Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Tue Sep 25, 2018 5:31 am Post subject: Re: New engine build by ladies |
Very nice! I think we all do our own version of the happy dance when we bring one back to life. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Tue Sep 25, 2018 5:36 am Post subject: Re: New engine build by ladies |
i realize this has been a major source of frustration for you, but your rockers are not set up properly. the adjuster screws look to be hitting the left side and/or the center of the valve stems.
they are supposed to be offset to the right as seen in this pic. this is a top view, looking down:
The factory service book shows the alignment of the valve and valve adjusting screw from the viewpoint from BELOW the engine, looking upward at the valve train.
and you're still missing a lot of engine tin. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Greg Ward Samba Member
Posted: Thu Sep 27, 2018 3:02 am Post subject: Re: New engine build by ladies |
hazetguy wrote: |
With all due respect, there is no reference needed to a service manual, as this is not a standard engine anymore.
The minute all the valvetrain was replaced with other components that are not standard anymore means all the specs in the manual stuff is out the window.
I agree offsetting the valve tappet slightly on the valve makes a difference, and only into turning the valve for longetivity, I've had many engines where the valve collets are purposely ground for gripping the valve and this rotation never occurs anyway, no undue affects because of this.
This engines rocker gear doesn't employ wavy washers and clips as standard and the manual expects, this is now a solid rocker setup. Setup as close enough as a STD engine needs to be in my opinion.
Cheers,
Greg |
Posted: Thu Sep 27, 2018 7:36 am Post subject: Re: New engine build by ladies |
I hear what you're saying, thanks.
I guess I'm just confused as to how or why, over the past couple months, the set-up went from looking awfully darn close in this post:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8850959#8850959
to the way it looks now. yeah, i've read the entire thread several times, i guess i just don't get it.
i will be interested, if there is to be any kind of long term follow-up in this thread, how the engine performs, lasts, wears, etc. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
scdevon Samba Member
Joined: October 18, 2017 Posts: 163 Location: Rockies
Posted: Thu Sep 27, 2018 10:28 am Post subject: Re: New engine build by ladies |
The rocker tips may look centered on the OP's valve stems but unless they are perfectly centered, there will always be some valve rotation. The valve just needs to be rotated a little every once in a while. It isn't a huge deal.
Once this engine is fully dressed with tin, my suggestion would be to just drive it a while and see how everything settles in. _________________ 1970 Beetle 1600 DP |
Joannekay Samba Member
Joined: September 18, 2016 Posts: 274 Location: Brightwaters
Posted: Thu Sep 27, 2018 2:49 pm Post subject: Re: New engine build by ladies |
Thanks guys but previous rocker assembly not slightly off..
Major problem with standard aftermarket.
Before rocker mounts machined.
Order fuel tank to finish tuning before installing engine.
Posted: Sat Sep 29, 2018 11:50 pm Post subject: Re: New engine build by ladies |
We hooked mangos heart up today..
Did the oil pressure & all good @ 50psi
Had a play with carb & she runs by herself now.
Sounds a bit chattery will empty oil & check tappets.
Time to lift & put engine in..
https://m.youtube.com/watch?v=4ylVbH78vyE&feature=youtu.be |
Posted: Tue Oct 09, 2018 5:01 am Post subject: Re: New engine build by ladies |
Update
Sorry for delay...life gets in the way.
Engine in..
As we didn’t want to lift to high..we jacked up slide engine under.
Used pulley to lift engine.
Got to luv 61...no room...struggled but success..
Now just to add the missing & zoom zoom
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Tue Oct 09, 2018 7:24 am Post subject: Re: New engine build by ladies |
Totally awesome ladies, well done.
Is that Beryl Green or another colour?? _________________ .ssS! |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Tue Oct 09, 2018 9:02 am Post subject: Re: New engine build by ladies |
I'm guessing mango....
do those slippers have steel toe-caps in them |
Posted: Mon Oct 22, 2018 11:43 pm Post subject: Re: New engine build by ladies |
Thank you guys.
Yes mango & steel cap slippers x
Back to Vw ...we care 4 mum & maintain a couple of houses.
Install just about 2 finish
We ordered a 019 from Glenn ring.
I just like the sound of them & should run nice with our 30 pict 1
Just have to grab a couple of terminals & zoom zoom
Posted: Tue Dec 11, 2018 7:10 pm Post subject: Re: New engine build by ladies |
New sticker...
Time to drive this baby.. |
Posted: Sat Dec 15, 2018 10:28 pm Post subject: Re: New engine build by ladies |
Woo hoo...reversed up driveway.stalled..drove down driveway..stalled..will adjust that but this silly little button to start doesn’t seem responsive as when we bench started..
Any help please.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Sun Dec 16, 2018 10:17 am Post subject: Re: New engine build by ladies |
Is the ignition switch broken? If not, you do not need the push switch for that, it is not stock.
Wrap that coil to distributor green wire around a pencil to give it a tight curl. Then slide the pencil out of the wire spiral. That will tighten up that wire to keep it off other parts so it does not rub thru the insulation, plus it does not wiggle around so much that might break the copper strands inside over time, and engine looks neater to boot. _________________ In Stereo, Where Available! |
Posted: Sun Dec 16, 2018 1:02 pm Post subject: Re: New engine build by ladies |
TROUBLESHOOTING TEST LIGHTS USED TO TEST 12V AT COIL, STARTER SOLENOID COIL, STARTER MOTOR, OR ANY DEVICE POWERED BY 12V. THE LIGHTS CAN BE USED WITH 6V SYSTEMS USING 6V LIGHTS. ATTACH THE LIGHT WIRES AT THE LOCATION OF THE LOAD TO TEST SWITCHES AND WIRING LEADING TO EACH LOAD.
Temporarily mount two small 12V lights under the dash, ground them to chassis clean metal. Attach one to the coil ignition wire at the coil terminal. Attach the other one to the starter solenoid terminal at the solenoid.
I have wired test lights by running the wires through the window for a one time test or you could run the wires inside under the carpet and leave them installed.
The lights will show you if the device is getting 12V.
_________________ Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231 |
Posted: Sun Dec 16, 2018 1:47 pm Post subject: Re: New engine build by ladies |
Wayne S. Johnson wrote: |
Are those some special lights that will not light up if only say 11.5 volts is getting thru? Asking because we use a 12 volt dash bulb as a static timing tool, works just fine on 6 volt VWs, just a bit more yellow in color. _________________ In Stereo, Where Available! |
Posted: Sun Dec 16, 2018 2:56 pm Post subject: Re: New engine build by ladies |
I used standard lights, not intended to replace DMM.. |
Exact, best to use a voltmeter or voltage setting on a multimeter for that instead.
Last year helped someone with their well. He tore the submerged pump all out due to it not working, and I helped him replaced it. Still would not work! Turned out the wiring at the circuit breaker had corroded enough to burn thru one of the wires, but the two ends were still butted up to each other just enough to pass about 40 volts AC enough to light up a test light instead of the full 120 volts. Took about three days of work and finding the correct pump parts to boot. _________________ In Stereo, Where Available! |
Posted: Sun Dec 16, 2018 4:43 pm Post subject: Re: New engine build by ladies |
Thank you Wayne & Eric..
Have called in the auto electrician.
Prior to us buying someone installed push button.
Cheap skate...half a job.
