Joannekay Samba Member
Joined: September 18, 2016 Posts: 274 Location: Brightwaters
Posted: Sun Aug 19, 2018 2:48 pm Post subject: Re: New engine build by ladies |
Spent the day hand sanding shaft mounting block just to move it a tad over but
Will take forever for the 4 of them.
Decided to try new rocker mount with narrow nylon washer.
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Sun Aug 19, 2018 6:00 pm Post subject: Re: New engine build by ladies |
Before you sand them all, try swapping them around to see if any fit better in other locations. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Aug 19, 2018 6:16 pm Post subject: Re: New engine build by ladies |
Thank you tdctdi but tried every which way & then some more.
They seem to be a problem with lots of folks.
Fingers crossed new rocker shaft mounts fit with original pushrods kindly purchased from Greg Ward in Australia.
Aftermarket new build challenging. |
Posted: Sun Aug 19, 2018 7:05 pm Post subject: Re: New engine build by ladies |
Head stud trim
Posted: Sun Aug 19, 2018 9:32 pm Post subject: Re: New engine build by ladies |
Moving along
Jack strap fantastic for us older folks
Posted: Mon Aug 20, 2018 3:12 am Post subject: Re: New engine build by ladies |
It appears that your missing the lower air deflector on the #3/4 cylinders & the little square metal one on the #1/2 head. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Aug 20, 2018 4:40 am Post subject: Re: New engine build by ladies |
Thank you tdctdi
Good pickup..
Yes there is 1 missing..
Ordered now...cheers.. |
Posted: Mon Aug 20, 2018 5:14 am Post subject: Re: New engine build by ladies |
Just don’t go much further, you have to remove the cylinder head to get it on. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Aug 20, 2018 5:48 am Post subject: Re: New engine build by ladies |
Thank you. |
Posted: Mon Aug 20, 2018 3:13 pm Post subject: Re: New engine build by ladies |
The reason to use original pushrod & tubes.
Damage after engine ran for 22 seconds
REDKAFER Samba Member
Posted: Mon Aug 20, 2018 4:18 pm Post subject: Re: New engine build by ladies |
Well that sure is a drag. I hope no damage was done outside the pushrods, at least they are not a massively expensive component... |
Posted: Mon Aug 20, 2018 8:06 pm Post subject: Re: New engine build by ladies |
Thank you redkafer
All good..
Extra checking this time
Posted: Wed Aug 22, 2018 11:15 pm Post subject: Re: New engine build by ladies |
While waiting for post man
We made a start bench stand
Then the post man arrived
Thank you again tdctdi..
On our way again.
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Thu Aug 23, 2018 6:51 am Post subject: Re: New engine build by ladies |
Joannekay wrote: |
That's handy. If I may make some recommendations in the interest of your safety:
1) Discard the cheap spring-loaded clips on the battery connections, which are prone to sparking and poor conductivity, and replace them with real battery cables, which can carry some current, and;
2) Perhaps don't have the battery (which could produce sparks) so darn close to the fuel canister (which can erupt in a ball of fire).
I can appreciate the effort that went into making the setup so compact, but sometimes safety should really take precedence.
Good luck! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Aug 23, 2018 8:05 am Post subject: Re: New engine build by ladies |
Bet that the clamps on the battery are from a charger.
Find a gas tank from a junk lawn mower to use for the setup. Less fuel to cause a problem if something goes wrong, less volume in the tank to have gas fumes in. Has a hose outlet so the fuel line can be connected to for much less possibility of flames/explosion, and a cap to keep the fumes from just pouring out. _________________ In Stereo, Where Available! |
Posted: Thu Aug 23, 2018 8:20 am Post subject: Re: New engine build by ladies |
Eric&Barb wrote: |
Find a gas tank from a junk lawn mower to use for the setup. Less fuel to cause a problem if something goes wrong, less volume in the tank to have gas fumes in. Has a hose outlet so the fuel line can be connected to for much less possibility of flames/explosion, and a cap to keep the fumes from just pouring out. |
That one looks like a marine application that has the pick-up tube in it & one-way vent valve. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Aug 23, 2018 2:08 pm Post subject: Re: New engine build by ladies |
Thank u busstom
In the interest of safety again thank u.
We appreciate all help.
Will replace fuel tank with smaller & further away.
Thank you Eric & barb will do.
Posted: Thu Aug 23, 2018 2:47 pm Post subject: Re: New engine build by ladies |
That's interesting...perhaps what I overlooked was that you may not have your large cables hooked up yet...(of course, your starter's not on).
I thought those little cables were going to be the only ones, but now I'm guessing that those are only to power the box (and coil, etc), and you still have to put the big battery cables on. Sorry if I jumped the gun. |
Posted: Thu Aug 23, 2018 3:20 pm Post subject: Re: New engine build by ladies |
All good busstom.
Happy for input. |
