..very tight..won’t budge.. |
Posted: Sat May 26, 2018 7:57 pm Post subject: Re: New engine build by ladies |
Will do.. |
Posted: Sat May 26, 2018 8:57 pm Post subject: Re: New engine build by ladies |
Hose off no fuel with hand crank.. |
