joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Dec 16, 2018 5:35 pm Post subject: Re: New engine build by ladies |
Looks like you need a new to you used fuse box. The one you have now is pretty much parts. The repro ones are made of plastic that does not hold up to the same high heat as the OG ones. Then clean that up with soap water followed up with vinegar soak to clean off the corrosion. A must to solder up the clips inside the fuse box to get rid of voltage drops. Need a proper fuse box clip instead of the DPO self tapping screw.
https://www.thesamba.com/vw/forum/viewtopic.php?t=261440&highlight=fuse+box+clip _________________ In Stereo, Where Available! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Joannekay Samba Member
Joined: September 18, 2016 Posts: 274 Location: Brightwaters
Posted: Mon Dec 17, 2018 9:21 am Post subject: Re: New engine build by ladies |
That axle boot will tear itself up in that position. The split should be at 3 or 9 O'clock, not 12 O'clock like it is. As is the axle flexes up and down there and the split is not as flexible as needed in that straight up position.
Also helps to push the small end in towards the transaxle about 1/4" before tightening that end hose clamp to keep the boot from over stretching when the beetle is jacked up for maintenance. This keeps the boot from over stretching and tearing. _________________ In Stereo, Where Available! |
Posted: Mon Dec 17, 2018 1:44 pm Post subject: Re: New engine build by ladies |
Thank you Eric..
Prior owners did shocking things.will fix all .
Will have a word with auto electrician ...
Appreciate all your help.
calvinater Samba Member
Joined: September 06, 2014 Posts: 3333 Location: 802 The Pointless Forrest
Posted: Mon Dec 17, 2018 3:05 pm Post subject: Re: New engine build by ladies |
Now take your mom for a ride. _________________ "Albatross"! |
Posted: Mon Dec 17, 2018 7:13 pm Post subject: Re: New engine build by ladies |
Glad to help!
Great to see you two smiling, may you have many more miles... _________________ In Stereo, Where Available! |
scdevon Samba Member
Joined: October 18, 2017 Posts: 163 Location: Rockies
Posted: Wed Dec 19, 2018 12:48 pm Post subject: Re: New engine build by ladies |
It sounds great in the second clip and the idle seems smooth and right on.
Congrats! _________________ 1970 Beetle 1600 DP |
Posted: Wed Dec 19, 2018 2:25 pm Post subject: Re: New engine build by ladies |
Thank you heaps guys.
Mum wants to wait a day or 2 lol.
Now to finish those forgotten bits.
Engine idling sweet.
Accelerator cable setup a problem.
Posted: Wed Dec 19, 2018 2:36 pm Post subject: Re: New engine build by ladies |
Will see how good the auto electrician is or eBay..
Posted: Wed Dec 19, 2018 2:39 pm Post subject: Re: New engine build by ladies |
Kind of hard to tell without our 3D glasses. Is the accelerator cable hitting the nut on the throttle shaft??
If so, what is the VW part number on the intake manifold?? _________________ In Stereo, Where Available! |
Posted: Wed Dec 19, 2018 2:45 pm Post subject: Re: New engine build by ladies |
Eric no end on accelerator cable to hold barrel in place.. |
Posted: Sat Dec 29, 2018 10:31 pm Post subject: Re: New engine build by ladies |
Model engine build while we wait 4 Xmas postage to finish..
Close match to ours
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Sat Dec 29, 2018 11:20 pm Post subject: Re: New engine build by ladies |
AWESOME! _________________ Jesucristo es mi Señor y Salvador! |
Posted: Thu Jan 17, 2019 10:58 pm Post subject: Re: New engine build by ladies |
Thank you..xx
Auto electrician spent 8hrs..all working now.
I forgot to install starter bush
Old out..new in freezer overnight
Starter Bush’s
Top left...6 v. Supplied by geno on sambo installed in bellhousing
Worked well on bench test even with crack right threw it.
Top right..12v supplied by geno..doesn’t fit starter.
Bottom right was the 1 we removed.
Stuffed & why trouble starting
Bottom left...perfect..thank you again Wayne. |
Posted: Fri Jan 18, 2019 8:32 pm Post subject: Re: New engine build by ladies |
New starter bush in...success.
Freezer didn’t help..we just beveled edge a tad.
Winning 1st kick now on start.
https://m.youtube.com/watch?feature=youtu.be&v=sXsJZrDXYGU
Next problem.
Accelerator cable & broken throttle pedal
Cable sticking..
tomsbuggered Samba Member
Joined: October 16, 2014 Posts: 417 Location: Calgary, AB Canada
Posted: Tue Jan 22, 2019 10:12 am Post subject: Re: New engine build by ladies |
Finally got through reading the whole thread, quite a journey and you stuck with it. Good on ya!
There is a wealth of knowledge on the Samba, once you filter through the advice but invaluable.
Keep at it and you'll be out the other side and cruisin' the rest of the summer. Looks like you are getting some insane hot weather!
Edit: spent Christmas Day on Lake Macquarie a couple years back. Beautifull part of the world.
Cheers. _________________ June 1956 VW Oval Beetle |
Posted: Tue Jan 22, 2019 2:26 pm Post subject: Re: New engine build by ladies |
Thank you tom..
It’s been a great journey & we feel a little more knowledge to fix our vw
Can’t wait to drive & enjoy vw feeling.
It is a sweet part of paradise Lake Macquarie..
Our little bay is sugar bay...back in the day was sugar cane farm..
