Joannekay Samba Member
Joined: September 18, 2016 Posts: 274 Location: Brightwaters
Posted: Thu Aug 23, 2018 6:39 pm Post subject: Re: New engine build by ladies |
Removed heads to install missing heat deflector
Not happy with rocker arm assembly not seating.
Rocker stud not seated enough
Removed stud..damaged & shit on thread
New stud ordered.
The small things that matter..
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Thu Aug 23, 2018 6:49 pm Post subject: Re: New engine build by ladies |
Should remove the casting flash in those heads fins for max air being able to flow thru for best cooling. Have even used a circular saw to clean the outer fins.
_________________ In Stereo, Where Available! |
Posted: Thu Aug 23, 2018 10:56 pm Post subject: Re: New engine build by ladies |
Thank you Eric & barb.
Could you please explain this process..
Original push rods
Thank you again mr Greg ward....
Much appreciate your help for our 1st build.
Quite a difference in thickness & weight.
Posted: Thu Aug 23, 2018 11:31 pm Post subject: Re: New engine build by ladies |
All good Eric & barb
Found a site that explains.
While waiting for rocker stud...on it..
Thank you for taking the time for great input..
Posted: Thu Aug 23, 2018 11:44 pm Post subject: Re: New engine build by ladies |
So many things we missed 1st build
Greg Ward Samba Member
Posted: Fri Aug 24, 2018 1:57 am Post subject: Re: New engine build by ladies |
Hi Jo,
Glad you got the bits, I'll be interested to see how the original pushrods sit and seat with the rockers.
Also, can't really see properly in that pic, but if you stand the pushrods on end next to each other, are they the exact same length?
Cheers,
Greg |
Posted: Fri Aug 24, 2018 2:47 am Post subject: Re: New engine build by ladies |
Greg exact same length just the width different.
Will post pictures when installed with rockers
Posted: Fri Aug 24, 2018 7:42 am Post subject: Re: New engine build by ladies |
Joannekay wrote: |
While waiting for rocker stud...on it..] |
Good! You also want a hole/s drilled thru any pocket that has none or a very small hole for the size of the pocket. If that is just not possible, you want to have a side hole out.
From the transporter workshop manual on the early 40 HP heads:
Posted: Sun Aug 26, 2018 11:10 pm Post subject: Re: New engine build by ladies |
Cip1..........
Bad service..
Wrong order
Only good news..they fit perfect.
Posted: Sun Aug 26, 2018 11:38 pm Post subject: Re: New engine build by ladies |
Hi Jo,
I bet if you put a straight edge on the top of those two standing up they aren't the same length?
However if they are the same length standing, I doubt they are when installed, look at the ball cup on the chromoly pushrod, the wear mark and shaped of the whole thing is so much different to the stock one.
Looking forward to some more progress pics when you get to that point.
Cheers,
Greg |
Posted: Mon Aug 27, 2018 3:06 am Post subject: Re: New engine build by ladies |
Thanks Greg..we also looking forward to finish day..
Spent a few days removing casting flash
New narrow rocker shaft mounts
Big difference in pushrod seating
Posted: Mon Aug 27, 2018 2:10 pm Post subject: Re: New engine build by ladies |
Don’t purchase from cip1
Hey there,
I'm not sure I understand. the part you received seems to be the exact part you've ordered, just with a different finish on it. I don't see anything different between what you have and what you've got from us. If you have anything besides the finish to bring to my attention however, please do.
Thanks,
Nolan P. - CIP1.com |
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Mon Aug 27, 2018 2:30 pm Post subject: Re: New engine build by ladies |
Unfortunately, you are experiencing all of the reasons with the aftermarket world why so many keep suggesting to stay with as much of the original components, such as this...
scrivyscriv wrote: |
I think this is what an "Engine build sponsored by Mid America Motorworks" would look like! |
The crappy parts places have your money & now they couldn't care less because they pretty much all get the same crappy parts. Some vendors are better, most are not. All of us have experienced this to some degree. Good for you for seeing it through & realizing that most of the comments are meant to help, not criticize. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Aug 27, 2018 3:51 pm Post subject: Re: New engine build by ladies |
So you ordered four rocker blocks and got three that appear to have been milled on one side and are thinner, and one "normal" one that has a different finish right?
If that's the case, that sucks. How in the world are you supposed to set up your rocker side play? Are the three non-zinced ones thinner as the picture make them look? Or are they just offset drilled for the stud? Either way, that sucks.
Is there no machine services where your at? Any machine shop should be able to narrow stock OG one's pretty easily. And you can have them narrowed the right amount from one, or both sides as necessary.
On another note, what's up with the nylon spacers? I've never seen them before. I'm not sure I'd trust nylon in that application but with the new plastics available, maybe it's ok ? |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Posted: Mon Aug 27, 2018 5:12 pm Post subject: Re: New engine build by ladies |
Tdctdi we are totally regretting throwing out some old original parts
Hard 1 to swallow.
Pruneman99..thank you & yes it does make a bad taste..
Will never use cip1 again.
They have threatened me this morning.
Will find machinist to remove 1mm of other new solid rocker mounts.
We won’t use nylon washer.
Wayne wish we had purchased those to start with. |
Posted: Mon Aug 27, 2018 11:04 pm Post subject: Re: New engine build by ladies |
Greg as you can see in picture.
Intake valve on 1st can’t move across until a 1mm shaved off right side of mount..also the exhaust valve on 2nd needs the same..
A few pages back on my updates lists
How many people have problems with this..they just shaved a 1 or 2mm off the
Mounts...
Posted: Wed Aug 29, 2018 3:05 am Post subject: Re: New engine build by ladies |
Aligned rocker assembly side play with cheap narrow mounts.
Solid mounts will be machined tomorrow to narrow rocker mount size.
Cip1 seen there error & sent the correct part but cheap quality. |
Posted: Mon Sep 03, 2018 1:21 am Post subject: Re: New engine build by ladies |
Installed missing heat deflector..
New rocker stud..all seated correct now.
Installed oil filter nuts ..thank you Greg.
On 1st build forget these manifold gaskets...senior moment..
Heater boxes & muffler installed.
Posted: Mon Sep 03, 2018 7:31 am Post subject: Re: New engine build by ladies |
Joannekay wrote: |
Did you remove the manifold gaskets that were in place? It appears that there are gaskets that are already crushed into place. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
