Joannekay Samba Member
Joined: September 18, 2016 Posts: 274 Location: Brightwaters
Posted: Wed Aug 01, 2018 9:30 pm Post subject: Re: New engine build by ladies |
Pushrod tube problems.
Stock 1600 to long.
All forums suggest not to use adjustable..heat issues.
Ordered 40 hp pushrod tubes..
Posted: Fri Aug 10, 2018 4:40 pm Post subject: Re: New engine build by ladies |
Pushrod tubes fit
Forgot rtv...thank u Wayne.
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Fri Aug 10, 2018 7:19 pm Post subject: Re: New engine build by ladies |
In this image, the tip of the adjuster is offset from the center of the valve, you can also see the shim between the rocker & the mount block. Remove the rocker shaft & put the shim on the outside so that the adjusters are as close to centered on the valve as possible.
I would also address the head stud that’s protruding so close to the intake rocker.
Final valve adjustment may not be done, but all of the adjusters should be closer to being level with each other. You may want to be sure that all of the pushrods are seated properly. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Aug 10, 2018 7:57 pm Post subject: Re: New engine build by ladies |
Thank u tdctdi..
When I put extra shim on end...it’s firm.
But will reshim.
Also other concern..head studs to close to rocker arm assemble.
Will shorten stud.
Will also double check pushrod seated correctly..
Again thank you for your help.
Rest day....good to have a break.. |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Sat Aug 11, 2018 3:44 am Post subject: Re: New engine build by ladies |
TDCTDI wrote: |
... so that the adjusters are as close to centered on the valve as possible. |
I have always read to slightly offset the rocker arms on the valve tips to encourage valve rotation. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Sat Aug 11, 2018 4:31 am Post subject: Re: New engine build by ladies |
scrivyscriv wrote: |
TDCTDI wrote: |
I have always read to slightly offset the rocker arms on the valve tips to encourage valve rotation. |
Key word being slightly. When a third of the adjustment screw hangs off the side of the valve tip, you will get an adjuster that is worn unevenly. This will cause failure of the adjuster & make it a real bitch to get a proper adjustment the next time the valves need to be adjusted. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Aug 11, 2018 4:35 am Post subject: Re: New engine build by ladies |
Joannekay wrote: |
Thank u tdctdi..
When I put extra shim on end...it’s firm. |
Just move the shim between the rocker & the stand to the other side of the rocker arm. You definitely don’t want to add another if it’s causing binding. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
REDKAFER Samba Member
Posted: Mon Aug 13, 2018 7:20 pm Post subject: Re: New engine build by ladies |
I gotta say, while in the middle of building up my 1600 for the first* time, I see the photos of your shop and the work you do, and I get huge gobs of motivation to get my merde together and wrench like hell. Keep kicking ass, I love it.
* - First time with adult levels of care and patience. I've had the car for 15 years, and it took me 12 of those to get as serious and appreciative as you folks. |
Posted: Fri Aug 17, 2018 11:54 pm Post subject: Re: New engine build by ladies |
Thank you redkafer for that lovely comment...
Still troubles tdctdi....
Shortened head studs
Rocker arm shaft & mounting blocks no room before spaces or shims.
Any ideas please.
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Posted: Sat Aug 18, 2018 12:06 am Post subject: Re: New engine build by ladies |
I thought a spacer or shim is required on both sides rocker arm & mounting block.. |
Posted: Sat Aug 18, 2018 12:08 am Post subject: Re: New engine build by ladies |
Pushrods new for a 1600.
Rocker studs not touched.. |
Greg Ward Samba Member
Posted: Sat Aug 18, 2018 2:48 am Post subject: Re: New engine build by ladies |
They aren't stock parts which makes things more difficult, the rocker assemblies are bolt together solid shaft aftermarket ones not stock with clips, so the shaft itself and the blocks that hold it may be bigger in diameter too.
Stock setup has the 4 clips and shims with wavy washers in between, on your setup, you need to shim each rocker properly, the two inlet rockers have a massive gap, they should all end up roughly the same gap, and to achieve that you will probably need to buy a shim kit, unless your kit has enough different width shims to get it set up correctly. You should end up with shims of different widths on each side of each rocker, it is ok to have more than one shim per side, but not none.
The rockers should move nice and freely up and down without any binding, but you also don't want so much clearance that you can "clack" them side to side.
Also, hard to see exactly, but it appears those pushrods you have are steel or chromoly, definitely not stock, they are normally made longer for stroker engines, which would also explain the need for shims and messed up geometry from stock.
I never use steel or chromoly pushrods in any engine after finding out what they do, you need to get a set of standard length aluminium pushrods just as the factory intended for a stock build.
I think if you put stock pushrods in it, shim your rockers side to side properly, and disappear all shims underneath the rocker stands you will be back close to where it all should be.
Proper rocker arm geometry needs to be checked at 1/2 total valve lift, your adjuster screw should show a nice straight shot through the valve stem at half lift, that is what you are aiming to get closest to.
Cheers,
Greg |
Posted: Sat Aug 18, 2018 3:40 am Post subject: Re: New engine build by ladies |
Thank you Greg for your reply.
The pushrods are chromoly stock..
Will purchase aluminium.
Again..thank you |
&Dan Samba Member
Posted: Sat Aug 18, 2018 8:47 am Post subject: Re: New engine build by ladies |
Careful, thoughtful assembly in such nice, clean conditions. Keep it up, engine's going to be a real winner. |
Posted: Sat Aug 18, 2018 3:05 pm Post subject: Re: New engine build by ladies |
Will sand rocker mount...
Posted: Sat Aug 18, 2018 5:12 pm Post subject: Re: New engine build by ladies |
Check performance stock rockers
Sand mounting block information
Posted: Sat Aug 18, 2018 11:45 pm Post subject: Re: New engine build by ladies |
No Problem,
I've never tried buying "new stock length" aluminium pushrods, even if they exist, I have a decent stash of old perfectly useable german AL pushrods.
If you want me to clean you up a set, then PM me and I'll be happy to help.
The reason you don't want steel/chromoly pushrods is that they won't expand when your engine gets hot like VW intended.
Magnesium case, Cast iron cylinders and Aluminium heads, the reason for AL pushrods is because they expand at a closer rate to the heads and keep your valve lash as close as possible to cam specs.
I ran Chromoly pushrods back in 1994 in a Hillclimb race, the cam was specced to .008" and .010", inlet lash and exhaust.
I lost all power from my race engine half track when it got hotter, checking the lash with steel pushrods, it was .024" on most of them, so a sparkplug gap was my lash setting.
Never again.
Steel/Chromoly pushrods are a 12sec or less dragrace only item...never to be used seriously on a street engine.
Cheers,
Greg |
