Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Jul 17, 2018 10:02 am Post subject: Re: Introducing the Ghiapet |
c21darrel wrote: |
... if nothing else you have a great entertaining mind. Enjoying your updates! |
Thank you sir, I'm glad someone finds this thread entertaining.
c21darrel wrote: |
I must have been shorter |
I'm 6'4", IDK how anyone my height can fit into a Ghia without relocating the seats, I couldn't even get in & out without being a contortionist in the car's original configuration.
c21darrel wrote: |
Also, during filming, please add to our experience by periodically glimpsing at speedo and gear in use. |
Yeah, umm, you don't have time to look at those when reacting to the obstacles much less trying to record them. In the first straight you can hear me shifting into third, I'm probably doing 40ish, the rest of the time I was in second & doing 25-30 which is still a decent pace given the terrain & not wanting to destroy the car. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
c21darrel Samba Member
Posted: Tue Jul 17, 2018 12:09 pm Post subject: Re: Introducing the Ghiapet |
TDCTDI wrote: |
c21darrel wrote: |
c21darrel wrote: |
c21darrel wrote: |
Yeah, umm, you don't have time to look at those when reacting to the obstacles much less trying to record them. In the first straight you can hear me shifting into third, I'm probably doing 40ish, the rest of the time I was in second & doing 25-30 which is still a decent pace given the terrain & not wanting to destroy the car. |
Yeah, Im not quite 6'4" closer to 5'10". Im an easy fit.
My daily driver came from the factory with a gopro mount on the windshield. You need one for your iPhone lol. Just keep enjoying the Ghiapet, I am. _________________ GhiaBuild
1967 DC build
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Tue Jul 17, 2018 1:29 pm Post subject: Re: Introducing the Ghiapet |
Believe it or not, I've actually contemplated a Chia seed mat for a Mohawk for the Ghiapet (Now who's "on the pipe")
In my quest to make an improvement on the beast daily, I decided to decrease the Ghiapet's threat of spontaneous combustion.
Today's project consisted of trying to remedy the neat creeping, weeping fuel wall fountain on the passenger side kick panel that's instigated by spirited left hand turns. After a little investigation, I determined that the hose on the filler neck had a few cracks in it (at least I was hoping that's all it was).
So I removed the old one..
Sourced a replacement & cut it to length
Then I slathered some Ospho into the filler neck to slow the progression of rust.
And then wrassled the hose into place.
This concludes today's what not to do to your classic car, and as Smokey Bear says, "Only you can prevent forest fires". _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Jul 17, 2018 2:30 pm Post subject: Re: Introducing the Ghiapet |
TDCTDI wrote: |
...Believe it or not, I've actually contemplated a Chia seed mat for a Mohawk for the Ghiapet (Now who's "on the pipe") |
I'd donate a dollar to see that You'll need to hang a giant gold hoop earring from the driver side door handle to complete the look.
Who's with me? _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Tue Jul 17, 2018 8:06 pm Post subject: Re: Introducing the Ghiapet |
Mmm, patience Darrel-san. For, like the Great Wall of China, the Ghiapet was not built in a day.
If you only knew the hell I went through to find a 9” section of 2” fuel filler hose. One numbnut at one of the four FLAPS (and I’m definitely substituting the four letter F word here) that I had to go to, suggested that I use a radiator hose.
c21darrel wrote: |
vaper is optional. |
Ain’t that one of them there eeletronical cigarette puffing millennials? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jul 20, 2018 7:38 am Post subject: Re: Introducing the Ghiapet |
Over the last day or so, in my "must improve upon the project every day" method, I addressed some of the surface rust by first attacking it with a stiff wire brush, then blowing off the dust & then slathering it down with some Ospho. Nothing exciting.
I made sure to work lots of Ospho into the joints & seams.
Then I did the same to the seam in the driver side door after clearing out the drains.
After letting it dry/cure, I cleaned it with acetone & shot them with some primer. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Jul 25, 2018 7:53 am Post subject: Re: Introducing the Ghiapet |
I grabbed a can of paint from the hardware store that looked close in color (it was not) but I shot some cover coat over the primered rocker & inner door to slow the progression of rust. The new color is a bit brighter, which I don't mind, it looks like another layer of rattle can paint is in the future for the Ghiapet.
It actually got a bit darker as it cured.
Posted: Wed Jul 25, 2018 12:08 pm Post subject: Re: Introducing the Ghiapet |
c21darrel wrote: |
What the hell are you doing??? Building a trailer queen? |
You know, "trailer queen" has a whole different meaning in these parts _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Jul 26, 2018 3:42 pm Post subject: Re: Introducing the Ghiapet |
Today I decided that I was just going to lower the car like everyone else.
JUST KIDDING!
I've been fighting & trying to dial in the left rear corner a few times & ended up overshooting by 3/4" last time so I pulled it apart again so I could do that whole "two steps forward &two steps back" thing.
And finally got it level
(How many times & how hard do you have to let your car door hit the side of your old car before you decide that it's time to get rid of it?!?!)
While I had the wheel off, I found my occasional rubbing noise & carefully pounded the fender into submission.
And just because I was on a roll, I jacked up the front end to address the fact that the suspension limiters were a bit too close & making contact a bit too early...
So I raised the front end about an inch & a half.
That concludes today's "how to fu*% up a classic car" _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Jul 26, 2018 4:53 pm Post subject: Re: Introducing the Ghiapet |
Makin friends, everywhere you go just makin friends. _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
Posted: Fri Jul 27, 2018 7:00 am Post subject: Re: Introducing the Ghiapet |
Evil_Fiz wrote: |
Makin friends, everywhere you go just makin friends. |
Yup, that's me, asshole extraordinaire
c21darrel wrote: |
Karmann ghias only self clearance on one side?
You had me, I thought you were going to lower it. |
Sorry, I couldn't help myself, I had to have some fun after having to do the same thing 4 times to get it right Good news is that I've got the process down to about 20 minute per side.
The other side makes a bit of contact also, but not as much since my fat ass isn't over there & I didn't have the wheel off already. I'll allow the front to make contact but in this case the fender lip was effectively a knife edge just waiting for the opportunity to filet the sidewall of the tires.
FWIW, here’s a vid of the hook & rod suspension limiters in action.
These should be installed in every extremely lowered car to avoid balljoint failure. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jul 27, 2018 7:01 pm Post subject: Re: Introducing the Ghiapet |
Well, I done painted myself into a corner now. I checked the events listing of Tarheel Sports Car Club, the local SCCA charter & registered the Ghiapet for a nearby event on August 19th. So that gives me two weekends to get the beast tech spec ready. Realistically, since i’ve been through all of the mechanicals, I only have to get the seats mounted properly & get seat belts in it.
So today I started fabbing up the passenger seat mount, this one is different from the driver side due to the realization that the seat bottom needs more angle. The driver side currently is a bit too flat causing me to sit only on my tail bone & being a bit uncomfortable on my 1/2 hour drive home.
While trying to decide the best height & angle, the loud creak brought to my attention “ Hey dumbass, you haven’t bolted that pan to the heater channel yet”
So, like the other side, I simply used the original hole...
To drill through the new layer to find the threaded hole in the channel.
After securing three or four of them, I decided to take a break, get out of the sun & rekey a door handle, toss it on & drive the beast home.
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Fri Jul 27, 2018 7:14 pm Post subject: Re: Introducing the Ghiapet |
Will you be attending Wake Forest Cars & Coffee tomorrow morning?
Bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Fri Jul 27, 2018 7:22 pm Post subject: Re: Introducing the Ghiapet |
Whaaa?
Where at? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jul 27, 2018 7:47 pm Post subject: Re: Introducing the Ghiapet |
TDCTDI wrote: |
Whaaa?
Where at? |
PM'd you...
