sb001 Samba Member
Posted: Wed Dec 13, 2017 6:32 pm Post subject: Yet another electrical puzzle |
Symptoms: Occasional flickering of generator light, but always goes back off after a few seconds-- been happening for a few weeks now
Driving at night, headlights randomly suddenly GROW BRIGHTER and then dim again, when this happened tonight coupled with a bit of engine power loss (interestingly however this was NOT accompanied by the generator dash light)
Bad regulator? Fan belt slipping? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed Dec 13, 2017 6:59 pm Post subject: Re: Yet another electrical puzzle |
sb001 wrote: |
Bad regulator? Fan belt slipping? |
I think that you are on the right track. Since you don't seem to have a dash voltmeter gauge or a plug-in digital voltmeter that goes into a cigarette lighter - if you had such accessory lighter - what I'd do would be to tighten the fan belt a little and see if things were better or the same.
If things did not get better, unless you're able to monitor voltage across the battery when such symptoms occur, I'd install a new Bosch solid state voltage regulator, about $32.
I have such Bosch solid state voltage regulator on my 1970 since last year, my generator light would come on after a few minutes of driving, now OK. No - I didn't bother to read my voltage either before or after my red warning light came on, I knew it was bad, was also getting hot and smelling. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Wed Dec 13, 2017 7:40 pm Post subject: Re: Yet another electrical puzzle |
I had these symptoms with an alternator, LOUD radio and BRIGHT lights, off and on. I had a plug in voltmeter at the time and it would read 17 volts!
internal regulator obviously different than yours but essentially the same. _________________ 1972 1302
HPMX 40's & 019 |
sb001 Samba Member
Posted: Wed Dec 13, 2017 7:57 pm Post subject: Re: Yet another electrical puzzle |
I honestly think it's the voltage regulator, it seemed like there was a faint whiff of burning smell when it happened too, MAN did those headlights get bright too I'm sure some oncoming folks were cussing me out _________________ I'm the humblest guy on this board.
1600 SP engine
EVfun Samba Member
Posted: Wed Dec 13, 2017 8:20 pm Post subject: Re: Yet another electrical puzzle |
Please check the connections at the generator and at the voltage regulator and make sure they are solid and clean. I am particularly concerned about the voltage regulator ground to the mounting points under the rear seat. It sounds like the regulator is not seeing a clean system voltage reference. When it sees less than actual it cranks up the output. _________________
Wildthings wrote: |
sb001 Samba Member
Posted: Wed Dec 13, 2017 8:25 pm Post subject: Re: Yet another electrical puzzle |
EVfun wrote: |
Please check the connections at the generator and at the voltage regulator and make sure they are solid and clean. I am particularly concerned about the voltage regulator ground to the mounting points under the rear seat. It sounds like the regulator is not seeing a clean system voltage reference. When it sees less than actual it cranks up the output. |
Will do, thanks! _________________ I'm the humblest guy on this board.
1600 SP engine
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Wed Dec 13, 2017 9:23 pm Post subject: Re: Yet another electrical puzzle |
You really should perform a voltage drop check, of the ground circuit, from the regulator to the battery negative and then the generator body to the battery negative. More than .25 volts out of wack and problems.
You can perform similar checks on the battery positive, from the battery, up to the light switch, then ignition switch and then the regulator.
clean those connections on the end points if all else fails. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
airschooled Air-Schooled
Posted: Thu Dec 14, 2017 1:15 am Post subject: Re: Yet another electrical puzzle |
Are you running a mechanical voltage regulator or solid state?
The switchover in mechanical regulators can stick sometimes, causing low or high outputs that are only detectable by light surgings. Cleaning the mechanism and filing the contact points helps, (though Bentley does instruct to replace the unit as a whole.)
www.airschooled.com |
sb001 Samba Member
Posted: Thu Dec 14, 2017 6:52 am Post subject: Re: Yet another electrical puzzle |
asiab3 wrote: |
Robbie |
It's the old style mechanical Bosch, and it likes to make weird clicking sounds that I had forgotten to mention, can't hear that anymore with the new seats in, but I'm sure it's probably still doing it. _________________ I'm the humblest guy on this board.
1600 SP engine
hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Thu Dec 14, 2017 7:11 am Post subject: Re: Yet another electrical puzzle |
Mine also has the flickering gen light,
i have a brand new generator and solid state reg.
still does it but goes away when i turn my lights on,
it's probably a bad ground, but i'm just too lazy to check _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
Cusser Samba Member
Posted: Thu Dec 14, 2017 8:33 am Post subject: Re: Yet another electrical puzzle |
sb001 wrote: |
I honestly think it's the voltage regulator, it seemed like there was a faint whiff of burning smell when it happened too, MAN did those headlights get bright too I'm sure some oncoming folks were cussing me out |
In the late 1980s, I had a 1979 Toyota truck. One day, all my interior lights got real bright and burned up the bulbs, same with my parking lights and tail lights. I limped it home (night, obviously) using the headlights and the hazard lights to have some rear lighting. Apparently the flashing on/off was not enough to heat up the flasher bulb filaments enough to burn those out. Yes, fix was to replace the alternator (with its internal regulator) and all the burnt out bulbs.
So I think there will be high voltage in the VW due to faulty regulator, at least that's an easy R&R. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
vwoldbug Samba Member
Posted: Thu Dec 14, 2017 1:43 pm Post subject: Re: Yet another electrical puzzle |
Do you have a voltmeter you can hook up and drive for a while to watch the voltage . Also look at the battery for signs of overcharging but it does sound like a bad voltage regulator . |
sb001 Samba Member
Posted: Thu Dec 14, 2017 1:51 pm Post subject: Re: Yet another electrical puzzle |
vwoldbug wrote: |
Yes I can do that- but since I have another regulator lying around and it only takes like 5 minutes to swap them out, I might just go ahead and try it. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Thu Dec 14, 2017 2:32 pm Post subject: Re: Yet another electrical puzzle |
Sounds good |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Thu Dec 14, 2017 3:50 pm Post subject: Re: Yet another electrical puzzle |
sb001 wrote: |
My bet is on regulator as well, but also if the regulator is not grounded well that could potentially also be the cause. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Thu Dec 14, 2017 7:00 pm Post subject: Re: Yet another electrical puzzle |
It's highly likely your autostick electricals are causing the problem, you'd be better off just converting over to a manual transmission and be done with it. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
sb001 Samba Member
Posted: Thu Dec 14, 2017 9:05 pm Post subject: Re: Yet another electrical puzzle |
scrivyscriv wrote: |
It's highly likely your autostick electricals are causing the problem, you'd be better off just converting over to a manual transmission and be done with it. |
Look I know you're insanely jealous that I've had my beetle since new, that the fact that it's an autostick makes it unique where yours is just yet another shrug-off specimen, that mine looks fantastic and I get compliments on it wherever I go while yours turns not a head, and that I've been able to keep it in stock form and running great while you've had to constnatly tweak yours just to keep it sputtering along- that's no reason to take your aggressions out on my posts here. _________________ I'm the humblest guy on this board.
1600 SP engine
wet_bread Samba Member
Posted: Thu Dec 14, 2017 10:17 pm Post subject: Re: Yet another electrical puzzle |
sb001 wrote: |
running great |
Posted: Thu Dec 14, 2017 10:22 pm Post subject: Re: Yet another electrical puzzle |
wet_bread wrote: |
sb001 wrote: |
running great |
Burn returned _________________ Robert in Memphis
Cusser Samba Member
Posted: Fri Dec 15, 2017 6:47 am Post subject: Re: Yet another electrical puzzle |
sb001 wrote: |
I know you're insanely jealous that I've had my beetle since new... |
Personally, I'm not jealous at all - good for you !!! And your business if yours is Autostick, I can't figure out why some here are negative to you and others because of that.
I got my 1970 when it was just 2 years old, and 2 years has been the newest vehicle I've ever had (think 6 is next newest). _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
