It's a play thing Samba Member
Joined: November 19, 2009 Posts: 575 Location: Dayton, Nevada
Posted: Sun Dec 17, 2017 7:01 pm Post subject: Re: Extending Front and Rear Track Width |
To widen the car will cost $ arms, axles, fender, the list goes on. they work well stock. if set up correctly they will go all kinds of places _________________ It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it... |
Metal Twister Samba Member
Joined: January 24, 2013 Posts: 405 Location: licking, MO.
Posted: Sat Dec 16, 2017 7:22 pm Post subject: Re: Extending Front and Rear Track Width |
Im playing with fabing up some tube fenders. This should fix everything as far as wheel clearence in the front as well as not having the arguments with CHP Popo about not having fenders. Been down that road to many times with the 32 and Model A. Everything gets fenders now. Will be adding spacers in the front as well.
_________________ Change is Opportunity!
Instagram=metaltwister |
Arkansauced Samba Member
Joined: November 11, 2014 Posts: 52 Location: Colleyville, TX
Posted: Sat Dec 16, 2017 6:19 pm Post subject: Re: Extending Front and Rear Track Width |
The off road guys often widen the front beam. You can buy them built that way so you don’t have to chop up the stock beam.
Haven’t seen it done in the rear without some pretty major suspension changes, aside from spacers as mentioned above. |
Hot Rod Harp Samba Member
Joined: March 02, 2008 Posts: 186 Location: Englewood, New Jersey
Posted: Wed Dec 13, 2017 10:03 am Post subject: Re: Extending Front and Rear Track Width |
Wheel spacers _________________ 74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
RinTinTin in Waldorf Astoria 1956 |
Mark Lewalski Samba Member
Joined: June 19, 2010 Posts: 406 Location: Safety Harbor, FL (Tampa Bay)
Posted: Wed Dec 13, 2017 8:36 am Post subject: Extending Front and Rear Track Width |
Looking for any information on getting a wider track on the Thing.
I'm investigating the possibility of getting the front tires and rear tires clear of the wheel wells with the fenders off. If these "mods" can be returned to original configuration, then that's preferable.
I tried a search but either there isn't any info out there or I didn't use appropriate search terms.
Thanks,
Mark _________________ '89 Vanagon GL Wolfsburg "Bluestar" (given to and owned by my son now)
'87 Vanagon Weekender
'74 Thing |
